Question about GPX ML648B MP3 Player
When i plug in my gpx ML648s into comp to sync, it says usb has malfunctioned and does not recognize it. what do i do?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 96 Answers
The pamplet which can be seen here http://s366.photobucket.com/albums/oo105/aStrangerInParadise/GXP%20MP3/ has a couple solutions.
I recomend holding down the reset button located on the back of the MP3 player, restarting your computer, and then plugging the device back in.
You can also go to www.windowsupdate.com to see if theres a Serive Pack that could help.
Try a different USB port.
Scan for hardware changes by right clicking on My Computer. choose Properties from the menu that appears. Then Click on Hardware tab, then click on Device Manager. Within Device Manager, there should be a listing for Portable Devices. If there isn't a listing for Portable Devices or the listing it shows is highlighted with a question mark, right-click on Universal Serial Bus Controllers and select Scan for hardware changes.
If you have a laptop, disengage the laptop's battery. Let the computer sit for thrity minutes to an hour before reconnection the power. The voltage level that you USB prots receive can sometimes be less than the threshold voltage required to activate and communicate with your Mp3 player. This process should return the power levels back to their original default setting.
Posted on Jun 05, 2010
My mp3 player not being recomignizer by computer.
when you turn it on. you should see the music screen. If you press the down arrow you should toggle between music, movie, picture and, settings. In setting under the online device option theres 2 choices. usb and media. its actually gotta be on usb to see the files stored on it.
i always see the tools folder in my computer. the files show as a sepeate drive in my compter with the online device settings set this way. might not be the same problem you got.
Apr 07, 2010 | GPX ML648B MP3 Player
Cant transfer music
The Driver Might have been misplaced for it
My Solution would be to install the disc if it came with one or go online to a website with drivers and download one the microsoft one is allright
Mar 25, 2010 | GPX MW6836DT (1GB) MP3 Player
My GPX ML648S MP3 player turned off while charging and won't turn back on. What do I do?
are you charging with your computer through the USB cord or did you get an adapter to charge via an outlet?
If charging with your computer, it could be a bad USB port, try the ports in the back of the tower if your using the front and vice versa.
Is the device responsive otherwise? Can you load music and the like while the device is connected? If not your USB Cord could be faulty and need to be replaced.
If you are using a laptop keep in mind that sometimes the amount of voltage required for this device does not always reach the USB ports. Try disengaging the laptop battery for an hour and then reconnecting it.
Mar 12, 2010 | GPX ML648B MP3 Player
My GPX player, model number MW259BU, will not work. When I plug it into the USB port, Windows gives me a message that it is not recognized and the device is malfunctioned. I updated Windows Media Player...
try
these steps:
1.plug your pen drive in your computer.
2.then open Control panel.
3. open administrative tools.
4.open Computer Management
5. a window label computer management will appear.
6. click disk management
7.locate you pendrive and select delete partition or format it fat 32 or other format convenient for your usage.
ok
hope this will help
cheers
uttam
Jan 21, 2010 | GPX MW3837 MP3 Player
Windows does not recognize deivce in usb port
How to try your premium assistance plan. Go to "iriver site or how?
Feb 03, 2009 | GPX MW3836 MP3 Player
Malfunction
You can try to take it out from the enclosure and plug the hard drive directly to your motherboard for you to retrieve the date. Or just buy a different drive enclosure.
Jan 21, 2009 | Seagate FreeAgent Pro Desktop - 320GB -...
My MW3836 won't sync
try takeing it off of usb cable trune it on then plug it back in then sync
Apr 24, 2008 | GPX MW3837 MP3 Player
Unable to download pictures from camera to pc
There are lots of different USB cables, not a real standardized piece. Try the USB that came with the camera or buy one that has your model listed. I have many and they all are specific to their models, some charge but dont sync, while others sync but dont charge, and some just dont do anything.
Feb 12, 2008 | Canon PowerShot SD950 IS Digital Camera
Worked first then boot error now comp wont pick it up
Hi, you can try to upgrade the player's firmware, you can download it from the RCA Website (moz-screenshot.jpgmoz-screenshot-1.jpghttp://support.rcaaudiovideo.com/downloads.aspx?product=187), the firmware it's the second app listed.
If your computer doesn't recognize the player, you'll have to turn it off and keep "PLAY" pressed for 10 seconds while connecting it to the USB port, then update the firmware.
Jan 31, 2008 | RCA OPAL M4001 MP3 Player
GPX ML648B  MP3 Player Logo
269 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
