Rear projection tv picture problem
Hi
I am facing the following problems in my Projection TV
1.When the TV is Switched on the picture freezes for some time then works properly
2.Some disturbance comes in between and the picture is not seen
3.When we switch between channels the image of the earlier channel isdisplayed in still mode whereas sound of the current channel is heard
4.Of late the when the TV is switched on no image is seen only thesound is heard and after some time the actual picture is seen , thepicture then fades of and bands of differnt colors are seen
5.and sometimes there is just a green screen
Can anyone please tell me what is the exact problem in the TV
Thanks in advance
  • 1 more comment
  • olson1031 Mar 09, 2008
    i changed the light in the tv, seen a lot of dust build up inside, went to the store and purchased a can of air to blow out inside of fan, bulb and other parts, turned on tv, worked fine for a few minutes then the screen started to act up, good sound but screen gets bright lines in it and jumps around then light goes out then comes back on. i just wanted to clean out dust now i am in a real mess.
  • casperandeww Jan 13, 2009
    i have a mitubishi rear projection tv older 90 something the screen goes out compleatly some times but sound stays on it doesnt always do it sometimes for hours with out issue its fine then suddenly goes out and others minutes then out.
    what can I do to fix it
  • cricketta831 Mar 05, 2009
    We have a RCA HD projection TV that was purchased new in 2005. When we turn it on, it takes a long time for the picture to come on and it makes kind of a fuzz noise with some squealing. When the picture starts to come on, you can only see a shadow of the picture with wavy lines through it. If you tap it on the left side at the top, it works right. What can we do?
Sorry no model ---it is a Toshiba 43V9UE rear projection T.V. and i have been told it may be the scanner modual
Posted on Jan 11, 2008
  • 8,617 Answers
Sounds like a tuner or Video output problem. What make and model set do you have.
I have a sony kp-48s65 projection tv. I have three lamps in back a red a green and a blue. when turned on the sound always works
timer standby light blinks steady at 1 pace Once in a while the picture will just come on and work fine it may work for 1 hour or 10h min then the picture goes out . What can i do. People say lamps but when the picture is on and working the three lights behind work fine . its like whatever powers the lights isnt working
Unplugging and plugging back in and waiting usually brings it back on. For so long . When it is on the screen I can see hard bright green and red the picture is really too red its ok but its hue is off or something Tv in good shape what do i do?
tv consumer
Posted on May 07, 2008
SOURCE:
Hi, our toshiba rear projection tv will turn on but no picture. whats the problem? thanks
MODEL NUMBER 56H80 TOSHIBA PROJECTOIN TV,PICTURE IS NOT COMING AT ALL
WHATS THE PROBLEM
Feb 04, 2011 | Toshiba 57H81 57" Rear Projection...
Zenith Rear Projection Model PVY5265RK
the problem you r facing is absolutely repairable but the charges will be heavy.
now its upon you to go for new or get it repaIRED.
i will suggest you to go to repair center and get it repaired as this problem is faced by many users and it is completely repaired.
Oct 24, 2008 | Zenith R56W36 56" Rear Projection...
The picture is out of foucus
If your tv is Sony KP-51WS500, then its rear projection tv and problem seems in convergence stage.
Please confirm model number to guide you further.
Oct 11, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony rear projection
My dad has a sony rear projection tv and had this same problem. A shop had to replace one of the color tubes(?) (green, red, or blue) had to be replaced. The shop said this was common with Sony rear projection TV's.
Dec 11, 2007 | Sony KP-51HW40 51" Rear Projection...
SAMSUNG PICTURE FREEZE (LOOKS BLACK&WHITE)
I have the same problem... It turns B&W
I can still hear the sound... however I can still turn the tv off when that happens
Aug 28, 2007 | Samsung HLN617W 61" Rear Projection HDTV
TV Picture Freezes and Turns Off; Cannot Use Remote
My shop had this problem yesterday. We had to change the DMD to correct it. One of the data lines was being drawn down intermitently. This doesn't eliminate the digital PCB, but, we have seen the DMD do this more than a digital. You should have an authorized shop do the repair. Contact Samsung at 1-800-SAMSUNG or contact by email: http://samsung.com/ContactUs/ContactUs.htm Hope this helps.
Mar 30, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Televison & Video Logo
1,248 people viewed this question
Top Televison & Video Experts
Ekse
