Question about Reliance Water Heater #6-30-DORT 30GAL Electric Water Heater
Water gets burning hot and trips reset on thermostat and theromast was replaced and still doing it
    President:
  • 3,433 Answers
Is there a temp setting like hi,med,or low? That control works like a rheostat. If it is shorted it will keep the elements full powered and you will have this problem. Has the pressure relief vale gone off yet? Make sure it works so you don't have pressure damage to the plumbing . Now back to the thermostat. Try turning it all the way down. If it continues to heat, The rheostat is defective (temp control)
Posted on Nov 15, 2009
Symptom: water gets too hot, before and after thermostats are replaced, burn mark and insulation swelling/melting on non-common wire from upper element to upper thermostat, and the breaker trips.
Double check the thermostat connection and setting; if it persists, I would add a pipe hugging thermostat connected to a shunt trip for the heater elements.
Jul 26, 2015 | Water Heaters
The water heater (Reliance Elec 501) does not turn on, This happened on the same day that our whole apartment lost power due to tripped main switch.n I reset main but water heater does not respond,...
Two-element water heater is 240Volts.
No hot water means: ECO reset button tripped, upper element bad, upper thermostat bad, or 240Volts is not reaching water heater.
Circuit breaker can be delivering power on one leg of the 240V circuit, so water heater appears to have electricity but is only receiving 120V.
Test for 240volts across top two screws on upper thermostat.
Look for loose wires and burned connections.
Push in reset button real hard.
Replace both upper and lower thermostats.
Remove wires and test upper element for continuity.
Open following links for do-it-yourself troubleshoot walk-thru:
http://waterheatertimer.org/B220C.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
http://waterheatertimer.org/Test-electricity-to-water-heater.html
Aug 21, 2011 | RELIANCE ELECTRIC WATER HEATER
Called and was told to change lower thermostat but yet again I had to go push red reset button on top panel to get it back on to get hot water. what should I do now?
You have electric water heater.
You have top and bottom panel, so water heater is 240Volt.
No hot water because ECO reset button tripped.
Water heater works correctly when reset button is reset, so electric power and circuit breaker are good. Water heater wiring is probably good.
Problem is most likely bad thermostat.
I usually replace both upper and lower thermostats.
If problems continue after replacing thermostats, then test and replace elements.
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
Aug 05, 2011 | RELIANCE ELECTRIC WATER HEATER
I don't have hot water suddenly. Please help me.
You posted under Rheem 81VP which is 6 gallon point of use electric water heater.
3 things can cause problems: Power going to water heater, thermostat with reset button, and 1500watt element.
Check that 120Volf circuit breaker is not tripped.
Open cover on side of tank and push in red reset button.
If reset button is not tripped out or will not reset, and water heater has power, then replace thermostat is best start point.
Also test element, since elements burn out:
http://waterheatertimer.org/How-to-test-water-heater-element.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 19, 2011 | Rheem 81VP6S/430126 Water Heater
It has cold water comign out no hot
Yes, the reset probably is tripped...push in the red button hard
Then turn it on and try it...
Check out this tip..
How to replace the Thermostat and Element for
Electric Hot Water Heater
heatman101
Jan 18, 2011 | RELIANCE ELECTRIC WATER HEATER
Hot water runs out in 5 minutes it use to last 20minutes
Electric water heater can be repaired by homeowner.
Water heater has some hot water.
We know 3 things for sure:
- electricity is ok
- upper element is ok
- tank does not have overheating problem
Here are the suspects:
- Burned or loose wire
- Upper thermostat not working
- Lower thermostat not working
- Lower element not working
What to do:
1) Turn off power, open water heater covers and look for signs of burned or loose wire, especially on lower element. Burned wire on lower element says lower element is burned out.
2) Test lower element.
Lower elements burn out when sediment builds up inside tank.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
3) If wires are ok. And you do not want to test parts, then replace upper and lower thermostat for 25$. If problem persists, replace lower element.
4) If you want to test thermostats and elements before replacing anything:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
5) When finished, be sure to put insulation and covers back on tank so thermostats don't receive cool air and misread tank temperature. This will prevent overheating of tank that causes red reset button to trip.
Nov 23, 2010 | RELIANCE ELECTRIC WATER HEATER
No hot water
Four things can cause NO hot water:
1) ECO red reset button tripped. Remove top cover on water heater, push red reset button on thermostat. Put insulation and cover back over thermostat.
2) Circuit breaker is tripped, circuit breaker bad, or wire loose in breaker box. Turn breaker on-off and listen for crackling or fizzing sound, and burned smell. Test breaker for 220Volts. Test top two screws on upper thermostat to see if water heater has electricity.
3) Bad upper thermostat. Replace upper thermostat.
4) Bad upper element. Test upper element.
Nov 22, 2010 | Reliance WATER HEATER CO #9-40-DKRT 40GAL...
Electric water heater out. Already replaced elements and breaker. Getting power to the unit but no hot water. What now?
Have you reset thermostat on the heater, it will be the top thermostat right above the element. It will have a red reset button to press to reset. They will trip causing the heater not to work till it's reset or replaced due to thermostat gone bad. Chances are you may only have to reset it.
Please go to link below with to get some very helpful information on these topic's. If you replaced everything but the thermostat or reset it that's all left to hold out power to water heater. The thermostat is a safety device to protect the home owner. You may have had a element short out to trip it.
It will take 30 to 45 minutes to start to produce hot water after power comes back on.
http://www.water-heater-repair-guide.com/electricwaterheatertroubleshooting.html
Jun 17, 2010 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Water not getting hot
You seem to have a burned out heater elemt. Most water heaters have 2 e.ements. If the upper one bruns out, it will not heat at all. If you have a cheap heater built by State, you probably have a bad lower thermostat. It will over heat and trip the protection device. If you reset the red button on the upper thermostat and it gets too hot (check in about 2 hours) then replace the lower therm. You could still have a burned out upper element.
Mar 31, 2009 | Water Heaters
Reliance Water Heater #6-30-DORT 30GAL Electric Water Heater Logo
153 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
