Question about Olympus SP-560 UZ Digital Camera
SP-560UZ zoom error
Zoom error
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 27, 2010
My memory card keeps poping out of the slot when I try to insert it
As long as it is the correct card and being inserted correctly, it will probably be the tiny latch that holds the card in by spring tension that has failed. It will need to be checked by a technician. You may be able to wedge something in to hold it if you don't want to spend the money but be aware that you may lose data if it slips out.
Jan 05, 2014 | Olympus SP-560UZ 8MP Digital Camera with...
No sound when I video tape with olympus sp-560uz
my brother inlaw had the same kind of problem he had to leave it in to be fixed it was a microphone go inside the camera
Mar 24, 2012 | Olympus FE-230 Digital Camera
Olympus SP-560UZ "Zoom Error" then shuts down
If you have recently dropped the camera you may have damaged the lens tube (housing). This damage will prevent the lens from moving properly and will cause the camera to shut itself off after a few seconds. If the lens is damaged the camera will require professional repair. If the lens is not damaged, the problem may be battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Sep 14, 2009 | Olympus SP-560 UZ Digital Camera
Zoom error
I had the same problem with my 6-month old Olympus SP-560UZ  and was quite upset until I thought of a way around this. The error seems to be due to the lens becoming off axis and not extending. I was able to turn on the camera by lying it down flat on its back so the lens will extend straight up when the camera is powered up. Once it is turned on, it seems ok to move it back in its normal position.
So far so good - and it is free…
Sep 19, 2008 | Cameras
Zoom Error
Have you tried changing the batteries to new/charged ones?
Jul 21, 2008 | Olympus SP-310 Digital Camera
Zoom Error
I think a grain of sand was blocking the zoom tubes. This will not work if the camera has been dropped & the zoom apparatus is bent. It is entirely at your own risk & may invalidate any guarantee but they may charge anyway if you have got sand in. I cut a finger of 80gm computer paper 1cm X 5cm. Inserted this first  around outer zoom tube & worked it all around. It goes in quite deep so be gentle. I switched on to open zoom & tipped out batteries before it had time to close & repeated procedure. When I put batteries back in it worked OK. I repeated procedure with lens fully extended. I found a thin bit of plastic packing worked better as it did not kink so easily. It is still working today having failed 100% before.
Chris
Jul 02, 2008 | Cameras
ZOOM ERROR
zoom error usually comes from lens off track or bent.. definitely needs repair
Feb 10, 2008 | Olympus SP-550 UZ Digital Camera
Olympus SP-560 UZ Digital Camera Logo
141 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
