Question about Bissell 3750 Lift Off Bagless Upright Vacuum
My bissell lift off will not pick up, there are no blockages and suction is still strong
  • 701 Answers
You can fix it easily. All you need to do is change the belt and you'll be good. Here is a link to the belt you need and the manual which has instructions.
Bissell Lift-Off Revolution Belts and Manual
Bisslll Lift-Off Revolution User Guide
Posted on Nov 15, 2009
Bissel carpet cleaner no sucking
Hello, this is Ava with Think Crucial.
Most of the time the reason why vacuum is not picking up is due to loss of suction. You may need to check for blockages of your wand and hose. Remove the wand and hose from your cleaner when checking for blockages and any damages. Make sure to turn off and unplug your vacuum from the power before doing this. You may have to refer to your User's Manual for the instructions and guide.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jun 10, 2017 | Vacuums
Wont pick up anythimg
Check your pick up tube. Use a straitened wire hangar to push up tube and check blockage. You also may need to change the bag. Some bags sides will clog with fine dust and reduce the suction.
Jan 03, 2016 | Bissell Steam and Sweep Hard Floor Cleaner...
Bissell Big Green Carpet Cleaner has poor suction why?
Most of the time the reason why vacuum is not picking up is due to loss of suction. You may need to check for blockages of your wand and hose. Remove the wand and hose from your cleaner when checking for blockages and any damages. Make sure to turn off and unplug your vacuum from the power before doing this. You may need to refer to your User's Manual for instructions and guide.
Ava B.
Jun 28, 2014 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissel has no vacuum but everything else works
Most of the time the reason why the vacuum is not picking up is due to loss of suction. You may need to check for blockages of your wand and hose. Remove the wand and hose from your cleaner when checking for blockages and any damages. Make sure to turn off and unplug your vacuum from the power before doing this. You may refer to your User's Manual for instructions on basic maintenance.
Ava B.
Mar 08, 2014 | Bissell ProHeat Pet Upright Deep Cleaner,...
My Bissell bagless vacuum does not seem to work anymore. It will start to with a suction and then instead of picking up the dirt, it appears to blow the dirt out almost in a cloud of dust and debris from...
this is caused by a dirty air filter and/or a blocked vacume hose ( most of the time the blockage is at the bend where the hose enters the floor sweeper area ) ---
remove and tap out and brush the filter ( or use a air compressor to blow out filter ).
then with the vacume on its side - remove the bottom plate ( like you were going to change the belt ) and use a coat hanger and clean out the hose between the floor sweeper and where the suction hoes attaches. this will restore your vacume to full operation.
c...
Jan 23, 2011 | Bissell 6595 Lift Off Bagless Upright...
Bissell Proheat 1699 won't spray from main/min. suction
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
kgj
Jul 27, 2010 | Bissell 1699 ProHeat Clear View Upright...
Blocked suction
Here is a tip that I wrote about my Bissel ... the hose should just pull out... it is just stuck in there tightly...
Bissell Bagless Upright Vacuum not working
http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not
heatman101
May 28, 2010 | Royal 088500 Featherlite Upright Vacuum
Fllor nozzle window blockage
take the 2 screws out near the front outside edges then just lift it off
Jun 30, 2009 | Bissell 1699 ProHeat Clear View Upright...
Loss of suction bissell vacume
that is normal for the vacume to shut off if the motor overheats you must keep teh dirt cup clean and empty and all the filters clean, when you empty the dirt cup if you have a lot of pet hair take the hose off and make sure that it is clean as well, and do not try to pick up any of those cleaning wipes that will stop it up real quick
Sep 29, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
No suction
Is there a blockage in the small hose in the bottom of the machine
take of the pod and you will see the small hose,
Is the main hose pushed into the bottom housing
Nov 06, 2007 | Bissell 37603 Upright Vacuum
Bissell 3750 Lift Off Bagless Upright Vacuum Logo
246 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
