Question about Garmin GPSMAP 276C GPS Receiver
276C Memory Battery
My 276C has begun to malfunction.
If it is switched off for more than a short period the clock loses time and it forgets it's most recent position. And it requires a cold start, that is it takes maybe 15 minutes to re-establish its current position. At that point it works OK again but I suspect the memory battery is failing.
Thanks in advance,
Graham
  • 2 more comments
  • Aussietraks Jan 09, 2008
    I don't believe this is correct as the GPS has to maintain both time and position information when the main battery is removed or absolutely flat.
    Until recently it did this very well. The GPS is stored with the main battery fully charged.
    See alsohttp://gpsinformation.biz/phpBB2/viewtop...
  • Anonymous Apr 03, 2008
    I'm having the same problem. Was told by Garmin that there is a capacitor that has gone bad in the unit and it will cost $170 to repair
  • stephanversc Dec 13, 2008
    I have the same problem. I've already changed the 3V backup battery but the gps is still mallfunctioning. With the new battery however it finds quicker the satelites.
    What else can cause memory loss ( hour and date ) ???
    Thanks for tips
    Stephan
  • jspringsteen Apr 07, 2009
    Have the exact same problem. Replaced the battery to see if it would solve the problem and it did NOT. Contacted Garmin and all they stated was for me to send the unit in and have them try to fix it for $175...ouch!
    Problem Solver:
  • 6 Answers
There is a button cell soldered to the main circuit board that powers the real-time clock while the unit is off or the main battery is removed or flat. After a couple of years this button cell dies and has to be replaced. I've had this problem twice in five years, and each time replacing the button cell fixes the problem.
Needs a Garmin workshop, or someone who's good with a fine-point soldering iron.
Posted on Dec 21, 2009
I had the same problem. The Real Time Clock slowly started to fail and my unit lost both time and position between uses. Had to return to Garmin at a cost to fix of over $200.00. They could not fix it and sent me a remanufactured unit.
Posted on Jan 30, 2008
  • 174 Answers
Replace the main battery. The main battery is used to provide power for all functions, there isn't a separate battery like in PDA.
Posted on Jan 09, 2008
How to fix the clock of 2015 Mazda3 which loses time
check your fuses, your losing full time power to the clock
Oct 22, 2015 | 2015 Mazda 3
3 log beeps on power on
Gigabyte doesn't list 3 long beeps as an error code, so I'm not sure if you're actually getting 3 short beeps or maybe 1 long and 2 short or... But, for reference, Gigabyte's error code list is as follows (depending on whether you have an AWARD BIOS or an AMI):
(AWARD BIOS)
1 short beep: System normal
2 short beep: CMOS Error
1 long beep and 1 short beep: Memory error
1 long beep and 2 short beep: Graphic card error
1 long beep and 3 short beep: AGP error
1 long beep and 9 short beep: Memory Error
Continuous long beep: Memory not correctly installed
Continuous short beep: Power supply unit failed
(AMI BIOS)
1 short beep: Memory Error
2 short beep: Memory parity check error.
3 short beep: Basic memory 64K address check error
4 short beep: Real Time Clock malfunction .
5 short beep: CPU error
6 short beep: Keyboard error
7 short beep: CPU interruption error
8 short beep: Graphic card error
9 short beep: Memory error
10 short beep: CMOS error
11 short beep: CPU cache memory malfunction
It might not be a lot of help, but it's somewhere to start... and at least this way you'll know what to be listening for.
Nov 30, 2013 | Gigabyte Computers & Internet
I got a chevy equinox 2006 everytime I start it the clock resets to 12? What is the problem?
the clock must supply directly from the battery , if no anytime when you switch on and of the clock come back to 12 and lose the memory.Is not difficult but need time to find the wire from clock and connect to an permanent 12 volt supply somewhere on the board , consumption is very small few miliamps.
May 08, 2011 | Chevrolet Equinox Cars & Trucks
My imac loses its wireless connection, regains it,
Best place to look is ebay as these cards are nolonger made. First try and plug and unplug your card a few times.
May 13, 2010 | Apple Airport Card - Network adapter -...
When i switch off dewalt dco11 radio the station memory is lost
Does the clock lose time too? 2 AA batteries under a door inside the battery compartment. Change them, reset time and stations.
Feb 06, 2010 | Dewalt DC011 AM/FM Radio
Voltage draw on a ford 2003 zx2 when the the car is turned off?
Current draw (not voltage draw) must be nearly zero Micro-amps even with alarm system, clock time keeping, and computer memory support--otherwise the battery would discharge over a fairly short period of time. The higher the Micro-amps, the quicker the battery dies.
Feb 02, 2010 | 2003 Ford ZX2
My 1999 Jeep Grand Cherokee Laredo radiator fan started running continuously. The only way to stop it was to disconnect the battery or remove the fuse. Any ideas what might cause this problem? Tom
There's a thermostatic switch that kicks the fan on and off. It is apparently shorted, causing the fan to run continuously. Check with your local auto parts store -- you be able to replace the switch without having to replace the entire fan assembly. In the meantime, pulling the fuse is a lot better than disconnecting the battery. You won't lose computer memory, clock, stereo memory, etc.
Oct 20, 2009 | 1999 Jeep Grand Cherokee
Minolta Di3510F indicated malfunction error with code COBAO. Can anyone help?
COBAo = Elevate mechanism malfunction.
The exit tray home position sensor is not blocked even after the lapse of a given period of time after the tray has started moving up.
An encoder clock input is not detected within a given period of time during operation of the tray.Check the sensors,motors and his connectors.
How to reset:
1. Press the trouble reset switch on the Tech.Rep.Setting Switches Board to reset the following malfunctions:scanner,fusing,exposure related malfunctions and C3FF.
2. For any other malfunctions open and close the front door or turn OFF and ON the power switch.
Aug 07, 2009 | Minolta Di3510f Bizhub Copier
Eclipse CD8445 Clock Problems
If you lose your preset stations as well, it means that your memory wire (sometimes yellow sometimes red) is not hooked to a constant power source. Get a testlight and find a wire in where the radio is at that has constant power once you find that attach the memory wire.
Nov 17, 2008 | Eclipse 5440
Clock loses time
All memory on the n35 is powered by the n35 - if it goes completely dead, I usually leave it for a few weeks for the battery to completely flatten then check hard reset switch is off and recharge.
Dec 30, 2007 | Acer n35 Pocket PC
Garmin GPSMAP 276C GPS Receiver Logo
1,065 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
