Horizontal lines in the top
Toshiba 27a35C
Few inches from the top have horizontal lines, which seem to fold the image back if there is some activity in that area of the screen.
I opened the TV and tried to adjust controls with screws. One control (probably horizontal hold) shrinks the screen vertically, but not too much. Anyway, that didnt helped.
I also read on some forum that this is proabably just some shorted capacitor, without further details. If someone can locate that capacitor for me, I can replace it.
Thanks for reading it anyways!
  • 34 Answers
CAUTION!!!!
you should never fix the inside of the tv unless you are a professionel tv repair man
there is High voltage and the only thing you should to is get a new tv set.
Posted on Nov 16, 2009
Horizontal lines on SONY TV
the ribbon flat connection tapes that connect the led panel driver to the panel have prob delaminated
this cant be repaired easily and you would need to replace the panel
Dec 05, 2014 | Sony KDL40EX520 Bravia KDL-40EX520 40 Inch...
Toshiba CZ32V61 no picture
1) you have problem with the Raster
2) the main causes are a) raster b) picture c) sound d) synch
3) since this are not video, the problem is raster. your must
test the voltage from section horizontal out +125vdc+vertical output +80v+all other circuit +12vdc
4) test the power supply for defective. see the diagram attached
Jul 12, 2012 | Toshiba CZ32V61 32" TV
Toshiba 32A50 The horizontal scan lines seem to roll off the top of the screen and fold back down like the guns don't know where the top of the tube is anymore, just started about two months ago. Any...
There are 2 or 3 filter capacitors found near the vertical IC on the printed circuit board. One of them is likely defective. It would be a relatively inexpensive repair at a repair shop. The filters cost $1 each at most.
Jan 04, 2011 | Toshiba 32A50 32" TV
I've had my Toshiba 46RV530U less than 2 years,
Diana, did you ever find a solution? My Toshiba (same model) is about 2 years old and it started getting these 4 horizontal lines spaced pretty far apart and a double image at bottom. When I lightly tap the top of the TV, they went away. But now that is not working. Please let me know. Thanks.
Jeff
May 15, 2010 | Toshiba REGZA 46RV530U LCD TV
36 Inch Toshiba - Single Bright Horizontal Line
You're losing your horizontal voltage that drives the fly back transformer. Poking around inside can be hazardous to your health since you have to worry about high voltages present on the picture tube even when the TV is off. You may still be able to get parts for those old TV's but they may hard to find. You can try here, but if you have no background in TV repair, it will be pointless.
TV Parts Universal TV Stands DLP Chips ShopJimmy
Mar 20, 2017 | Toshiba CZ36T31 36" TV
Toshiba 27
you just say horizontal lines / and across a top of your television.I expect your trouble is the vertical line of your television . sound ok? try trouble the vertical section the check the resistor?
Apr 19, 2008 | Televison & Video
Toshiba TV CX2789K Horizontal Line
Failure in the vertical deflection amplifier section. This is usualy from failed components, and sometimes cold solder connections. Most of the time, I found bad capacitors, and sometimes the output IC or transistors (depending on the model type) that have failed.
Take the set to a service center for an estimate. You may find it more feasible to buy a new set depending on the parts that failed and the time involved to do the work.
Jerry G.
Apr 14, 2008 | Televison & Video
Toshiba colorstream 27A33 TV
1.Are these lines only in the upper 1/3 rd portion of the screen?And is there a clear demarcation between this area and the lower portionb, where the image is perfect? 2.Or is thin Horizontal lines evenly spaced around an centimetre apart? If it is the first case, then there si a problem with your TVs SMPS. It is not generating the required regulated 110V required for the TVs functioning. If it is case 2, then there is a simple adjustment at the back - 'SCREEN'. This adjusts the Screen Grid Voltage, and by slightly lowering it, this problem will go away.
Sep 05, 2006 | Toshiba 27A30 27" TV
Televison & Video Logo
125 people viewed this question
Top Televison & Video Experts
Electro Med Services...
