Question about Lexmark X5470 All-In-One InkJet Printer
Cannot scan on lexmark x5470 ("cannot retrieve application list")
I have lexmark x5470 and when i click "scan mode" on the exterior of the printer and try to scan something, it says "cannot retrieve application list". What must i do?
IT SHOWS IN MY LEXMARK PRINTER MODEL X5470 ALL IN ONE ...xcANNOT RETRIEVE APPLICATION LIST. I NEED TO SCAN SOME DOCUMENT THATS WHY I'M LOOKING FOR LEXMARK INSTALLER FOR THIS MODEL. LOOKING FORWARD FOR...
Please follow the steps given below:
1) Click on "Start," "Programs," the Lexmark program folder, and select the "All-in-One Center."
2) Click on the "See more Scan Settings," then "Display Advanced Scan Settings."
3) Click on the "Scan" tab.
4) Click on "Edit."
5) Under "Application Name," please highlight "Microsoft Word" and click on "Add."
6) Click on "Close."
Jeethu
Sep 15, 2010 | Lexmark X5470 All-In-One InkJet Printer
Unable to scan with x5470 Lexmark all in one
please try scanning with another program, for example you can try paint to start paint
press and hold the windows key, then press r. the run menu comes up, type in mspaint. ones the mspaint is open click file and select from scanner or camera, follow the scanning wizard and let me know the results.
Sep 24, 2008 | Lexmark X5470 All-In-One InkJet Printer
"Cannot retrieve Application List" Error message
plz install drivers of your printer first to your pc.
Mar 19, 2010 | Lexmark X5470 All-In-One InkJet Printer
Printer stating cannot retrieve SCAN MODE APPLICATION FOR LEXMARK X5470
Hello. Here are some tips on how to remedy the problem. Check your firewall especially from third parties. Make sure to allow all Lexmark communications to go through. Also, try to check if the scan software is installed. If not, try to run the installation cd again to include the scan software. Hope this helps.
Mar 17, 2010 | Lexmark X5470 All-In-One InkJet Printer
Cannot retrieve applications listo lexmark 3500
my printer will not scan when i try it tells me downloading applications list then it will not download it tells me cannot retreive applications lists and i have reinstalled the disc and still nothing
Jan 27, 2010 | Lexmark X5470 All-In-One InkJet Printer
What can I do when the "scan Mode" says cannot retrieve application list?
This is a pest of a problem with LEXMARK. You need to phone there customer service for the solution.
Nov 01, 2009 | Lexmark X5470 All-In-One InkJet Printer
My printer wont scan every time i try it says can not retrieve application list what does this mean?
Please follow the steps given below to add applications to Imaging studio:
1. Open the Imaging Studio and then click "scan," after the scanned document appears as a preview.
2. Click "Other Software" at the bottom.
3. That will open up the list of application list, to modify the application list, click on "Modify Application List".
4. Please add the application you want to scan and click on "Close."
Aug 20, 2009 | Lexmark X5470 All-In-One InkJet Printer
Have a Lexmark X5470; when 'Scan Mode' is engaged,
on your computer: click on start all programs / programs check for the lexmark folder ( lexmark 5400 Series ) check if there is any application under it ( AIOC , Productivity Studio, or Imaging Studio ) If there is: check your firewall, this might be blocking the application list. If there's none: Using the disc: Start My Computer / Computer Open your CD/DVD drive where the lexmark disc is Open application folder Run Setup under application folder. This should update the software
Mar 19, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark Scanner - "cannot retrieve application list" Won't Scan - HELP please!
Microsoft Paint ----> 'File' ------> 'From scanner or camera' (when in scan mode on printer). Just tried this and it really works.
Oct 19, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
105 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
