Question about Belkin (F5D7230-4) Router (587009)
How do i hook up my belkin f5d7230-4 router to hughes net internet when there is only one ethernet port?
  • 591 Answers
Connect that one port to your Belkin WAN (Internet)connector (Yellow Port). The other ports go to other computers, to their Broadband RJ45 connectors.
Here's from the manual:
1. Unplug your existing modem’s power supply.
Find the cable connecting your modem and computer.
Unplug it from the modem and plug it into the gray port
on the Belkin Router.
If you are replacing an existing router, find the cable
connecting the computer and old router. Disconnect it from
the old router and plug it into the gray port on the new router
2. Connect the new cable (provided in the box) to the yellow
port on the Router. Plug the other end into the modem.
G WIRELESS ROUTER Quick Installation Guide
3. Plug in your modem’s power supply. Wait 60 seconds for the
modem to start up.
Plug the Router’s power supply into a wall outlet, and the
other end into the black port on the Belkin Router.
As the Router wakes up, lights will come on; recheck your
connections if the “power” and one of the “wired” lights
are not lit up in green after 20 seconds.
4. Locate the CD in this guide and insert it into your computer
The Setup Assistant should appear automatically.
If it doesn’t, open the CD in My Computer (Windows®)
or the Finder (Mac OS® X) and double-click on the
“Setup Assistant” icon
Posted on Nov 16, 2009
How to plug a WNR1000 Wireless Router into a Hughes net HN7000S modem
It should connect with an Ethernet cable. Looks like a phone cable but is twice as wide with 8 pins instead of 4. Plug one end into the modem's Ethernet output port and plug the other end into the router's single WAN/Internet input port.
Nov 09, 2017 | NetGear Computers & Internet
Is there a way i can hook up internet to 2 desktops with 1 modem/router?
That is exactly what a router is for.
If your modem doesn't have multiple ethernet connections, then go out and buy a generic router (like linksys or belkin or cicso or netgear, etc.) and hook the WAN port of the router to the modem's ethernet connection, and then hook the computers into the multiple ethernet connections on the router.
Aug 24, 2011 | Computers & Internet
How to hook up to new computer
1.You should have a modem you received from your ISP (Internet Service Provider).
2.Plug the Ethernet Cord Into the Internet port of your router.
3.If you have a desktop computer plug in the ethernet cord into one of 4 ports of the router.
4.Open you wireless connections and connect to the internet.
Mar 20, 2011 | Belkin Basic Wireless Router
How do I hook up a Berklin wireless router to my comcast internet
Use an Ethernet cable to connect the port on the Comcast modem to the WAN port on the Berklin (Belkin????) router.
Use another Ethernet cable to connect one of the LAN ports on the router to the Ethernet port on your computer.
Start Internet Explorer on your computer.
Connect to the web-interface inside the router.
Run the "network setup wizard".
Run the "wireless setup wizard".
Nov 17, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Lose internet connection (hughes net) when hooking up router
I would contact your hughes net, that is a satelite provider. That is a total different system, than dsl or cable. Hughes net should be able to walk you through the setup.
Oct 26, 2009 | Linksys WRT160N Wireless Router
We have just signed up for cable TV/high speed internet/cable telephone. The modem provided is an "Arris" version 1.5. The cable tech said I could connect my Belkin G router so that more than one computer...
Plug the ethernet net cord into the arris ethernet port. plug the other end into the router where it says "internet"
Plug a ethernet cable from one of the router ports to the computer.
First start up the arris modem, then power up the router, then start the computer.
Oct 22, 2009 | Belkin 802.11g Wireless Desktop Network...
Wndr 3300 net gear router wont work with hn 9000 hughes net modem
I went to the Hughes web site to check out the modem. They say it is also a router. I think you will have to disable the router abilities of your WNDR 3300 Net Gear Router.
Get into the Netgear setup by loging on to it.In its WAN setup select Static IP Address and set the Static IP Address to the same as the hughes modem, except for the last number which should be about 50 greater. IE: Hughes 192.168.12.1 and Netgear 192.168.12.55.
In the DHCP setup, disable the DHCP Server
In the Wireless setup, Give your network a name is SSID. You should also set up security to keep others off you internet connection with a WEP key.
I hope this helps.
May 30, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
Router will not route to another router of same type
The hughes modem is not a router.
What are you trying to do? Install the Linksys?
Plug the ethernet port on the Hugnes to the "Internet" or "WAN" port of the Linksys.
Then if you go into the config of the Linksys, you can tell if it gets a public IP address.
May 21, 2009 | Linksys Computers & Internet
How to first hook up router to dsl modem
Connect the modem to the WAN / Internet port section and hook one of your computer to LAN ports.
Note: make sure that your Ethernet cable is working properly.
Mar 25, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Could you simply tell me how to hook up my wireless router? It has been installed and hooked up to my home computer before, but then we went awhile without the internet. I just can't remember what to plug...
pug in your modem and run the ethernet cable from the modem to the port labeled internet on the router. make sure the router has power and run another ethernet cable from any of the ports labled LAN to the port on your computer. and viola!! zi internet!!!
pls repost if you hit any snaggs
Mar 18, 2009 | Belkin Computers & Internet
Belkin (F5D7230-4) Router (587009) Logo
440 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
