Question about Ovens
I have a Whirlpool LLR6233AW0 top loading washing machine. The cycles of the machine no longer match the dial settings on the control panel. One doesn't know where to start it on the dial, how long it will go, etc? Is this a common problem?
  • 77 Answers
Take the knob off and theres a ring that indicates where the machine is in its cycle thats striped out.Replace and done!!
Posted on Nov 16, 2009
Tip
Related: F2 E6 on Whirlpool RBD305PDS14 double oven - blank display
Equipment is Whirlpool double oven RBD305PDS14 built-in.  After a very stormy summer 2007, I thought a power surge may have zapped the control board.  Problem initially presented on display as error & fault "E6 F2"; simply pressing "Timer Off" would usually clear this error & fault code.
However, some months later, the display would often go completely blank followed by the beep sequence "short-long-short-short-short" (Morse code: dit dah dit dit dit).  No error & fault code would appear.  Pressing any keypad oven control did not work at all in this condition.  When power was cycled at the breaker panel, the usual "PF" with clock display did not appear.
[TURN OVEN POWER OFF AT BREAKER!!!]
After following the excellent information on "how to remove the control panel" posted in this forum, I first tested the "control panel thermal fuse" (refer to the tech sheet that should be behind the control panel once it is removed).  It showed a closed circuit.
I turned my attention to the "flexible" keypad connector cable (error & fault code "E6 F2" is a keypad or keypad connector problem; again, refer to tech sheet).  The control panel has a board mounted female connector with two tabs that may be gently pulled upward to release the flexible cable.
I cleaned the flexible cable contact area (it seats into the board mounted female connector) carefully with a Q tip and some isopropyl alcohol.  I reinserted the flexible cable and gently pressed down on the two tabs (noted above) on the board mounted female connector.  VERY GENTLY tug on the flexible cable to insure it is gripped by the connector.
After all of this monkey business, I re-mounted the control panel display panel on the oven and restored power.  So far, so good.  After applying power, the "PF" with clock display always appears.  I am able to set the clock and press "Start".  Over functions normally.  The clock displays as normal and I no longer observe the problem I described above.
BTW, I noted the incoming 240V has transient suppression (no surge protection, however).
on Oct 21, 2007 | Whirlpool RBS245PDS Electric Single Oven
Had set my Magic Chef oven on self-cleaning mode and about 30 minutes into the cleaning cycle there was a pop and a flash. I suppose something has shorted out because the controls are no longer working. Is...
Yes the oven is able to be repaired depending on what popped. You will need to get at the control panel which is located at the top of the oven behind the burners. You may have to remove the rear panel to gain access. Also you can follow the outlet plug to the transformer. IT sounds like you lost a fuse. If the fuse blew on the control board, then you will need to look for a short somewhere, if it blew at the transformer, then you just need to replace the fuse
Jan 11, 2010 | Ovens
I need an owner manuel for Caloric Range Model # EST 345 I can'g figure out how to run the self cleaning oven cycle.
you might try the following, although it is the instructions for an old model, it may be relevant;
"The actual self-cleaning process is initiated by a simple 5 step procedure: 1. Set the range clock to time of day. Note: on models not equipped with an automatic oven timer, the self-cleaning cycle is preprogrammed for a 21/2 hour cycle. Use Steps 3, 4 and 5 only. 2.Establish the length of cleaning time by:
A. Setting the start time. Press and turn the start dial of the automatic oven timer clockwise to the desired starting time. B. Set the stop time. Press and turn the stop dial of the automatic oven timer clockwise to the desired stop time. Max time is 3 hours miniumum 1/12 hours. 3. Set the oven selector dial on the control panel to "Clean" 4. Set the temperature control dial to "off". If you temperature control dial has a "Clean" position, then set the dial to "Clean" instead of "Off". 5. Remove oven racks, broiler pan and broiler grid from lower oven. Close and lock the oven door by moving the latch lever as far right as it will go - into the locked position. If the lever is accidently dislodged restore it to the locked position. Otherwise, the self-cleaning process will not take place. Shortly after the cleaning cycle has begun, the oven temperatur reaches a degree in excess of the normal broiling temperature. The red "Clean" light will come on and the clean cycle will start. In a few minutes the door lock lever, which you have placed in the locked position, will automatically be secured to prevent the oven door from beging opened during the cleaning cycle. This latch remains locked until the clean cycle is complete and the oven temperature reduces to normal baking and broiling temperaturs. NOTE: Prior to self cleaning cycle operation, the oven and surface lights must be turned offed. The upper oven can be used."
I found this here; http://www.appliance411.com/archive/21155_caloric_oven_lost_cleaning_manual.shtml
Nov 18, 2009 | Ovens
Whirlpool Oven Died During Cleaning Cycle No Display Now Locked
Had same problem with my KitchenAid. 10 years old. Ran self cleaning cycle, oven died!!!! Called repair. Appears to be thermal fuse. Part on order. Microcomputer had some brown spots on it. Tey wanted us to replace it too. But will wait to see if fuse is problem. Repair - $150 vs. $570. If it's the higher price, we'll buy a new oven before putting that kind of money into it. Will NEVER run a clean cycle again even if I have to buy a new oven.
Jul 16, 2009 | Whirlpool RBS275PD Electric Single Oven
How to remove the control panel on Whirlpool double oven Model RBD305PDS14
Remove the doors by turning toward you a little toggle apparatus located on each hinge. Locate a small screw on the lower inside edge of the left and right hand trim and then slide off the trim. Remove the lower trim then raise the upper trip and put the left end of the panel inside the top opening. This allows you access to the control panel. Test both the keypad part #8300440 and the control panel part #830219 to see which one needs to be replaced. Order the replacement part, plug it in, reverse the precess above and it should work like new..
Oct 02, 2008 | Whirlpool RBD305PDS Electric Double Oven
Self-Cleaning Cycle Caused Top oven to stop working
I removed the side trim panels, then the control panel. the wiring diagram was behind the control panel.
Sep 03, 2008 | Whirlpool RBD306PD Electric Double Oven
Oven temperature
switch part of the stat mounts behind the front panel in the position of the temperature control knob. there is a capilliary tube coming out of the stat and the bulb at the end of this mounts in the oven.
Jun 24, 2008 | Ovens
Older Whirlpool RB170PBX both ovens out
these ovens have a fuse in them called a tco thermal cut out switch if the ovens over heat for a varity of reasons it cuts the power and must be replaced most are on the back of the ovens and are metel disc with two wires on them
Jan 31, 2008 | Whirlpool RBD305PD Electric Double Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
