Question about Creative Labs Sound Blaster Live! Value Sound Card
Hesitation and slowness in sound
Hesitation and slowness in sound can be from cd or on line or video. Anything producing sound will cause this pulsation and hesitation. About 10 seconds of this for every for every minute of sound.
Any thoughts? Win XP sp3 2 gig processor. 1 gig ram.
    Guru:
  • 1,738 Answers
Windows xp service pack 3 is your problem. SP3 takes a lot of memory to use. You should be able to uninstall sp3 and go back to sp2.
Posted on Nov 15, 2009
Testimonial: "Thanks, I will give that a try."
08 colorado hesitation
check your fuel pressure,if not right before you go buy new fuel pump,try new fuel filter
2- take the vacuum line to fuel pressure regulator .if it is wet with gas,the diaphragm is ruptured need new regulator
3- have exhaust shop check you cat convertor,also if you recently have head gasket problem,some of those anti freeze is burned by engine and ran through your cat convertor causes it partially plugged,
4- A bad throttle position sensor could be another cadidate
5- bad or old ignition coil could be also the reason,as it could not produce enough juice on higher R.P.M
Aug 27, 2014 | 2008 Chevrolet Colorado Crew
Chev auto trans slow taking off
Hello
I would rebuild the carburetor or check the intake for vacuum leaks or leaking vacuum hoses, all these cause a lean mixture of fuel and that causes hesitation. The EGR valve opening to early due to a defective delay or other control device can also cause hesitation, disconnect the EGR to confirm the problem lies there and repair if needed
Jul 15, 2012 | 1978 Chevrolet C1500
I own a LG.ADR-620 CD RECORDER, when i record from the in built cd to the cdrw and play back things sound OK, when i record from a external source to the cdrw and then play back i get interference only on...
When you record from an external source, the data transfer may be too slow to produce quality recordings. If you're able to download the external source first, then burn it to disk, it should produce good quality recordings.
Apr 15, 2012 | LG Audio Players & Recorders
My logitech x240 when i play a video or sound it sounds really slow would it be sound system or sound card
Open up your computer the speakers plug/outlet is usually at the back of the computer
to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
be sure to wear an anti static earth strap before touching anything inside your computer
or you might have to uninstall your soundcard restart your computer then reintall it
click start control panel administrive tools computer management device manager scroll to sounds video and game controllers ther might be a yellow ? question mark right click to update driver or uninstall hope this helps
Apr 22, 2011 | Logitech X-240 Computer Speakers
My bike produces sound like whistle
Try changing the air filter.
Have a great day !
Apr 09, 2010 | 2006 Hero Honda CD Deluxe
CD drive clicking sound
Hello my friend please try to insert 2 new CD. and then try to observe the sound if it is still sounds like the weird. Then if you notice that the 2 new CD you insert produce same sound as your old one then i recommend that if you can find computer technician in your place to verify if your DVD/CD Rom is defective or not cause as of now if the 2 new cd inserted produces same sound as your old cd inserted then DVD/CD Rom has something to do its either defective or has a serious problem that needs assistance.
Thank you
Jul 30, 2009 | Computers & Internet
Stanton S -650
Make sure that the "line/phono" switch on the back of the unit is set to "line", or your output signal will sound distorted.
May 22, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
Microsoft LifeCam vx3000
i lost the cd haw can i instoll on llaptop without cd.
Feb 23, 2008 | Microsoft LifeCam VX-3000 Web Camera
Drum drive/motor growling, also very brief repeated hesitation audible
Dale you are correct, the dryer has a part starting to fail. If you remove the top and shift the cabinet the noise may increase or decrease. If this happens, then the rear panel is bent in that supports the rear bushing. You can replace that to resolve this. If the noise doesn't change, I suggest you check the blower, Sometimes the blower will spin freely on the motor shaft and cause a noise. Since this blower wheel also cools the motor, it could be spinning. Try removing the blower and add a washer behind it to tighten it to the motor shaft. This is just a press fit blower wheel. If that doesn't resolve the issue, then replace the blower wheel. Hope this helps.
Jan 28, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Creative Labs Sound Blaster Live! Value Sound Card Logo
143 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
Shawn DuRee
kevinmacleod
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
