Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
I have an Epson Stylus CX6600 and a sheet of paper has just jammed, can anyone help please.
After reading some of the others I felt I could very gently pull the paper through from the front not the back of the printer, it came away in bits as it was well sodden with ink, I used a pair of long tweezers to get at the little bits and then had to print several sheets to get rid of the smudged pages, but that seems to have done the trick and its now printing ok. Many thanks.
Posted on Nov 16, 2009
Epson Stylus CX6600 wont power up/scan light turns on then goes off.
this may help...
Check that all the access doors and compartments are closed correctly.
Check paper isn't jammed.
Take out the all the ink cartilages and reset them in correctly
Make sure the rollers are set in place correctly, (if there removable)
Hope this helps a bit
Feb 09, 2014 | Epson Stylus CX6600 All-In-One InkJet...
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
My cx6600 has a paper jam and can't seem to get it to get it un jammed
if you have kids, then you may have something such as a band-aid or such stuck in the rollers, try using a 8 1/2 x 11 inch piece of poster paper and run it thru the machine to get it (or other things like bottle caps) unstuck.
Feb 21, 2011 | Epson Stylus CX6600 All-In-One InkJet...
Keeps jaming on the right every time
Follow this step to clear the jam
press the diamond shape button start button to eject the jammed paper. If the jammed paper is not ejected, go to the next step.
if the paper is stuck near the sheet feeder or output tray, gently pull it out.
If the paper is stuck inside Epson Stylus CX7800, press the power on button to turn it off. Open the scanner and remove any pepr inside including any torn pieces. Do not pu;; it backward beacuse this can damage the sheet feeder. Close the scanner, then turn the epson stylus CX78oo back on.
Nov 17, 2010 | Epson Stylus CX7800 All-In-One InkJet...
Have lost my installation cd for a Epson Stylus CX6600 can I download this? Please advise
yes you can download the software that was on the cd from
http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-CX6600/Drivers-Support
Mar 07, 2010 | Epson Stylus CX6600 All-In-One InkJet...
Paper feed problem
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Feb 10, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Build up of ink on rollers , how on earth do i clean this off as my print outs are all grubby mucky looking cheers
Hi, please attempt running several sheets of blank plain paper or try to copy a plain blank paper for 5 to 10 times.
Sep 24, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Epson R300
Make sure the photo paper is not curling when it goes in. I had same problem before, with paper jam error even though the photo paper did not appear jammed. I noticed the photo paper was slightly curled, so I flattened it out and that solved my problem. Also, if you are loading multiple sheets at one time, try just loading one sheet and see if that fixes it.
May 11, 2008 | Epson Stylus Photo R300 InkJet Printer
Paper feeder
You probably is working with paper excessively wet. Even when you cannot detect the moiture can be present in the paper. Try to use a paper dryer (there are for sale in computers stores). Dont use to leave the sheets in the printer when you are not printing, leave them in the dryer.
May 02, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus cx6600 printer not printing
please remove un necessery data from your system and re install the printer som after it your problem will be finish
Sep 26, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
