Question about Craftsman Garden
My craftsmanleaf blower number 358797180 will
My craftsmanleaf blower number 358797180 will not start and cuts off during use
  • 486 Answers
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Posted on Nov 16, 2009
AO error code on 250k btu hayward pool heater
Dear ,
Please try the below solutions,
Solution 1:
If the blower prover switch does not close after the blower starts the control will stop the ignition trial go into lockout. The blower will continue to run. Automatic reset is immediate after the switch closes
Solution 2:
If the blower prover switch opens unexpectedly during operation the control will shut down and attempt to re-light. If the switch does not close after the blower starts the control will go into lockout with the blower running. Automatic reset is immediate after error is corrected
Solution 3:
If the blower prover switch opens during the postpurge cycle (heater is not fir- ing) the control will display the error code. The post-purge cycle will be com- pleted once the blower prover switch close
Regards,
Samy
Aug 10, 2014 | Hayward Pool & Spa
I own a 1998 GMC 2500 5.0 L pickup and for several months now the blower motor has been working intermittently. It doesn't seem to matter what speed the selector is set on. It will come on and off several...
You say the blower goes on/off at any speed?,you mean if on high it cuts off?,on low it cuts off?sounds the same???. Try putting a continuity lamp at the fuse box and watch(someone watch)to see if light goes on/off;"could" be power is disconnected at blower(if light stays on). This is free of cost(s) and somewhere to start. Hope this helps somewhat. Alberto
Feb 07, 2014 | 2005 Chevrolet Silverado
Where is the heater motor
You can get to it from the engine compartment, but you have to cut the cover off. There is an indented line showing where to cut. See picture below.
  1. For the 3.1L engine, remove the alternator belt, then remove the alternator and position aside.
  2. For the 2.5L and 3.3L engines, remove the power steering pressure hose from the power steering pump.
  3. For the 3.0L engine, remove the serpentine belt.
  4. For the 3.0L and 3.3L engines, remove the retaining bolts from the power steering pump bracket, then set the pump aside.
  5. Detach the blower electrical connector, then, if accessible, remove the cooling tube.
When cutting the blower motor cover, make the cut just the thickness of the cover, which is1/ 8 inch (2mm) thick. Cutting deeper than that may damage the cooling tube.
For 1992-98 vehicles, partially cut the blower motor case cover, as shown on the cover. Cutting completely around the cover is NOT required. Swing the cut potion of the cover down.
  1. If previously accessible, disconnect the cooling tube.
  2. Unfasten the attaching screws/bolts and remove the blower motor from the case.
  1. If necessary, remove the fan from the blower motor.
  2. The installation is the reverse of the removal procedure.
  3. If the case was cut during removal, secure the cover using the three retaining clips. Tighten the blower motor screws to 44 inch lbs. (5 Nm).
  4. Connect the negative battery cable, then start the engine and check the blower motor for proper operation.
Dec 01, 2010 | 1997 Pontiac Grand Am
Location of the blower motor
from autozone.com: access from engine compartment
REMOVAL & INSTALLATION
See Figures 1, 2 and 3
  1. Disconnect negative battery cable.
Fig. 1: Exploded view of the blower motor assembly
973a989.gif Fig. 2: Some later model vehicles require you to cut the case, on the indicated lines, in order to access the blower motor
Fig. 3: On 3.0L engines, you must remove the power steering pump for access to the blower motor
Sep 22, 2010 | 1997 Pontiac Grand Am
When furnce starts blower comes on exchaust then burnner light as it warms the main blower should come on but does not burnner shut down after high limits need to no why main blower fails on start up motor...
check the afc automatic fan control when heater heats up fan cuts in ,or cuts out if fan dose not start , check to see if back of afc is clean on dust or fluff in it
Aug 16, 2010 | Heating & Cooling
Brand new electric mulching blower/vac : cut out after 10 secs.
Electric motors sometimes have circuit breakers to protect them from overload or overheating. Some reset automatically, some don't. But even if you found and reset a breaker, this shoudn't happen 10 seconds after starting a new unit, unless you sucked a branch into it during those 10 seconds! Take it back to the store for a replacement.
Jul 04, 2010 | Garden
Heater Burner ignites but main blower motor will not turn on.
it sound like the blower motor may be seizing up. try spining the blade by hand to see if it feels free or not. the motor could be trying to turn but can then tripping itself out on overload. (most motors have built in safety overloads which will trip during an overcurrant event. aka too many amps.) you may have to replace blower motor
Mar 16, 2009 | Mr. Heater Natural Gas Garage Heater -...
McCulloch 32cc blower, what is the fuel mixture, gas/oil
Do a 40:1 ratio to start, if it smokes cut it back alittle but 40:1 should be ok. Better to be alittle high on mix than not enough.
Jan 05, 2009 | McCulloch 26cc Backpack Blower with Dual...
Garden Logo
319 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
