Question about JVC DR-MV1S DVD Recorder/VCR
My unit (just all of a sudden) will not turn on by
My JVC DR-MV5SU (just all of a sudden) will not turn on by either by the power buttons on the front of the deck or by the remote control (I have checked the batteries and they checked out excellent). It worked fine the last time we used it. Now I see two led lights flashing at the top of the display under where it says VHS and where it says DVD. I have checked the fuse inside and it tested out good. Can you tell me what might be causing this problem? Or is there a repair manual available for this unit?
  • 456 Answers
Check the power supply and all the capacitors throughout the unit, i have found that this is normally the case when an item will not power on and is displaying red LEDS. Good Luck.
Posted on Nov 15, 2009
Testimonial: "Thanks for the prompt reply. I do not have the necessary equipment for testing my JVC DR-MV5SU. Is it wworth having repaired? "
  • Adam Jerome_lagudi
    Adam Jerome_lagudi Nov 15, 2009
    If you can find a technician he can check the voltages from the power supply, other wise get a volt meter (or a multi meter) and im sure an online guide will be available on the net. Hope this helps.
How do you Reset JVC DR-MV100 DVD Recorder/VCR Combo?
First press and hold the (Stop) button first and then press& hold the (Standby/On) Button until you see *RESET* flashing on & off on the display, hold both buttons in until the unit shuts down.
Nov 12, 2012 | JVC DR-MV1S DVD Recorder/VCR
My JVC DR-MV150B plays prerecorded VHS tapes fine.
Try opening the front hatch of the tape by pressing the small, square button on the right or left (short) side of the tape. Check the black tape inside for any marks, dirt, scratches, tears, etc. If the tape is fine then your unit needs to be cleaned with a tape cleaner available at any electronics specialty or retail store. Good luck to you!
Jan 02, 2010 | JVC DR-MV150B DVD Recorder/VCR
Cannot eject DVD or turn off machine or anything
hold your power button down for 8 seconds and the machine will power down
Feb 19, 2009 | JVC DR-MV5S DVD Recorder/VCR
Can't get DVD/VHS player to work.
This is a link to JVC's download for the DR-MV5SU (you typed MVSSU, which I'm guessing is just a typo):
http://resources.jvc.com/Resources/00/00/94/LPT1032-001B.pdf
Dec 11, 2008 | Audio Players & Recorders
Power failure in Jvc camcoder (dr-dv800)
There are protection fuses inside the unit to protect the electronics. This is not a repair for a novice. Bring the unit to an authorized JVC repair center. The parts cost should be around $5. Add in the local repair rate for the total cost.
Dan
Apr 30, 2008 | JVC Everio GZ-MG21 Camcorder
Toshiba Hdd/Dvd video recorder. Moved unit to a static caravan,comes on ok but when using the remote to use it ,no matter what button I press I get the message 1. DR-OFF Can you please help ?
Hold both the channel up and down buttons on the front of the recorder for 3 secs until DR1 shows in the display. Try it and let me know if it worked..
Apr 16, 2008 | Televison & Video
Loading... jvc dr mh30
Commonly this is cause by leaky capacitors in the secondry of the power supply SMPS ASSY.The PCB is located in the back right hand side of the unit.A visual inspection for any bulging of the capacitors will confirm this.
If you cannot change the capacitors yourself I suggest you take the unit to your local service center.
Nov 18, 2007 | JVC DR-MH30S DVD Recorder
DVD displys "loading" constantly
First of all if it is still under warranty take it back and exchange it or have them look at it. As far as it not wanting to turn off you can search for a reset button on the back of the unit. Reset it. Or if no reset button just unplug it and plug it back in. See if that helps. As far as being jammed. Unplug the unit. Very carefully take the unit apart. See if anything has been accidentally placed in the unit when a dvd was pushed in at the same time. I have experienced this before cause I have little kids. Things happen. Now there again by taking it apart could void any warranty you may have. Also something in the unit could also shorted a circuit out causing it to not turn off.
Sep 18, 2006 | JVC DR-MV1S DVD Recorder/VCR
JVC DR-MV1S DVD Recorder/VCR Logo
562 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
