Question about Estate TEDX640JQ Electric Dryer
THE DRYER DRUM ROTATES BUT NO HEAT - Estate TEDX640JQ Electric Dryer
Rotates but no heat
Posted on Nov 16, 2009
    Problem Solver:
  • 5 Answers
  • skydnsr Feb 04, 2010
    Could be your thermal cut-off has failed, as above. Other parts that can fail and cause this problem include the fuse, thermostat, and heating element. I think the fuse is supposed to be the most common part to fail. People often think they must have a defective heating element, but from what I understand, heating elements don't fail that often. Once you get the back of the dryer off, it is easy to test everything. Search the various "dryer won't heat" threads in this site for troubleshooting directions. If you still have the customer literature that came with your new dryer, that will help you identify the parts on your particular machine.
    In general, you will use an ohmmeter to see if the circuit between the two connectors on a given part is open or closed. This is referred to as a continuity test. All of the parts mentioned above should have zero resistance between the two connectors, meaning there is intact continuity. If a part fails the continuity test -- in other words, if it shows infinite resistance on the ohmmeter -- it is defective. UNPLUG THE MACHINE, BEFORE YOU TEST ANYTHING!
    I just fixed my own dryer with help from various posters on fixya, by reading several threads and more or less putting all of the information together in my head. I found that a lot of the information that is posted about "no heat" type dryer problems is very general and can apply to any make or model of dryer. Whirlpool makes Estate, so anything about Whirlpool should be very applicable. Look for threads about gas dryers if you have a gas dryer, and look for threads about electric if you have electric, though.
    Good luck.
Coils lights up but no heat goes up to drum
if your heater coil is working
dryers have a cool down cycle built in
the coil heats shuts down
and drum rotates till end of cycle
Oct 13, 2016 | Dryers
No heat when dryer is turned on, drum rotates but no heat
Hi,If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.if you dryer is gas check out this gas no heat tip....If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Oct 15, 2011 | Kenmore Elite HE4 Electric Dryer
Dryer drum rotates but there is no heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 18, 2011 | Estate TEDX640JQ Electric Dryer
Dryer drum rotates with on heat produced maytag 90series electric
heatman101
Jul 24, 2011 | Kenmore 63942 Dryer
Drum rotates, timer dosen't advance, no heat
heatman101'
Jul 12, 2011 | Kenmore 500 6952 Dryer
Drum rotates. No Heat. Kenmore Electric Dryer
check the thermal fuse on the top of blower wheel housing,also while your there take off the cover of the housing and clean all the lint out,if your fuse was popped the lint buildup did it,check outside and make sure the air from dryer is blowing out and is not blocked,if it is blow out vent line if it's a long run with a leaf blower,if the thermal fuse is good read out the heater with a meter and if that's good read out the t-stats
Nov 15, 2009 | Kenmore Dryers
Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
Sep 15, 2008 | Zanussi TC7102W Electric Dryer
Dryer heating element
There is a fuse in the dryer for the heat.
Before tearing into the dryer, make sure the power getting to the dryer is absolutely correct. (check power with the dryer running) Even with incorrect power to the dryer. the drum will still turn but there will be no heat.
Many a person has paid for expensive service calls for the problem you are having only to discover by the servicer that there was nothing wrong with the dryer but had bad power to the dryer......
Jun 15, 2008 | Whirlpool Dryers
Estate TEDX640JQ Electric Dryer Logo
546 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
