Question about HP Computers & Internet
My Compaq nc6000 laptop sometimes wont turn on. Ill hit the power button the fan will kick on for about 7seconds or so and the lightning bolt symbol will stay lit. normally the hard drive lights, power light and the three lights by the power button will flash before the hard drive will start up and the fan kicks on. but if i keep pushing the power button it will eventually start. also when windows shuts down the computer sometimes it freezes and i have to shut it off by holding the power button down.
  • HP Master
  • 1,700 Answers
Old old old laptops, with windows 2000 or XP, (doomed for sure there both are VIRUS MAGNETS AND ZERO SUPPORT NOW)
a circa 2006 LT. (3+ years before W7 sold)
now the power fails. (could be a blessing....)
NO OS stated, what operating system is on this old dog.
XP?
Fans dead, means power failure.
BIOS dead, same or screen dead.
does external VGA screens work, not if it shuts off sure.
step 1 is does it run with the battery out, main battery huge. does it?
click Laptops black screens of deathhh here.
http://pcdied.com/black-screen.html
windows can freeze for many reasons, 1000s.
but is 2, in truth corruption or power loss.
you push the power button, battery out.
you hear fans,see lights but vastly more important
are the BIOS messages on the screen.
on my HP's power on, battery out. line cord in AC jack and power pack connected
we push power, and the screen always shows
"hit ESC to setup BIOS"
or some other key on OLD DOGS.
it must
if not you have no power. easy no?
if this works and the hot key ESC (0r your prompted )
key works, and bios screens work what is next
the HDD and its corrupted OS.
we then in a real shop boot to live windows PE stick or CD or Linux CD. live.
omg the the computer works and is bad OS on my old dog HDD.
Posted on May 23, 2017
  • Anonymous Jun 01, 2017
    btw if XP , it has always love to freeze shutting down, the reason is 2 fold.
    1: XP sux and they all do that.
    2: drivers or other bad programs fail to shut down on command causing XP to go batty.
    XP is junk get rid of it.
    Get a new LT from GOODWILL that has w7 on it.
    and win.
    win7 shuts down.
    w10 is even better, and is even now
    programmable by you to set rules for shut down
    took mS 16 years to remove head from can and do this right,
    on mine , i can check a box,. that says.
    shut down ,no matter what, and set delays.
    but of MS WORD is open , you lose the file or it truncates. your call there.
    and rule 3, all XP are infected and never ever will work right again, due to VIRUS MAGNET status.
    i guess you missed how UK had hospital shut down due to the inane practice of using XP there. and worse , missed the last ever update.
4 Suggested Answers
SOURCE: Compaq laptop
its not charging try any other power adopter....
Posted on Jul 17, 2008
SOURCE: Starting problem
Starting problem Answer hi i have a HP compaq nc6000 laptop, and when i try to start it up all i get is noise of fan... (More) hi i have a HP compaq nc6000 laptop, and when i try to start it up all i get is noise of fan starting up with one glowing orange light next to a lightning bolt like symbol. IWhen I turn ON my laptop first time HP Compaq nc6000, sometimes the orange LED will just light up and nothing happens, sometimes when I get lucky I will be able to goto Windows. when start work properly.
Posted on Feb 05, 2010
boysisiw22
  • 11 Answers
SOURCE: The battery symbol with the lightning bolt is
it is either you need to replace the battery, or better yet try updating BIOS.
Posted on Feb 27, 2010
My hp compaq nc600 laptop wont turn on just an ornage light comes on, black screen and fan for 10 seconds then dies?
In the first instance you need to check your power lead. Exchange it for another one that you know works.
Apr 09, 2013 | HP Compaq nc6000 Notebook
What the solution of laptop hp compaq nc6000 when turn on won't start up
Hit escape as you turn on the pc. Continue hitting the button until the startup screen shows. Also Try Hitting Contol alt delete all at once and hold down until startup screen shows. Be sure you have absolutley no usb ports being used during startup
Nov 13, 2012 | HP Compaq nc6000 Notebook
My HP nc6000 wont start when I press power button. Fan starts for a few seconds an then the orange led turns on, after that everythig turns off. AC an the battery is ok. Any idea? Thak you.
Hi,these particular brand of Hp series is very problematic,try checking the Ram out,its usually underneath the keyboard,so if you have two installed try using one at a time to boot system,if problem persist have an I.T Technician look at it.
Dec 31, 2010 | HP Compaq nc6000 Notebook
Starting problem
Jan 31, 2010 | HP Compaq nc6000 Notebook
Nc6000 compaq power on problem...Blue led button.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Once this problem occurs, and after it shuts itself back down, if you use the palm of your hand and press down gently on the J-K-L area of the keyboard, then press the power on switch, the units powers up normally!!!!!! DO NOT PRESS DOWN HARD!
Sometimes the unit comes on and stays on, sometimes it is very movement sensitive, sometimes it drops power again in short order.
Jun 09, 2009 | HP Compaq nc6000 Notebook
HP Compaq nc6000 wont start up
Hi there.
This could be a problem with the system memory.
Take the battery out and the AC power, turn the laptop over and look for a panel with screws on it, unscrew the panel and you should see something like this >>>>>>>>>
Unclip the memory by pushing the little lugs outwards and the memory should pop up ready to be taken out, get a clean dry paintbrush and clean the memory and the slots.
If you have more than one stick of memory just put one of them back and try booting the laptop up.
If one works try the other and see how you get on.
Post back for any additional help
Good luck and thanks for using FixYa!!
May 26, 2009 | HP Compaq nc6000 Notebook
FLASHING AMBER UNDER LIGHTNING SYMBOL
Is it an amber lightning bolt? (I am assuming thats what you mean by UNDER lightning symbol)
That is the charging symbol for your battery, it means your battery is being charged by your power adapter.
Jan 29, 2009 | Compaq Presario X1000 Notebook
Flashing lightning bolt on Compaq C300
This sounds like a battery problem. The best way to test this is to remove the battery and then power the laptop up with just the power cord plugged in but no battery. If the computer boots then the battery is bad you will need a replacement. Also try letting the battery charge for a day. Be sure that the charging light is coming on when you have it plugged in.
Dec 09, 2008 | Compaq Presario Notebook
HP compaq nc6000 Start up problems
cpu is getting over heated because the fan cooling it is slow or not working well or stopped . go into setup , see the cpu temperature, and fan speed , if normal , neglect the above cause.
change ram , use any other working ram .
battery may not be fully charged , or old battery.
battery faulty (current leakage or less working voltage or less current storage capacity,
use mains supply , if lap top is ok on mains supply then charging section or battery is faulty.
Aug 15, 2008 | HP Compaq nc6000 Notebook
Compaq laptop
Jul 17, 2008 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
393 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
