Question about Dell Inspiron 1525 (dndppa1_3) Intel Core 2 Duo T5550 (1.83GHz/667Mhz FSB/2MB cache) 120GB/3000MB PC Notebook
How do I reduce the noise of my laptop? My fan is too noisy!!
  • 3,153 Answers
Only do this if you feel competent in doing so.
Pulling apart laptops is not for the faint of heart.
If you really must do it there are some
good guides here
An alternative is to get a can of compressed air used to clean computers. Put the nozzle on and spray it in every hole you can see without putting the nozzle itself inside the laptop.
Do this outside with glasses on.
You may also want to remove the hard drive and ROM drive.
Take a
peek here for more ideas of what is involved.
There are a few are tips for various things in there.
DON'T touch the CPU cooler unless you know what you are doing and have some thermal grease for CPUs to hand.
To make newer laptops last longer between cleaning a good 3 fan cooling pad is suggested.
never use a laptop on soft surfaces as the ventilation can act as a mini vacuum cleaner and encourage dirt build up.
Soft surfaces also block the vents causing fans to run more and burn out sooner.
Hope this gives you the information you need
Posted on Nov 15, 2009
  • 641 Answers
You cann try removing the covers..abd cleaning it..but it probably needs a fan replacement..it isnt a hard job..just make shure you map out the location of all thescrews..kinda like a little scamatic..otherwisw you might put a to long screw into a holer and short something out.. i know this from past experiance
How to reduce fan noise
The noise is either dirt on the fan blades or noisy bearings. Try cleaning first. If that doesn't work, replace it.
Mar 23, 2014 | HP Pavilion Computers & Internet
Acer fan noisy
its usually dust problem. open Laptop casing and clean it via Air blooring machine hope it will reduce noise.
Dec 10, 2013 | Acer Aspire Computers & Internet
How to fix noisy fan in chef fan forced oven
Possible fault in the bearing bushes , in the first place you can spray a WD40 or even some light oil into the fan's rotor ends where the bearings are located. If the sound reduces clean and wipe off excess oil from the shaft side. Also make sure that the fan leaf is not making the noise due to any dirt accumulation or obstruction.
Jan 09, 2012 | Ovens
I have Acer Veriton 5800 desktop and often the noise get louder and faster and then it quieten down. Do you think it a fan?
Most desktops have fans fitted, especially in the power supply.
The bearings and not that good and become noisy when older. They are replaceable but a replacement power supply is far less effort.
Show the fans a plastic pipe from a vacyym cleaner from time to time, that will make the fans more efficient and reduce the wear and noise.
The hard drive can get noisy also, (if it is I would before it is too late), recommend replacing it.
Hope that helps.
Dec 09, 2010 | Acer Veriton 5800 PC Desktop
Fan noisy
Fan is placed in notebook so as to expel the heat produced in the laptop. Try using your laptop in a cool sorrounding, so that the fan speed will be reduced. Try to clean the laptop. If your not sure how to open the laptop and clean, give to a near by technician and get it cleaned. Thank You.
Jun 17, 2010 | Sony VAIO PCG-K23 Notebook
Fanning system has become noisy. Dell vostro A860
mine too! I;m going to replace the fan and go from there
Jun 26, 2009 | Vantec Fan Vibration Dampener Noise...
Sony Vaio laptop fan is very loud and continously running
My pcg-k33 was very noisy (fan) so I vacuumed the fan opening with a powerful shop vac. This helped alot. I think that the CPU temperature triggers the fan so keeping the cooling system clean is important. As well, there are openings on the bottom for air so it is important to keep the unit on a surface that doesn't impede airflow (on your lap is a bad idea)
Mar 17, 2009 | Sony VAIO VGN-FJ270/B Notebook
Noise
That noise is due to your Power-Supply-Unit, Hard-Drive, Optical Drives, other spinning devices, and ventilation fans. You can reduce some of it but not all of it.
For example, your hard-drive could be rather old and producing a lot of noise when it spins up, reads, or writes data. You could replace it with a newer hard-drive which barely makes any noise. The same with your Power Supply Unit (PSU). It could be old and rather noisy. You could buy yourself a newer one such as the ones made by PC Power & Cooling which gets you a quieter product. However that's about it as you DO NOT want to reduce the amount of fans in your system.
Sorry if this was not the solution you were after. However most noise from a computer stems from ventilation fans which can be replaced but should not be removed.
Feb 02, 2009 | Abit NF7-S V2 Motherboard
Loud cooling fan hum
If the fan was not that noisy before , this can only be cause by a dirty fan and you may need to clean it up to reduce the hum coming out from it...
Dec 28, 2008 | Acer Extensa Laptop
Laptop Noise
If this is a new problem, replace the fan. If it has always been noisy , I guess you will have to live with it.
Oct 23, 2007 | Toshiba Satellite A60 Notebook
Dell Inspiron 1525 (dndppa1_3) Intel Core 2 Duo T5550 (1.83GHz/667Mhz FSB/2MB cache) 120GB/3000MB PC Notebook Logo
187 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
