Question about Canon PIXMA MP150 All-In-One InkJet Printer
E5 error code on canon pixma mp150
Like the title suggested i get this message from my printer and to top up the scanner doesn't work either, it starts to think like scanning the document but then at the end nothing happens. Anyone have any suggestions ? I know the error message but i don't understand why the scanner doesn't work, as i assume it's separated from printer.
Thank you in advance
Stelian
  • Anonymous Dec 16, 2008
    same case for me!
  • Christrick Jan 09, 2009
    E-5 problems on my priner
  • 45 Answers
I had run into a similar problem with my all-in-one and had to use
http://www.irfanview.com/ (which is free) to scan with
Open irfanview and select File>Acquire Batch Scanning
Posted on Jan 09, 2008
Canon MP340 won't scan
The printer "black ink low" message has nothing to do with scanning. You don't have to disable the ink monitoring or do anything else with printer - to scan!
The printer is" waiting" for you to CLOSE a "Paper port 11" dialog box on your PC screen. If the dialog box is not open, check the task bar (bottom of screen) for anything with "MX340" in title, click on it then close it.
good luck
Lumir
www.inkbank.com.au
Mar 09, 2014 | Canon PIXMA MP240 All-In-One InkJet...
Im trying to scan a document but its saying error code 2106. i have it hooked up through wireless
Try these things:
1. place a doc to scan in the scanner. Close the lid and hit MENU, COPY document, START.
If that doesn't work you'll need to contact kodak. If it does then try this next:
2. Check for ADMINISTRATOR rights.
  1. RIGHT CLICK on the kodak icon and select Properties > Compatibility tab > Run this program as an administrator
  2. Select RUN AS ADMINISTRATOR
  3. click APPLY
  4. click OK
Then try scanning again. If it still doesn't work then-
Reload the driver:
  1. select Start > Run.
  2. Type %windir%, then click OK.
  3. Double-click twain_32.
  4. Right-click Kodak, then select Delete.
  5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to (cd drive: > printer > scanner.
    Double-click aioscannr.msi, then follow the instructions to remove it
  6. Then go to cd drive: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
  7. Open Home Center Software
  8. Select Scan Documents and Pictures.
  9. Scan a document
If it still doesn't work then you'll need to take it in for service.
Jun 15, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
How do you scan an image onto the computer using the Canon MP190 series? Ive tried hitting scan and it only tried to copy the image and print onto paper.
Place the paper you wish to scan on top of scanner.
1. Go to window start manu.
2. Find picture board.
3. Click the file manu at picture board, and find the scanner.
4. Click the scanner and it will scan the paper as soon as you click ok...
5. After completion of scan, click "save as" and name the title wish to make.
That's all...
Apr 21, 2011 | Canon PIXMA MP190 All-In-One InkJet...
Can't scan- Refer to device documentation to
Try using widows paint. Look in windows accessories off the start program menu. If you open windows paint, look for open file from "Scanner or Camera". Most likely you can get the scanner to work again in Vista. Otherwise...try Vuescan scanner software. I think you can get a free trial period online and it should also work. You'll have to pay for that if you like it.
May 19, 2010 | HP OfficeJet 6310 All-in-One Printer...
HP 6110 All In One Scanner & Printer
i dont have the scanner icon for HP. I loaded the drivers, but the scanner doesnt show up on the control panel.
How do I set up the scanner?
Aug 12, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Scanner not working
Hi Jkey !
As per the information you have provided, I understand that you are receiving an error "No scan option refer to the documentation" on the printer, when you try to print from the front panel of the printer (I mean from the printer's side).
However, plz provide me the proper error message so that I can assist you in the best possible way. If you are unable to scan from the printer's side, then try to scan from the computer and check if it is working or not. It should work when you try to scan from the computer, if not there may be a communication issue between the two devices.
To check the communication perform the below steps:
IF the printer is connected via USB cable, then perform below steps:
Useful scripts For Windows XP:
To isolate the issue I suggest you to try scanning from the Windows Image acquisition(WIA) wizard on the computer.
Follow the below steps to Scan using WIA
1.Verify that the all-in-one product power is turned on and the printer cable is properly connected.
2.Click Start then Click All Programs then Click Accessories then Click Scanner and Camera Wizard.
3.Follow the Scanner and Camera Wizard instructions to scan images to the computer.
If you are able to scan fine using the above steps, please write back to me along with the exact error message.
With Regards
Mike.
Jun 27, 2009 | HP Photosmart 2575 All-In-One Printer,...
Hp 3380 scanner issue
I SUGGEST DELEATING SCANNER FROM YOUR SYSTEM AND RELOADING THE SCANNER DRIVER FROM THE INSTALL DISC THAT CAME WITH YOUR SCANNER
Feb 02, 2008 | HP LaserJet 3380 All-In-One Printer
Error message: cannot detect scanning device
This worked for me:
Go to http://welcome.solutions.brother.com/ , navigate to Error message for your scanner model. The patch on this page worked for me
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000100/000082/faq000182_001.html?reg=us&c=us&lang=en&prod=mfc7220_us_as&Cat=
I notice there are several other patches as well, which may be appropriate for your specific issue. I have my mfc-7820n networked at home, at first none of my 4 computers could scan, now 3 of 4 can. I am hoping that one of the other patches will help.
Dec 02, 2007 | Office Equipment & Supplies
?Scanner failure? error message
Usually this type of error message pops up when the scanner lamp isn?t warming up properly. This is what you should do: 1. Check if the lamp is on. 2. Unplug the scanner?s power supply and plug it back in. Try connecting it diretly to the wall. 3. If that doesn?t work: a. Unplug the unit?s power supply. b. Press ?cancel? and left arrow while reconnecting the unit. c. Release the buttons when the printer starts up. 4. Try scanning again. 5. If it doesn?t work, have it serviced.
Feb 22, 2006 | HP PSC 750 All-In-One InkJet Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
315 people viewed this question
old marine
old marine
