Question about Intel PRO/Wireless 3945ABG Network Connection (WM3945AGMW1WB)
My laptop will not recognize the router and will not work wirelessly. Also, the connector where I would plug in the cat 5 cable to work as wired is broken, so I NEED it to work wirelessly, How do I do this?
  • 2,263 Answers
Check the wireless adapter. Is it working or not ? For this you will need to go to the device manager. When you try to connect to the wireless network . Do u get any message ? Check the settings of the router also. Is there any other computer online wireless ? if there is other computer online then the router must be working properly. Click Here for step by step solution
Posted on Nov 16, 2009
Can't figure out how to hook up my WBR-2310 to my laptop
1:get a Cat 5 e cable 2:plug it into the port on the back labeled WAN 3:plug the other end of the Cat 5 e cable into the internet 4:turn your laptop on 5:go to wireless networks 6:choose your wireless router,have fun 7:do what you want on the net!
May 04, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
How do i connect to a wireless internet router
You need a cat 5 ethernet cable that goes from the uplink port to the router. The rest is wireless. Most routers offer cat 5 ports where you can plug a computer in. Dont use a telephone wire ... telephone wire is RJ 11 - you need a RJ-45 caat 5 cable. They look similar.
BTW, most wireless runs at about 10 - while wire runs at 100 or 1000.
You will need to run the wizard on your computer to detect ... and/or load the software that came with the router.
Thanks for your interest in FixYa.com
Mar 06, 2010 | Computers & Internet
Belkin router
The router normally goes between the Cable Modem (or DSL line) and the computer. Use a CAT-5 cable to connect modem to the WAN input connector on your router (the connector labelled "Internet), then another CAT-5 cable goes between any of the ports and your computer. Using your web browser, go to 192.168.1.1 and continue with the router setup, choose an SSID (what you name your network), followed by Wireless Security if your router supports wireless as well. I like WPA-PSK[TKIP] for its simplicity. Anyway, the router is now useaqble by other computers!
Nov 11, 2009 | Computers & Internet
Bought wireless connection still cant connect to internet on wii system Belkin_G_Wireless_9430BF is the namw of the wireless connector can connectwith ps 3 but not wii
does the wii see the router do you have a laptop to make sure its sending a signal try this dis connect everything plug in the modem let it symc up by it self then plug in the router and hook up the cat 5 cable to the router
the try to sync the connection with the wii by searching for the router
it helps to name your router first with a laptop but that should work if not let me know iam a cable tech with a few tricks
Aug 01, 2009 | Nintendo Wii Console
Hello, I have 2 problems with my lenovo laptop z61m, that is running IE8. But first please know that my wireless internet connection is very low and I may be booted offline. In which case please email...
Test your CAT 5 cable on your laptop again, but first right-click your wireless icon, and click open network connections. Then right-click the LANconnection and click Enable. That should do the trick.
Jun 24, 2009 | Computers & Internet
Cannot connect to Xbox live because my xbox can't obtain an IP adress
Okay check the cable of the xbox make sure its not broken or KINKED could have a broken wire somewhere make sure the wire work try the wire on a computer to see if it gets an IP.
Check the connector too, make sure none of the wire are lossen up, if so then replace the connectors or buy a new wire. make sure its Cat 5 or Cat 5E. doesnt have to be cat 6. thats overkill.
if its wireless then check if your router has WEP or WAP enabled, then you have to get the Key to get into the router, and make sure the SSID of the router is correct.
Hope this helps
Good Luck
Rate this please
Dec 19, 2008 | Microsoft Xbox 360 Console
Wireless connection works but no plug in connection
The wired nic in your laptop will have a separate ip address than your wireless nic. I suspect you either have the router not set to hand out ip addresses, the info it is handing out is wrong, or you may have a static ip set. Did you ever have the laptop working on the wired nic?
Try disabling the wireless connection, plug up the cat 5 cable, open a dos prompt and type;
ipconfig /all
Notice the information. Now unplug the cable, enable the wireless connection and do the same for the wireless nic. The ip address should be different, but everything else should be the same. Let me know what you find.
Oct 12, 2008 | D-Link AirPlus DI-524 Wireless Router
ENET Port issue on BEFW11S4 Wireless Router
Hi!
Try these steps:
1. Make sure the wireless is disabled when you're doing that. It might cause a confusion between the wired and wireless connection.
2. Try to plug it at other ports (1-4)
3. Try another known working ethernet or CAT-5 cable.
4. Set the laptop's LAN card's speed to 10-hald duplex.
Try these and hope it will help you ;-)
Apr 02, 2008 | Linksys BEFW11S4 Wireless-B Broadband...
Computers & Internet Logo
711 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
