Question about Frigidaire FEQ1442ES Electric Dryer
Dryer starts, tumbles once and shuts off? - Frigidaire FEQ1442ES Electric Dryer
  • Gr8Things May 11, 2010
    Is this on timed-dry or on automatic dry?
I had the same issue. Make an attachment for your vacuum cleaner that can fit in the space where the lint-filter goes. Unscrew the screen and vacuum deeply and thoroughly (use a long screwdriver to loosen stuck-on lint in the bottom). Next, Open up the bottom panel (it's easy- just two screws) and vacuum out all that lint, too. FINALLY- release the exhaust system (usually a coil connected to an outside wall) and shake all the obstructions loose and discard the lint. Turn on the dryer with it disconnected and let the air push more lint out. Hope this helps
Posted on Dec 20, 2009
Dryer that wont stop tumbling
Well we know the door switch is functioning properly so that usually just leave a timer issue.
Dec 05, 2014 | Dryers
Dryer is tumbling but no heat - when I reset it shuts off after about 10 min and the Drying, Cool Down, and Extended Tumble lights are all flashing.
Janet McDonald,
I understand that you are having trouble with your dryer not heating and not running a full cycle and shutting off with the Drying, Cool Down, and Extended Tumble lights flashing. What I suggest is to give your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back and try to start a cycle. If it does not complete the cycle and shuts off with the lights flashing, I suggest to either contact the manufacturer or a local appliance technician. This way you will be able to locate the cause of this issue and have it resolved.
-Best Regards-
Jan 14, 2014 | Frigidaire AEQ6700FE Affinity Electric...
Bosch WTE84122BY Condenser Tumble Dryer dosen't starts
Did you check the res to see if it was full? Might be clothes inside the door and it aint shut all the way? never even seen a condenser dryer.
I have the model service manual though HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 11, 2013 | Bosch Axxis WTA4400 Dryers
Lg tromm DLE5977 won't start the tumble
Sounds like loose belt. If the drum spins by hand, it's almost guaranteed to be a bad belt.
Nov 27, 2013 | LG DLE5932W Electric Dryer
My servis M2002 tumble dryer will only turn after being manually started off then shutting the door quickly. It will then stop and hum when it trys to go in reverse. Any ideas what it could be?
I would say motor but here is a website to help:
drum roller/glides, idler assembly:http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Dec 11, 2010 | Dryers
I have a tumble dryer.
Sounds as if the door switch is the problem. This is normally a safety switch that stops the dryer when the door is opened.
Unplug the dryer.
Remove the door switch and check the switch condition with a continuity meter after removing the wires. Try turning the switch on and off....the meter should read power on and off when you do that.
You may have to remove the front of the dryer to get to the door switch.
Good luck,
I hope this helps
Oct 05, 2009 | Hotpoint Dryers
The dryer heats but will not tumble. I am
if the belt was broken, the safety switch would shut off the machine. the belt is probably slipping, stretched from age. replace belt
Jul 09, 2009 | Frigidaire FGX831C Top Load Stacked Washer...
Frigidaire FEQ1442ES Electric Dryer Logo
136 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
