Question about Acer P191WBD LCD Monitor
"Input not supported" roaming on my screen
I just turned on my monitor and it say's "Input not supported" roaming on my screen, just checked all my fittings, to make sure everything is hooked up porperly and they are,
so what I'm I missing
    Champion:
  • 206 Answers
It means that the resolution of the windows is set too high for your monitor. You will have to find some better monitor to connect it to it, and then to lower the resolution, after that, it should be working just fine
Posted on Nov 16, 2009
Power light on monitor lights but screen is black. Is it done?
This can happen if you somehow changed the input setting. Make sure to check the "Input" setting on the on-screen menu and make sure it's set to the proper type of input (HDMI/Digital or D-Sub/Analog) for the cable you're using. If that is correct, and you don't get an image, then you should also try to connect your monitor to another computer using another cable...because it actually may be your computer's video output, or a bad cable, that is the problem, and not the monitor.
If those checks don't solve the issue, then yes it may be "done."
This link will provide you with a user manual for your monitor to assist with the on-screen menu selection.
Jan 08, 2011 | ViewSonic VA1930WM LCD Monitor
Hi, I was recently given a Samsung Syncmasster 2333sw flat screen monitor that I hooked up to my old Dell Dimension 8200 desktop.The monitor says the optimum resolution is 1920x1080 pixels. The maximum the...
hi bob you should be able to adjust the screen size via the menu on the monitor itself, (Available in Analog mode only) Note When TV signal is input in AV mode ,select “Screen Fit “to adjust vertical position in 0-6 levels. Image Size Note Supplied for the wide models only such as 16:9 or 16:10. You can change the size of the screen displayed on your monitor. PC signals • Auto - The screen is displayed in accordance with the screen aspect ratio of the input signals.• Wide - A full screen is displayed regardless of the screen aspect ratio of the input signals. Note • Signals not available in the standard mode table are not supported.• If the wide screen which is the optimal resolution for the monitor is set on your PC, this function is not performed. AV signals • 4 : 3 - Sets the picture to 4:3 normal mode. • 16 : 9- Sets the picture to 16:9 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • 4 : 3 - Sets the picture to 4:3 normal mode. • Wide-Sets the picture to 16:10 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note • It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • When the panel is of 16:10,the screen size options include “4:3”,”wide “,”Screen fit“.hope this helps
Jun 22, 2010 | Dell Dimension 8200 PC Desktop
It says "input not supported" whenever i change the resolution higher than 1280 1080..i changed my vga card to my onboard one...cause at least here i can see everything clear with the resolution of 1280...
hi there,
looks like windows does not know how to handle the monitor.
You may try to disable the onboard graphic card in the BIOS before
hooking up the monitor to the nvidia card. then try to run windows in safe mode(by pressing F8 when booting up), it'll run windows with the lowest available resolution, which will be supported by the monitor.
Now download appropriate driver for monitor, install and reboot.
That should do the trick
good luck
Sep 29, 2009 | HP w17e Monitor
My w17e monitor says "input not supported"
Not quite sure what the question is that you have not already answered for yourself.
That monitor's maximum resolution is given as 1440 X 900 at 60Hz and installing a more powerful video card won't change that.
http://reviews.cnet.com/lcd-monitors/hp-w17e-lcd-monitor/4507-3174_7-32735619.html?tag=mncol;psum
JOAT
Dell m992 crt monitor
If it's getting no signal, make sure the monitor is set for the correct input. This would be either analog (if your cord has blue ends) or digital (if the connectors are white). Depending on wt yhat your monitor is, a button on the monitor will help you set that. If it's set for the correct input signal, then switch out a different cable to see if perchance you have a bad cable out of the box. If there is another PC or laptop setting around, plug your monitor into that to make sure it's good and maybe even plug THAT monitor into yours to make sure there is nothing wrong with your video card. Let me know what transpires. If this takes care of things, please help me out by rating it accordingly.
Jan 13, 2009 | Dell M992 19" CRT Monitor
FLOATING BOX WITH ATTENTION INPUT NOT SUPPORTED
Your monitor has several different video inputs.
Go to the configuration settings on your monitor and select the video input that matches the video cable from your computer.
Nov 12, 2008 | Computers & Internet
Inoperative monitor
Here are a couple things to try.
1. try the input select button on the monitor (The minnus button) without pressing the OSD menu button 1st, see if it changes to analog.
http://support.us.dell.com/support/edocs/monitors/1703fps/en/controls.htm
When the DVI self-test screen is up, it is indicating monitor is in DVI mode.
2. If that doesn't work, try a DVI to analog converter on the DVI port on the monitor and connect the analog cable to the converter. See if you get any video that way.
3. If you can access the On-Screen Display (OSD Menu) perform a factory reset.
Sep 29, 2008 | Dell UltraSharp 1703FP Flat panel TFT 17"...
Acer monitor AL1916W
start up windows in safe mode and see if you still get the problem. did you use the same vga cable???
Aug 26, 2008 | Gateway FPD2275W LCD Monitor
Acer P191WBD LCD Monitor Logo
145 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
