Question about Amana ASD2324HES Stainless Steel Side by Side Refrigerator
The refrigerator side is not getting cold; the freezer side is working well
  • matlock_mich May 11, 2010
    Defrost problem if there is frost or ice on the back of the freezer wall unplug let thaw then take back wall out and check heater and bi-metal a little silver button looking thing that claps to a pipe.
    President:
  • Amana Master
  • 1,922 Answers
You need to replace the main control in the lower rear left side wall of the unit,part3 AP4334000 ,a sure sign of this is if you have recently blown out some lights in the refrigerator and you replace these and they don't light properly and the relay on the control board buzzes,not always,but if so then it is the control board at fault,and board will have a burned spot on the p.c. trace side
Posted on Nov 17, 2009
HVACRH20
  • 237 Answers
SOURCE: refrigerator won't get cold
You likely have a defrost cycle failure. The freezer's cooling coils need to be frosty and cold so the air that the fan pulls over them can cool the fridge section. If the defrost cycle fails, the coils freeze up to a block of ice and air flow suffers (fridge is about 55 degrees F). The freezer stays cold only because there's a block of ice in there now... sometimes that cold "sinks" to the bottom and only the food at the bottom stays frozen (and can even freeze food at the bottom of the fridge compartment while the rest is warm). To be sure, you'll need to take the rear interior panel off the freezer back wall and check the coils to see if they are frozen solid. If they are then there's a defrost cycle failure. If they are showing a nice white frosty pattern evenly all over the coils then that's normal and maybe the evap fan (right above the coils) is not blowing air up properly or is not working at all. That fan should run if the compressor is running, etc. the only time it doesn't run is during an actual defrost cycle. Once you find out what condition the coils are in it should be simple to direct you further on the problem.
Posted on Jan 06, 2007
  • 19 Answers
SOURCE: my freezers works but my refrigerator
make sure all your fans are turning. maybe try to remove the knobs and see if you can turn them without the knobs, possibly they could be stripped.
Posted on Apr 22, 2009
  • 24 Answers
SOURCE: Refrigerator does not get cold - GE side by side
In my GE side-by-side refrigerator (model number GSS20IEMDWW), there is a motor-controlled flapper door between the freezer and fresh food side. Cold air from the freezer side cools the fresh food side when that flapper door is open.
It is located at the top of the fresh food side on the dividing wall between the fresh food side and the freezer. If this is blocked with something (large left-over container, soft drink bottles, etc), it _may_ be enough to prevent sufficient cooling of the fresh food side.
Of course, there may be a more serious problem with the flapper door mechanism or the control unit that signals the flapper door to open/close.
The vegetable and deli drawers may have a small opening (manually controlled with a wheel or a slider of some sort) that connects those drawers to the freezer side, thus explaining how those areas are still functioning as expected.
Posted on Jul 28, 2009
garing
  • 998 Answers
SOURCE: Freezer Working Frig not getting cold enough at max setting
unplug 24 hrs with doors open plug in again if it works better you have a defrost problem. it may be the defrost termination switch.. burned out element or bad timer
Posted on Aug 03, 2009
heatman101
  • 43501 Answers
SOURCE: refrigerator and freezer not getting cold side by side
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 25, 2010
Whirlpool refrigerator is not getting cold but the freezer is. The freezer is located below the refrigerator.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 23, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator section not cold, freezer cold and working
heatman101
Feb 19, 2011 | Maytag Ice2O 19.8 Cu. Ft. Side-by-Side...
Freezer works good but food side doesnt get cold and fan in freezer runs all the time
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Jan 27, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My double sided refrigerator/freezer is not getting cold on the refrigerator side but the freezer side is working fine.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Oct 11, 2010 | Refrigerators
Refridgerator side is getting warm
the refrigerator side of most modern day units only gets cold by cold air being blown over from the freezer side so check the fan in the freezer to make sure it is working as well as check the damper that opens and closes to let cold air over to the refrigerator side
Apr 05, 2010 | KitchenAid KSCS25FKSS Side by Side...
The freezer is working OK but the refrigerator is not getting col
you have leakeage on pipes(smal hole) in short time and the freezer wil not getting cold.call specialized service, they must have a good welder.
Feb 15, 2010 | Frigidaire FRS3R5EMB Side by Side...
Freezer side of 690 does not work (not even cool); refrigerator side works just fine.
Check the fan in the freezer department. It has to run when the door i closed. Sometimes the door switch is bad. This causes the freezer coils to ice up so the cold air does not go through the coil to cool the freezer. Unplug the power cord for 1 hour or two hours. Then plug the cord in and see if the freezer gets cold.
May 15, 2009 | Sub-Zero 690 Side by Side Refrigerator
My freezers works but my refrigerator
Apr 22, 2009 | KitchenAid Superba KSRG25FK Side by Side...
REFRIGERATOR SIDE DOES NOT GET COLD
hi. did you check to see if the fan in the freezer is working. check to see if any frost build up on freezer wall.check those thanks
Oct 06, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
REFRIGERATOR SIDE NOT GETTING THAT COLD
they are junk so many problems with mine . when down 4 times
just 2 years old.
Sep 30, 2008 | Samsung RS2534 Side by Side Refrigerator
Amana ASD2324HES Stainless Steel Side by Side Refrigerator Logo
122 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
