Question about Lexmark X2500 All-In-One Printer
Printer only prints one page at a time. I un-installed the printer and loaded it back up but that only solved the issue for about th first 3 prints. Now its back to the same issue of printing one page at a time and keep needing to redo the whole print process again.
  • 320 Answers
Uninstall disable antivirus and reinstall if your running vista there i probably a patch you will need at lexmark.com
Posted on Nov 15, 2009
Installed new ink. it says out of alenment
Dennis: According to an old FixYa.com, urbanhookupz said: "You need to run a printer alignment page like you do when you put in new cartridges.
unplug your printer plug it back in.
open door and take out print ink cartridges.
put them back in and then close the door.
It should now prompt you to do a test alignment page.
now try and print it should solve the problem.
if it does not prompt you to do a test page
Aligning the Print Head
This operation must be carried out when using the printer for the first time.
Aligning the
Print Head positions allows you to print without shifts in the color registration.
Print head alignment is performed either automatically or manually. This section deals with
automatic Print Head alignment only.
?? Ensure that the Inner Cover is closed.
?? The Print Head can also be aligned from the printer itself.
1.With the printer on, load a sheet of Letter-sized plain paper in the Sheet
Feeder.
2. Hold down the RESUME/CANCEL button until the POWER lamp flashes four
times.
1 With the printer on, load a sheet of Letter-sized plain paper in the Sheet
Feeder.
2 Open the Printer Properties dialog box.
See "Opening the Printer Properties Dialog Box Directly from the Start Menu" on
page 28.
3 Print the pattern.
(1) Click the Maintenance tab.
(2) Click Print Head Alignment."
May 26, 2015 | Canon MX340 AllInOne InkJet Printer
Print job goes to print queue but does not print
Un install the drivers.
Connect through usb cable observe system recognised the printer?.. if recognised, reload the drivers & chk for the prints.. if not issue with formatter..
Insert net work patch cable., print configuration page., verify the ip address., load the drivers as network printer., chk for the prints., if not printing., ping ip from system... chk withnamother cable.., fotmatter issue..
Apr 04, 2014 | HEWLETT-PACKARD LASERJET PRO P1606DN...
Every 3rd page prints chinese
check ur cable otherwise
check ur printer driver - installed upd driver 5.8 version driver
this problem will solve
Mar 27, 2014 | HP LaserJet 4650 Color Printer
Wont Print no icon on the control panel or device and printer page down load to print test page Les
Browse below link, select OS, download full feature drivers.. save it..Installation procedure: Un plug USB cable, un install loaded drivers through control panel. Restart the system run the drivers, connect the USB cable when its appears on screen run rest of the drivers.. once installed check for icon in printer drivers.. print test page & confirm for the print as well as check for the scan...Link: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3418707&lc=en&cc=us&dlc=en&lang=en&cc=us
Dec 30, 2011 | HP Photosmart C4580 All-in-One InkJet...
Solution for printer
* Does the same issue persists while printing from all applications?
* Does the unit print the self test page properly? Steps are given below
* Make sure the printer is loaded with unused white paper.
* Press and hold Cancel on the printer control panel.
* Press Start Color Copy .
* Release both buttons. The self-test page prints.
Please get back to me with the above information. I can solve this problem....
:) Dr Tony
Apr 04, 2010 | HP PSC 1410v All-in-One Printer
Printer not printing text
When printing a web page which has only 5 lines of text, the printer prints the 5 lines and scrolls the page empty. But, I wanted the printer to stop printing after it has printed the available 5 lines. Also, it should not print the header and footer automatically.
Dec 04, 2009 | HP DeskJet 3740 InkJet Printer
Only one half of page prints.
My suggestion would be to totally un-install the printer and erase all traces of the driver(s). Search for them after the un-intall and erase them manually.
Re-install the printer and driver...reboot if nessasary...align the print heads...do a test pattern...then try and print your document. It might just be a corrupted driver...some would suggest just installing over the existing driver...but I've found doing it that way gives you the best chance of it working the first time.
Apr 24, 2009 | Epson Office Equipment & Supplies
Fairly new toner and display reads "Install black cardtricge"
I have just resolved the "Install black cartrige" issue on my printer I am not sure if it will solve everyone's problem but these are the steps I took to solve the problem.
1. removed the black cartrige.
2. removed all the paper from the tray and noticed that one of the pages was a little jammed.
3. I then turned the printer on and off again and still encountered the "Install black cartrige" error message.
4. I then put the black cartrige back in the the printer and restarted the printer.
5. When the printer restarted it started to initialize correctly and I perform some test prints to confirm that it was back up and running.
Apr 07, 2009 | HP LaserJet M1522nf Multifunction Printer...
Xerox Phaser 7300DN will not collate
Try using the PCL driver from the Xerox website, rather than the Postscript one supplied with the printer.
I had the same problem and installing the PCL driver solved it.
Sep 27, 2008 | Xerox Phaser 7300DN Laser Printer
LED BLINKING
Replace the communication cable (parallel cable).
Dec 11, 2007 | Epson FX 1170 Matrix Printer
Lexmark X2500 All-In-One Printer Logo
530 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
