Question about LG Projection Televisions
  • 192 Answers
SOURCE: LG Projection TV has dark picture
Normally the main cause of any DLP having a dark picture is the lamp. I would replace it and it should look like a new set again.
Posted on Jul 01, 2007
SOURCE: LG Rear Projection Television Model RT-56NZ23RB - Fault
For my LG TV - LG RT-56NZ23RB, I replaced two STK 392-120 chips and it has fixed convergence problem now.
Posted on Jun 09, 2008
SOURCE: access service menu lg rear projection tv
Hold the menu button on the remote and the menu button on the tv down simultaneously for 5 seconds.
Posted on Aug 10, 2008
SOURCE: 52" LG LCD rear projection screen blue discoloration
bonsoir!ce que vous avez ici c'est un probleme de light engine ;c'est surement un le filtre bleu qui est brule et cette tache va remplir tout l'ecran apres,il faut contacter lg et manifester parceque le light engine coute tres cher 900 us
Posted on Oct 18, 2008
  • 7 Answers
To do this, press the ENTER button on the TV and the MUTE button on the remote at the same time. After 5 seconds the screen should come up and it will read "Lamp use time...Total lamp use time ....lamp reset" Press the center button on your remote (the circle button right in the middle of the four directional buttons) and you will be reset to -0- again. Your orange light should now be off.
Posted on Feb 02, 2009
  • 6784 Answers
Normally when this happens, this is because of the power supply board is going threw some abnormal fluctuation. i would check this board for minor solder breakage.
Posted on Feb 06, 2009
0 characters
1 Points
Tv will not switch on just stays in standby mode
Sounds like a power supply problem you will need to take it into a local repair shop
Mar 19, 2010 | Samsung HCN4226W 42" Rear Projection...
LG 52 Inch Rear Projector TV - switches itself off
LAMP pull it out and see if it looks busted on the inside.
Dec 21, 2009 | LG RU-52SZ51D 52" Rear Projection...
LG rear projection tv. sound but no picture.
Go to a repair centre, some parts must be fixed/replaced.
Jul 22, 2009 | LG RU-52SZ30 52" Rear Projection...
No picture yellow standby light blinking
how old is the tv is it possible your lamp is burned out this is what a dlp screen would do.
Apr 14, 2009 | LG RU-52SZ51D 52" Rear Projection...
LG rear projection. RE-44SZ21RD - flashes amber
get a ohm meter and check all the fuses
Mar 27, 2009 | Projection Televisions
Lg RU-52sz30 rear projection tv does not go on
I have an lg dlp projection tv Model # 52sx4d-ub.I replaced the bulb,everything correctly,but no picture. LG says I have to have a tech come out to reset? Can you help.
Jan 23, 2009 | LG RU-52SZ30 52" Rear Projection...
Tv doesnt always come on straight away
Need more input, what model, what brand, do it turn on if you hit the side.
What About Bob
Feb 19, 2008 | Projection Televisions
Projection Televisions Logo
Top LG Projection Televisions Experts
Steven Wander
Steven Wander
Lawrence Oravetz
Are you a LG Projection Television Expert? Answer questions, earn points and help others
