Question about Sony Playstation 3 (PS3) Console
Playstation 3 I have a westinghouse 42" lcd tv,,my ps3 will not play with my hd cables,,,but will in rca
  • 182 Answers
When you turn the ps3 on with hd cable connected to tv hold down the power button for 10 seconds and it will run the optimal viewing settings screen. hope this helps
Posted on Jan 11, 2008
6ya staff
SOURCE:
I am having issues with my RCA Scenium D52W135D (playstation 3 connection). Recently, I have been having a very specific problem with this combo. I have it connected using HDMI to a Pioneer receiver...
Had the same problem. With mine the other day you probably moved your Playstation 3 too another tv and set your 1080i,720,480 to high deaf on settings in Playstation. You have to change them back to automatic that TV says HDTV but it only plays Playstation 3 on 480 checked in settings of Playstation. Played mine for 4 years on that TV moved and got a 3d wifi then dad got him one And was going to trash that RCA but I told him I would take it for now too keep from buying another TV at this time got it in my new home wouldn't play video but it. would sound tried different cables but still now change. But remembered i changed all of my settings over when I got 3D TV. Playstation 3 hadn't been on know other TV. Since I owned it but that RCA now won't work then came to me last night and playing it on both TVs but you have to change the settings on it before moving it or you cant see the screen to fix it do that guarantee it will fix it. Like you said everything else works PS 1,PS 2,DVD, cable,but PS 3 won't its the settings in theme,and audio.
Nov 10, 2012 | RCA D52W135D 52 in. TV/DVD Combo
Hitachi lcd tv tune in to playstation
Intenta conectar primero el PS3 a la LCDTV por medio de las entradas RCA, en la parte trasera de la TV, con el cable de conexion que viene con el PS3, si aun no obtiene video, intente conectar, de la misma manera, el PS3 a otra TV sin capacidad HDMI. Asi se decarta la posibilidad de fallo en cable HDMI, en LCDTV o de generacion de video del PS3.
Feb 27, 2012 | Hitachi LE42S704 42 LCD TV
My Westinghouse 32 does not play sounds for my video games for my PS3
Your signal board is bad and will need replacement. If you open up your tv and look at the signal board you can get a part number so that you can order one.
You can get get parts for this tv at www.interliquidparts.com
Nov 18, 2011 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
My playstation 3 will not play in 1080p. It used to work, but when we switched cables, it wont work in HD.
When you switched cables, you mean you changed the cord running from the PS3 to the TV? HD content requires an HDMI connection from the PS3 to the TV. It is possible that when you changed cables, you replaced the PS3's HDMI cable with Component Cables which can only deliver in Standard Definition and not in High Definition (720p, 1080i and 1080p).
HDMI:
http://www.playstation3hdmicable.com/images/hdmi2.jpg
Component: http://www.componentcable.net/images/Component%20Cable%20PS3.jpg
Apr 29, 2011 | Sony Playstation 3 (PS3) Console
For some reason we cannot connect our playstation 3 to this television using the hdmi cable.
Connect the HDMI cable to the playstation 3 and LG TV.
Press the input button on your LG remote until you see the new HDMI connection.
If there is no picture, Hold the power button on your PS3 until you see lights flahing on the console, this will reset the playstation to default., as it may be set for a RCA signal, thus no pictue through HDMI.
Feb 07, 2011 | LG 42LC2D 42 in. LCD HDTV
Im trying to connect my playstation 3 to my 42 inch LG lcd tv
When connecting the ps3 to a nice TV like that, you want to use an HDMI cable. You can use the stock red white and yellow plugs to connect to the back of the TV, however you will not get the full HD experience like with the HDMI cable.
Dec 25, 2010 | LG Televison & Video
How do you hook up a playstation to my vizio tv
depending on the age of your play station you may or may not have an hdmi output on the playstation. if youi do then its simple. one hdmi cable from the tv to the playstation and yoiur done. if not, you should have some round color coded plugs on the back of the tv and the same ones at the playstation. they should be just larger than a pencil eraser. these are called RCA plugs or phono plugs. the cables will have the opposite end with pin sticking out. you can go to google images and type rca plug to see a picture.
Dec 24, 2010 | LG 42LC2D 42 in. LCD HDTV
I am trying to commect to my PS3 to an LG LCD tv which supports 1080P (Full HD). but as the game starts and when i check the TV it says 720P although the game and the TV both supports full HD. Do i need...
Hello there. There's a few possibilities. First, the obvious, do you have it set to 1080P in the Display Settings options? Secondly, are you using an HDMI cable? You need to be using HDMI to play games in full 1080P. I use the component cables (The red, green and blue ones) for my PS3 and when I'm on the XMB (that's the PS's desktop so to speak) it's displayed in 1080P but games will not play in 1080P, only 720P. Any old HDMI cable will do the trick, so don't get suckered by the price if you are going to pick up a cable!
Nov 12, 2010 | Sony Playstation 3 (PS3) Console
PS3 wont go 1080i/720p
I don't think there is a way to set your resolution manually, bro. They do it all by auto. If I may make a suggestion... Turn off both the TV & PS3. Unplug your HDMI, then make sure both your TV & PS3 are turned ON. Now re-connect your HDMI. A TV tech once told me that these units "communicate" through the HDMI. This can only occure whilst they're up & running. This may help get you going on to 1080i.
p.s. PS3 games only output 720p, max! This isn't always the case for Blu Ray movies, but it is for games. Good luck!
May 23, 2009 | Sony PlayStation® 3 (60 GB) Console
Playstation 3
What tv do you have:
lcd full hd or hd ready
plasma full hd or hd ready
normal tv pal analog 60 hz
Jun 26, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
