Question about Sharp EL-1701C Calculator
Sharp caluulator EL-1701C out of ink..lost manual
Sharp Calulator EL-1701C out of ink..lost manual do not know how to replace ink rolls DeeDee
Found solution. thx.
Posted on Nov 16, 2009
I have a sharp El 1701C calculator and can't get it to print. It was working but I touched some button and now it shows NP, also an F and a up arrow on the left side of the screen.
My guess is that you are getting a No Paper message and a Feed message accompanied by a directional arrow indicating which way it is to feed. Maybe you can Google (sharp)(El 1701C)(manual) to find out what went wrong and how to get things back to normal.
Feb 06, 2017 | Sharp Office Equipment & Supplies
I have an old Sharp EL-1701C calculator and for some reason can not feed a new roll of paper into the unit? Batteries are new and the feed option works well, just doesn't grab the paper roll to start?
you may need to cut the corners off a little bit on the start of the new roll and feed the paper in while advancing with the calculator advance control/button
Dec 10, 2014 | Sharp EL-1701C Calculator
When adding on My Sharp EL-1701C calculator it will stop adding and show a P. E
The P stands for power & usually means you need to change your battery
Dec 22, 2010 | Sharp EL-1701C Calculator
How can I get a manual for the SHARP EL-1701C? Can I view the manual online?
lOG INTO GOOGLE AND REQUEST A FREE DOWNLOAD IT SHOULD BE AVAILABLE
Nov 18, 2009 | Sharp EL-1701C Calculator
I have a Sharp EL-1701C Calculator
Hi cherycooney,
Press the '2nd' button, press the 'M+' button. 'NP' should appear on the display screen, and print function will be turned off.
Thanks for using Fixya.
Apr 15, 2009 | Sharp EL-1701C Calculator
Ink problem
It has a little ink roller under the plastic on the right side as you are looking at it. It is made of black plastic and pulls straight up to come out
May 11, 2008 | Sharp EL-1701C Calculator
Where do i put the paper into to replace a new roll
There should be a small slot towards the back. The paper gets fed from the back bottom, and it comes through the top just behind the display.
IF you take your roll of paper, tear off a fresh new edge, make an arrow point at the end (fold 1 side to the middle, and then fold the other side to the middle to meet the other side) to make the paper look like : " > " then insert the pointed side in the slot, and then press PAPER FEED at the same time. The paper should start feeding and you should be good to go.
Feb 04, 2008 | Sharp EL-1701C Calculator
Item count on el-1701c
Helloooo
There is a switch located above the keyboard labled IC for item count...slide the switch to the on position and as you add a number will appear on the paper tape on the other side of the total. On some units it will appear on the Display also.
I hope this solves you problem.
Squipps
Jan 23, 2008 | Sharp EL-1701C Calculator
Set tax rate for Sharp EL-1701C
I Finally figured it out after playing with it for almost 1/2 an hour!
Hit 2nd then Tax + (rate set) it will appear as 0.000 enter your tax rate... mine is 5% so I enter 5.0 then hit 2nd and Tax + (rate set again) And it will work!
It is glorious!!!
Answered By James Soltys from: Edmonton, Alberta Canada
Jan 20, 2008 | Sharp EL-1701C Calculator
Sharp EL-1701C Calculator Logo
1,692 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
