Question about Kenmore Washing Machines
Rubbing noise from agitator in top load kenmore washing machine
Top loading Kenmore washing machine (Model 110 064518527) agitator makes noise when spinning. Sounds like agitator is rubbing. Any suggestions on how to repair?
Thanks.
    President:
  • 1,937 Answers
I can't find your model number on the Sears Parts Site:
http://www.searspartsdirect.com/partsdirect/index.action
However.
If this is a basic top load, direct drive, Neutral Drain washer, the problem could point to the transmission "Agitate Cams".
See the following Whirlpool / Kenmore Service Manual for these washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The agitate cams are used to raise the agitate gear above the connecting rack during the spin cycle.
Following is a Whirlpool parts list for commercial versions of these washers although the consumer model uses the same part numbers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
See part # 62580 (About $15.00)
I had the same problem with gear grinding and this solved it.
See the following for how to pull the transmission. You don't have to remove the tub!!
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=962131af4fd992034867327e32162166
Pull the transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
It sounds like a complicated job but it really isn't and certainly less expensive that a $170 transmission.
Posted on Nov 16, 2009
Testimonial: "Very clear and thorough instructions. "
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Kenmore top-loading washing machine squeaks
Hi
Thanks for using FixYa. Please check if there are any sucked small clothes, safety pin, lint or debris in the water pump. If the pump is fine then the squeaking sound may be due to gear dogs in the agitator or bad gear case. The washer will spin and agitate at the same time. If the washer is still under warranty then do not try to open, repair or replace any part to void the warranty.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 13, 2009 | Kenmore 22422 Top Load Washer
Kenmore washer will not spin or agitate, it makes noise
IN BETWEEN THE MOTOR AND TRANSMISSION THERE IS A MOTOR COUPLING PART # 285753A REPLACE THAT WILL FIX YOUR PROBLEM
Apr 28, 2009 | Kenmore 23822 Top Load Washer
Top load washer machine will not agitate
Hi There,
Check to see that the belt is being driven by the motor when it goes into the wash cycle. Let me know if this helps and thank you for using FixYa!
Mar 10, 2009 | Kenmore 24902 Top Load Washer
Washer making rubing noise while turning
On the back of your machine you can remove the back panel think it is about 8 screws. Once you get the back panel off look closely at the motor. Motor mounts, gears, clutch, brake, and if need be take the bottom apart and look at the main bearing on the bottom of the drum to make sure that hasnt gone bad
Feb 14, 2009 | Kenmore 24032\24036 Top Load Washer
Very Noisy Operation
you will have to access the bottom of the agitator from the back of the machine. Either you have loose bolts or else you agitator bearings are shot
Jan 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore washer will not agitate or spin & makes grinding noise
CHECK THE MOTOR coupler located between the motor and then transmission this will be a good place to start if you lean back the washer and look from the bottom you will see a thing between the motor and the tranny that looks like a oreo cookie check and see if that is broken in any way
Jan 11, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 Series Top Load Washer not agitating
Check out this you tube. Had the same problem today. Tipped washer on its side and replaced coupler between motor and gearbox. Parts are about $15
This is a good diagnosis video.
http://www.youtube.com/watch?v=VYOP0_KCYT0
Sep 02, 2008 | Kenmore 24032\24036 Top Load Washer
Grinding noise in top load kenmore washer when agitating
IT COULD BE A FOREIGN OBJECT IN THE PUMP. THE ONLY OTHER ITEM WOULD BE THE DRIVE COUPLER LOCATED BETWEEN THE MOTOR AND THE TRANSMISSION.
CHECK THE PUMP FIRST. IT IS ATTACHED TO THE FRONT OF THE MOTOR WITH TWO CLAMPS.
Apr 13, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
221 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
