Question about Karcher K 5.85 M Electric Pressure Washer
I have a karcher 495, it is puslating when it is
I have a karcher 495, it is pulsating when it is on, switching on and of every few seconds when i stop the trigger. plaese help , maurice
    Sniper:
  • 56 Answers
It sounds like there may be a pressure leak somewhere in the system. The machine cuts off when there is no flow of water past it. If it is leaking then there is intermittent flow. Which would make the machine run then stop continuously.
Posted on Nov 16, 2009
Why does my Karcher pressure washer Pulsates when switched on also leakes water.
Shame you did not leave the model type of "Karcher" pressure washer as there are several models.
There is normally a special oil which should be changed, expect this to be done at least every three years or less.
1/. These pressure washers should only be serviced or taken apart at one of their registered dealers, as far as pulsating if you have the cheaper models then they do not last very long.
2/. Their better more power washers pulsate all the time & that is why they are sold new with a special fitted container, this allows all the pipes & water connections to fit & hold in supplied container, which allows you to give a higher or lower power controller where their yellow pipe that attaches to the gun fits on the machine.
3/. Where the pressure pipe goes into the power washer it has a black knurled fitting to adjust the pressure higher or lower out put, this is the only adjustment you can make on these power washers, everything else needs to be done by their approved dealers, situated all around the world, try finding your nearest dealer through the Internet. Hope this helps. Malcolm.
Feb 07, 2015 | Karcher Garden
I HAVE AN OLD, ABOUT 15 YEARS,PRESSURE WASHER MODEL 270M. RECENTLY IT STARTED TO PULSATE WHEN I ACTIVATED THE WAND CONTROL. IT PULSES AT THE RATE OF ABOUT 1 SECOND INTERVALS. IT WILL NEVER STOP AND RUN. I...
To me this problem sounds like there is something wrong with the pump.
I think its better to buy another Karcher machine and get the 12 month warranty. As with old pressure washers you could spend money on certain parts to fix the machine but a few weeks/months down the line a different part of the machine could break and then you end up having to buy a new machine anyway.
Also being 15 years old you would have to check to see if parts are still made for the machine. This is because once Karcher discontinues a machine parts for that machine are manufactured for 10 years from that discontinue date.
Jan 17, 2011 | Karcher Garden
My karcher 250 pulsates when i turn it on, any idia how to fix it thanks
Several things can cause this problem. It is trying to build up pressure and something is preventing it.
1. check water pressure comming out of the the spicket.
2. Make sure the hose and connectors aren't leaking.
3. make sure there isn't any water leaking from the washer.
If all is ok I would guess the pressure pump has gone out that's the noise you hear pulsating trying to build up pressure.
Terry
Jan 15, 2011 | Garden
Pulsating when idle
The motor doesn't pulsate when you are spraying and pulsattes when not spraying is normal otherwise the pressure will just keep building and burn out the pump. However, if you are not using the sprayer right away then the unit should be shut off until your ready to start again.
I hope the answer is helpful, please rate if the answer has helped in any way. Good Luck and have a great weekend.
Apr 03, 2010 | Karcher K 3.98 M Electric Pressure Washer
Karcher 360M pressure washer pulsating problem when idleing
unfortunately these little units have this problem commonly, 9 times out of 10 it will be the plastic head or the plastic valve block on the unit will be cracked and leaking slightly... it builds up pressure then leaks out and tries to build up the pressure again and this just reoccurs over and over...
you can get this repaired but is normally about half the cost of a new unit, if the pressure is still okay i would probably recommend just keep using it until it proper dies...
If you do get this fixed, we have studied into this and believe the main cause of heads cracking is warm water say if your inlet hose is in the sun for a period of time this can cause the water to become quite hot or if the unit sits and water trapped inside the head assy freezes can also cause this. Hope this helps Kind Regards Brad
Dec 16, 2009 | Karcher PSI Electric Pressure Washer
When I switch my karcher k4.97 washer on it just sits and pulsates(on off on off etc.)When I squeeze the trigger it runs perfect,Then when I release the trigger it reverts back to pulsating.It leaks water...
Well, first the easy bit... the pulsation is caused by the leak, because the machine can't hold pressure when the trigger is released.  The difficult bit is: what to do about it?  Unfortunately, there are several different places where the leak can occur and, even with the cover off, it's usually impossible to be sure exactly where the water's coming from.  In the repair shop where I work, we almost always replace every part that might be causing trouble without even trying to identify the exact source.  To do otherwise will rack the labour costs up so high as to render the job uneconomic.  We reckon that if you can't complete the job in 45 minutes it's not worth it.  Sad really, but such are the realities of our economics.
Anyway, unless you are a really competent handy-person, this is probably a job you won't want to tackle for yourself.  So your choice is either to live with it (and do whatever you can to limit the pulsating time - keep it working or switch it off immediately) or take it to a repair shop.  If you are in the UK, Karcher head office can direct you to a repairer, and I guess the same applies in many other countries too.
If you do want to have a go at it yourself, post another message here and I'll give you as much guidance as I can (but there will be a limit to the amount of detail I can provide, as I can't get in to writing a complete service manual!).
Jun 23, 2009 | Karcher Garden
Karcher K 5.85 M Electric Pressure Washer Logo
1,275 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
