Question about Sylvania Televison & Video
How do i hook up my dvd player directly tob my 2001 sylvania tv that only have audio and video inputs?
  • 458 Answers
If your DVD has a scart socket, then you can buy a Scart to Composite cable, this is a cable with a Scart at one end & a Red/White & Yellow connector at the other end. If your DVD only has audio & video outputs then all you need is a composite cable.
Posted on Nov 15, 2009
How do you hook up a sylvania TV model#6313ce to a DVD player?
Connect the output leads of the player, often coded red (r. audio), white (L. audio) and yellow (video) to corresponding inputs on the rear of your Sylvania TV.
Jun 18, 2016 | Sylvania Televison & Video
How do I connect my Sylvania DVD VCR Player to my Westinghouse LCD TV?
Your Sylvania player probably has three outputs: right audio (red), left audio (white), and video (yellow). Use a corresponding three conductor cable to connect to corresponding inputs on the rear of your Westinghouse TV (if it has them).
Sep 19, 2015 | Sylvania Televison & Video
How to hookup Sanyo DVW-6100 to a Sylvania tv
If the Sylvania tv is a CRT (old style tube tv) you can just use an RCA cable and hook it into the composite video. It will be the cable that has a red, white and yellow connectors on it. The yellow is the video, the red is the right audio and the white is the left audio. Connect ones side of this cable to the output of the DVD/TAPE player and to the input on the TV side.
Sep 04, 2014 | Sanyo DVW-6100 DVD Player/VCR
The converter box is hooked On the TV and working. I have the TV with the rabbit ears and only video n audio in the front (yellow n white). I recently purchase a DVD player n I am trying to hook it on the...
you have to change the input on the tv to AV. there should be an input button on the remote, but if your remote doesnt work you might not be able to change the input. you can try to use the channel up and down on the tv and once you get to the end of the numbers, some tvs will change inputs before restarting the number list. make sure you hook the yellow cable to the yellow plugs on the dvd and the tv and either of the red or white ones to the white one on the tv. red and white are left and right audio and the yellow one is the video
Dec 24, 2010 | Insignia Digital-to-Analog Converter for...
I have direct satalite tv VR 6050 kenwood surround sound tuner vizio tv, dvd player, and a vcr, Im confused on how its hook up and what order should it go something like sat in to sat box to kewood...
that reciever is not going to carry a hi definition video signal, it doesnt have either hdmi or component video inputs.
you can still use it, but if you run the picture through the reciever, it will have poor quality.
heres how you are supposed to hook it up:
find the single,m yellow video jack on your sattelite box, and hook that up to the "tv" video input, then hook the laft and right audio outputs from the cable box into the "tv" audio left and right inputs on the receiver. hook up the dvd player and vcr in the same manner, using "dvd" and "VCR" (if labeled as such) inputs on the reciever.
finally, send the tv video and audio outputs to the composite video in and left/right audio inputs on the tv. the video will be running through the reciever, and when you use the reciever to switch the sound source, the video will also be changed. you could get better picture quality if you ran the video directly to the tv using component (seperate green, red and blue) outputs/inputs, and bypassing the reciever on the video end, but then you would have to change inputs on the tv AND reciever to change from your cable box to your dvd player.
Nov 25, 2010 | Kenwood VR-6050 Receiver
Hook up player
Your TV hopefully supportsw more then one unit connecting to it. if not you will need to use an input on one of your units (direct tv unit or DVD player) for the other unit. Example your direct tv is connected to your TV, on the back of your direct tv unit is a video /audio input. connect your dvd player to that input. on your direct tv remote or menu should be an option to use that input.
Aug 25, 2009 | GoVideo Go Video DVD/VCR Combo
Sylvania vcr/dvd installation
!st) The antenna INPUT::RF (black wire usually from "cable TV", "Dish TV", even ANTENNA air wave reception,etc.) into INPUT of VCR\DVD, OUTPUT of VCR\DVD to TV RF input.
2nd) If you have INPUT\OUTPUT to what are called " RCA " jacks on your TV, on the front or on the back, then any & all output jacks from VCR\DVD goes to INPUT\OUTPUT of the TV.
In other words:: output of audio on VHS\DVD to input of audio on TV( RCA jacks). Output of video on VHS\DVD to input of video (RCA jacks)
Hope this helps
Aug 14, 2008 | Televison & Video
Can i hook up to my satelite dish direct or do i have to go thru my receiver first. Thanks; Delmar currah@mts.net
The satelite dish will not pass-through the video/audio from your DVD player. You will need to find an open area (preferably DVD selector) on your receiver to input the DVD video/audio. Most satelite boxes are one way devices.
Satelite box --> Receiver (satelite input)--> TV
DVD Player --> Receiver (DVD Player input) --> TV
or
Satelite box --> TV
DVD Player --> TV
Mar 13, 2008 | Televison & Video
Video In trouble
I HAD THE SAME PROBLEM WITH MY PS2 GO TO INPUT CHANNEL OR ACCESSORRY 1 OR 2 MY PS2 IS ON INPUT1 GO DOWN 4,3,2,INPUT NORMALLY START AFTER CHEERS
Jan 17, 2008 | Sylvania DVC-860E DVD Player/VCR
Connecting DVD Player
when you say nothing do you mean the tv wont come on? If the tv is on can you see the words (input, volume bar, menus, etc.) do you hear audio? does the player work on another tv, since you have a sylvania tv, are you using the game button on the top of the remote to switch to the jacks on the front? Good luck :0)
Jul 07, 2007 | Sylvania 6419TC 19" TV
Televison & Video Logo
94 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
