Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Picture appears blurry, duplicate images almost. Mostly around the outer edges.
    Genius:
  • 1,112 Answers
You need to have the convergence IC's replaced. Try going into your menu and look for Convergence alignment adjustment option, you should be able to move the red and blue cross hair on the screen, just follow the instruction on the set and see which on does not move, then have that one replaced. But I strongly suggest that you replace them both, as if one has failed the other is not far behind, and will cost you more to replace in the long run. Better to do some prevention now then have the same problem happen again in the near future. A good note to give the technician i you don't repair it yourself, If the unit uses convergence IC's part #STK-392-110, Have him or her install higher rating ones #STK-392-120 these will last longer.
Posted on Nov 15, 2009
Blurry picture grainy and some greenish color around edges this camera was given to me and the pictures that were already on it look great but when I take new pictures I gthankset these problems
There may be the issue with the CCD (image sensor device) of the Camera.
Refer this article to confirm this.
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT1&news_id=161
Check whether the LCD screen of the Camera looks similar as given on the page.
Ifyes,click on the "Yes" button at the end of the page to create anonline Repair Request for sending the Camera to the Sony FactoryService Center.
Aug 19, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
My images are blurry
check that you have not left it on close up settings ! micro
Jul 14, 2009 | Casio EXILIM Digital Camera
Blurry picture
Try adjusting the focus ring around the lens. Poor quality try adjusting room lighting or you may need to upgrade to a better webcam.
Jun 09, 2009 | Logitech 961462-0403 Webcam
Tv shows double images
Look for the convergence menu in the manual and try to align it.
Apr 02, 2009 | Toshiba TP55H60 55" Rear Projection...
Image blurry at edges
my dear friend, it appears that you must have opened the 3 lcd screws that are not supposed to be touched, if so then just forget reassembling the same as the convergence would be lost & cannot be manually done
another thing are the polarisers.if excessive dust had accumulated & if you used wrong technique in cleaning then the coating would have come off & you have lost everything , just change the entire lcd block.this costs a bomb.beter to buy a new projector
Jan 05, 2009 | Panasonic PT-AE900U Multimedia Projector
When i turn on my sony cybershot cam the vir=ew find shows stretched picture with washed out colour and blurry lines around image edges
It looks CCD Imager is defective.
Please mention model number of your Sony cybershot to help you out.
Oct 05, 2008 | Sony Cameras
Image reduced by dark edges
An adapter tube has to flare out at the end or it will cut the corners off at the wide angle setting. Telephoto should be ok though.
Dec 04, 2007 | Canon PowerShot A620 Digital Camera
Picture edges blurry
There is a setting labeled cropping... turn it on.
Nov 19, 2007 | Olevia LT32HVM 32 in. LCD Television
Red convergence out of range.
Replace STK393-570 convergence IC. located on center PCB.
re-check alignment........T.
Oct 24, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Color is not good around outer edges of picture
When the colors are off around the edges on a regular picture tube TV, it usually means that the degaussing thermistor's solder joints have cracked loose. Another possible cause is that a strong magnet, such as in a stereo speaker, was brought very close to the picture tube and has magnetized the tube. Resoldering the solder joints on the degaussing thermistor and demagnetizing the picture tube should put the color back to normal.
Aug 17, 2007 | Toshiba 32AF45 32" TV
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
103 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
