Question about E-Machines T6528 PC Desktop
CPU is unworkable message at boot up
I turned on my PC yesterday and at boot up a the following message came up " CPU is unworkable or been changed"- I have not changed anything and had no problem previous to this.
I continued with Boot up by pressing F! and windows XP cant load.
Ani Ideas on whats wrong and what i can do to put things right>
Many thanks.
  • Rumenigge Dec 21, 2008
    Hi I am receiving the following error when booting up my pc
    CPU is unworkable or has been changed - CPU soft menu
    I have changed the CMOS battery and also left it out for one hour in
    order to reset the Bios. IN Bios I have tried loading the default
    values but I still haven't managed to solve this issue. Any further
    things I can try?
    I have changed the CMOS battery and also left it out for one hour inorder to reset the Bios. IN Bios I have tried loading the defaultvalues but I still haven't managed to solve this issue. Any furtherthings I can try?
    Problem Solver:
  • 14 Answers
Try resetting the BIOS. Maybe some of the settings were lost if the motherboard's BIOS battery died.
Posted on Nov 05, 2008
  • 45 Answers
Possibly power supply issue and/or replace the battery on your motherboard
Posted on Jan 09, 2008
SOURCE:
When i turn on my PC toys CPU and emachines monitor it says disk boot failure enter system disk
hi,
you have two option as follows:
1.when you start PC press F2 enter in BIOS set it to boot from HDD then restart,if this step does not help then number 2
2.reinstal the OS
Sep 26, 2012 | E-Machines eMachines Desktop PC
Will not boot
Are you receiving error message?
What operating system are you running?
Oct 15, 2008 | AOpen Computers & Internet
On boot up on my Dimension 3100C I receive the following error message: Drive 1 not found:Parallel ATA, PATA-0 (PRI IDE Master) Alert! chipset heat sink not detected System halted!
first off your going to ewant to hit f2 or f12 to get into setup and you are going to want to change boot oder to your hard drive. i then would open the comoputer up by taking the side of the case off and checking your cpu. u are going to wanna make sure there is a heatsink or fan securly on your cpu. if not this could over heat and burn your cpu up. heat sinks look like thisbadboy616.png
Jan 07, 2011 | Dell Dimension 3100 PC Desktop
Have emachines T6528 graphics problem
if it doesn't boot at all .( this is the reason that you see that message on the screen it means that no video signal came out from the computer ) ..try to change the cable that leads from the pc to the monitor first ...and if the problem its still on ...it have to be something related with the Ram memory or the CPU ....cause these 2 are the only things that can make a system to do not boot at all ...if any other device will not work ..the pc will still boot to bios ..or will still show the devices it finds on start ...even if is not able to succeed with the operating system boot...
so ...either it boots and you can not see anything cause the cable its damaged...( very possible cause this is the case it shows that message ...when the cable its shorted ..or unplugged ) or it doesn't starts at all cause of the memory or CPU ...
Sep 08, 2009 | E-Machines T6528 PC Desktop
Screen is black. Hear computer trying to boot up.
cpu fan failure try to put a big fan where the comp vents and air flows! and see if its not shutting down!
Jul 01, 2009 | HP Pavilion dv5-1000us Notebook PC
Dell logo appears and message appears INSERT BOOT DISKETTE...
A couple of things can cause this.
1] having the 'boot order' set up so that the computer looks to a removable device that has non-bootable media in it.
2] somehow the 'boot' device has lost it's 'boot' properties.
Best way to troubleshoot:
1] find the boot CD
2] re-strat the machine and enter the "BIOS setup" mode <f10>, or <DEL>; I think::verify the boot order
this should likely be: C: ; CD ; A:
allow machine to start with CD and check to see if anything on the wanted 'boot' device has been lost; sometimes it will get smashed.
Let us know what you get after this point, because I would rather give you an answer based on knowledge from this part of the exercise.
Mar 21, 2009 | Dell Dimension 4100 (-JM0TB01) PC Desktop
I boot my cpu but the monitor doesnt show anything
Hi again.
The beep codes you describe are memory issues or failure, take the system memory out, clean the contacts and the slots with a clean, soft, dry paintbrush. Re-seat the memory firmly and try boot the PC again.
please post back with the results
Good luck and thanks for using Fixya!!
Feb 23, 2009 | Microsoft Windows Vista Ultimate Edition
BIOS error - CPU is unworkable or has been changed
try to reset cmos by removing CMOS battery from motherboard and reinsert again...
Dec 12, 2008 | Abit KV7-V Motherboard
My computer won't boot! It keeps restarting before Windows screen.
Make sure the cmos jumper is plugged in. Turn off your pc, unplug the power source. Remove the cmos battery for 30 seconds then put it back. Reboot your pc. Give us feedback! Hope that helps :-)
Jul 25, 2008 | Abit IC7-G Motherboard
Cpu is unworkable or has been change check soft menu
What is the model number of the board?
If you were able to boot, then you defiantly got the CPU in properly. Sounds like you just need some tweaking in the bios.
Oct 12, 2007 | Computers & Internet
E-Machines T6528 PC Desktop Logo
103 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
