Question about Nintendo Wii Console
Wii problem when i press the on button the light dosen't turn green do you know how to fix it?
  • 4,402 Answers
First thing to try is unplug it from the wall and the back, then try it again.
Posted on Jan 09, 2008
Wii has no power whatsoever going in
The button has to be pressed until you see the light come on try using the wimote power button on the upper left corner hold it until you see the light if its yellow its in standby if its green its on you should see the disk entry area turn blue a sec when it comes on. Then it should be green on the power light if no lights in just a couple or 3 seconds holding it down you may have 2 bad wii's in a row. If you take it back ask them if they have a test model on the floor and tell them to show you exactly how it works to power on and off.
Dec 02, 2011 | Nintendo Wii Console
I plug my wii in and the red power light comes on but when i press the power button to turn it on the lights go green and shut off right away. the lights around the disc slot and the power light. Can i fix...
hey there arobw7
This problem is very common with the WII but don't worry there are many websites out there that can help with this problem.
I personally reccommend this one as it has been very successful for me and many others.
I know this can help your situation
Good luck
Sep 20, 2011 | Nintendo Wii Console
I can't turn on the Wii. The red light is always on and when I press the power button (or even the eject button) the blue light is flashing (Only when I press those buttons). I tried the solution of...
Try pressing the power button down and holding it for a few seconds and see if your WII comes back to life. When I first got my Wii I would hold down the button just long enough for it to turn green. This seems like a standby mode. To get my Wii to turn off completly I needed to hold down
the button until it turned red and when restarting the WII I held doen the button until the Wii started back up.
May 10, 2011 | Nintendo Wii Console
After pressing the red sync button on the console for about 10-15 seconds, and syncronizing the remote, the remote stars to work, but when I start a game the remote is no longer working. Then when I...
There are two ways to sync the Wii remote with the Wii console after pressing the red sync button like you did:
1) Press the "1" and "2" buttons on the Wii remote until the lights begin to flash. This method provides a temporary connection to the Wii.
2) Open the battery cover on the Wii remote and press the red button next to the batteries. This creates a permanent connection or "pair" between the Wii remote and the Wii console.
Based on your description, it sounds like you are using method #1. In order to power on the Wii when the Wii's red light is on (meaning the machine is turned off) and start playing games like you want, method #2 must be used.
Imagine method #1 as "guest mode". If a friend comes over with their Wii remote and wants to play a game, you would open up the game first, use method #1, and your friend would temporarily be connected to the Wii. Using method #1 is like "owner mode" that lets the Wii remote turn the console on and off and always stay connected to it.
Hope this helps!
Mar 10, 2011 | Nintendo Wii Console
My Wii has a red light when plugged in, and a green one while turned, on, the problem is, nothing is displayed on the tv or heard, also, the disk drive whirrs for a few second after turning on. The tv...
If the light is red, it means WiiConnect24 is turned off. Green means the system is turned on and it's normal for the Wii to whirr a bit when it's initially turned on.
Completely power down your system by pressing the power button for 10 seconds. If that doesn't work, unplug the AC Adapter from the Wii for a moment, then plug it back in.
That said, Nintendo recommends calling them if this doesn't fix your problem. Hope this helps.
Jan 06, 2011 | Nintendo Wii Console
My wii works but my controler dosent show up on the screen but the buttons work i need help
I don't know about the Wii but I know what happens with the light on the Wii
Green - The Wii Console is on
Yellow - You are connected to Wiiconnect24. It's harsh not to keep the "Yellow" light on because it could overheat the Wii Console. So if it's "Yellow", put your finger on the "Power" Button and keep it there for a long time. When you push it, it will start with Yellow then turn to Green then keep the finger there for a while then will turn to Red
Red - The Wii Console is off
Blue - You are connected to Wiiconnect24. When it turns Blue, It means you are getting a message from the Wii Console or on Standby Mode
Feb 06, 2010 | Nintendo Wii Console
is this via the remote or on the machine if remote change the batteries if machine there will be a small connection from the button to the circut switch that may be broken its just a small plastic button but a sod to fix by hand as you need to dismantal but i hope that helps
May 29, 2009 | Nintendo Wii Console
My wii is not working
If it's orange that means it is turned off. It turns green when you turn it on. Insert a disc, press the power button or hit eject.
Aug 03, 2008 | Nintendo Wii Console
Nintendo Wii console gets a black screen when switched on
not to be mean but buying a modded anything usually voids the warranty.
Not having anything to go off of regarding the mod means that we don't know if it's a faulty weld on the board or anything like that.
Try doing a system reset (if there is a reset button) and see if that works
Jun 08, 2008 | Nintendo Wii Console
Power is on but screen is black
I found this [temporary] solution at
(via email, thanks Steven) This happened to me once, but I fixed it. Here is how:
Eject the disk
Unplug the wii at the back
Wait 1 minute
Plug it back in
Turn it on from the remote
Press reset if it does not show up
Hold the power button to shut it off
Turn it on once more.
I don't know how, but it seemed to work for me. The problem happened when I was trying to load the Mii channel. Hope this helps !
(via email, thanks Andrew)
The first time I shut down my Wii, the light went orange (as it should). When I turned on the power with my wii remote the next day, the wii\'s light turned green but the screen was black.
The treatment was the same as from Black Screen, No Connection: Unplug the Wii\'s power supply unit, then replug; turn system on with wii remote.
The difference is: this problem can strike in more places than just by loading the Mii Channel. Also, I think the green light being on (yet there being a black screen) is a common symptom as well.
May 18, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
24 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
