Question about Sony SLV-660HF VHS VCR
My tape was stuck in the unit, managed to free it up and noe I have an erro code of E3 on the LED screen, what does this mean?
    Scholar:
  • 105 Answers
First you must make sure you got all of the video tape out of the unit. Unplug your unit from power and check for any remaining tape. Any small piece of tape could jam your unit and give you error code E3. Once you know you removed all tape leave your unit unplugged for 5 minutes to see if it clears up the error code. E3 is a drum rotation error code and usually clears after plugging the unit back into the power. If this did not help then further repair will be necessary.
I hope this helped you out! Good Luck!
Posted on Nov 16, 2009
Dometic fridge is flashing E3 on LED Panel what does the code mean
bad control board check by removing thermistor from board run over nite if ok replace thermistor if not bad control board
Jun 21, 2015 | Dometic Refrigerators
Door latch stuck
This error means your temperature sensor (probe) has failed and needs to be replaced.
Nov 05, 2014 | Whirlpool GMC305PD Electric Single Oven
A cassette has jammed inside my vcr machine. It will not move forward or backward Can yoy please help
Since the tape won't come out then it means you will have to manually remove the stuck tape. This involves you disassembling the unit in order to help/assist the player get the stuck tape out.
Turn of the unit and remove from the wall, get a Philip screw driver, use it to remove all the screws from the unit and take it apart.
Open the cover and you will see the stuck tape and what's hooking or preventing it from coming out/ejecting.
Now plug the unit, and turn it on. Press the eject button, as the tape tries to come out, support it with your hand so that it can come out.
Or if it happen that the cassette tape has coiled inside the unit, carefully free the coiled tape and the press the eject button.
Lastly, the moment you disassemble the player, you would see what's preventing it from coming out, then you can free whatsoever that is making it stuck press the eject button and the tape should come out.
Make sure the unit is turned off each time you want to remove what's making the cassette stuck.
I hope understand the above explanations.
Good luck.
Mar 04, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
CAN NOT INSERT A TAPE WHEN POWER IS TURNED ON
Sony VCRs have shown these error codes for years whenever a problem occurs but it really does not help much to know what the code means. Even if you knew the code meaning you still would not know exactly what to fix in the VCR. Suffice it to say the VCR probably needs repair.
Go to https://eservice.sony.com/webrma/web/index.do
and enter your zipcode to locate a SONY repair facility.
Apr 28, 2010 | Sony SLV-775HF VCR
Error codes E1 to E5
E1: tape end detection LED open
E2: front loading motor lock
E3: loading motor lock
E4: cylinder motor lock
E5: reel motor lock
These are from a Panasonic AG-7500 service manual.
Mar 04, 2010 | Panasonic Televison & Video
Sony dcr trv245e erroe code c32 20. I have had condensation issues with this camera in the past and now I cant eject the tape. can anyone help
The error code that your unit is now producing indicates that it is experiencing a tape transport problem - specifically that the takeup reel is leaving slack out of the cassette. This may have led to tape becoming caught in the mechanism and hence the cassette will not eject. This is one scenario although unfortunately it is not the only possibility.
The unit will probably need to go to a professional to have the cassette manually removed and the cause of the fault condition identified and rectified.
Jan 02, 2010 | Sony Handycam DCR-TRV250 Digital Camcorder
I have a Toyo Aircon TA 12C(H)S air conditioner that shows E3 on the readout and nothing will come on. Any ideas what the error codes mean?
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. E3 means low pressure of refrigerant. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem. Good luck to you!
Jul 03, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
E3 error code will not wash, what does this error code mean?
i have a maytag washer and it says E3 and it will not work,does anyone know what that means please let me know...thanks
Apr 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
E3 Error
here are the codes i found
E-1 Electrodes were not firmly grasped. Grasp the electrodes correctly.
E-3 Hands are dry. Slightly moisten hands with
a wet towel.
E-4 Body Fat Percentage and BMI values are outside themeasurable range. verify your personal data is
correct.
E-5 and E-6 Irregular Operation Turn the unit off, then on. Take another measurement. If the error occurs again contact Customer Service at 800-634-4350
have a great weekend!
Jan 29, 2009 | Omron Body Fat Analyzer from
Televison & Video Logo
701 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
