Question about Refrigerators
Freezer works fine. Refrigerator does not get cold
  • Refrigerators Master
  • 2,183 Answers
The freezer feeds the refridge side with cold air,when you open the freezer door do you hear the fan blowing,if not you have a bad evap fan motor,touch the back wall of the freezer,is there snow or ice on it,if so you have a defrost problem,you didn't send model number,is it a side by side,if you know where the timer is assuming there is one turn the knob on it slowly until the fridge shuts down,you put it in defrost mode by doing this,take the back wall off of freezer and see if heater came on,if it did you have a bad timer because it won't go into defrost on it's own,if heater doesn't come on you have to check the thermostat and the heater,you can cut the two wires going to the t-stat but cut them close to the t-stat body,now put the wires together and if the heater comes on you have a bad thermostat,the thermostat is cheap enough so it's a good idea to change it anyway,now you have done this without a meter but you should use one,if you have one read out the heater and see if it's bad,most likely it will be if you did everything so far,sometime the glass heaters read good but if you look at it and it's all black change it,if the heater is good you could have a wire problem,you should make sure power is going to the freezer section by checking the t-stat wires,also if there are water droplets on freezer ceiling or on the door the freezer door could of been left open and the air ducts could have froze up,if there is any ice you have to melt it out with hair dryer,you didn't give much to go on so i think i covered it all for you,hope this helps
Posted on Nov 16, 2009
I have a haier model # htq18jabww-01 and the freezer seems to b working fine but the fridge does not seem to be cold at all...any soultions??
The "Cold-to-Coldest" adjuster in the freezer steals chilled air from the refrigerator to add more to the freezer. It's a mechanical damper. Set it fully CCW to cold (warmest position). I also put duck tape over half the chilled air outlets in the freezer to increase the chilled air pressure feeding the refrigerator section. Set the thermostat in the refrigerator to 8 or 9 and the freezer works fine and everything in the refrigerator is 38F.
Apr 18, 2012 | Haier HTQ21JABWW Top Freezer Refrigerator
Freezer is working fine. The refrigerator is not
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 02, 2010 | KitchenAid KSCS25FKSS Side by Side...
The refrigerator isn't getting cold
the refrigerator part isn't getting cold. it was working but now its just room temperature inside. the freezer part works fine.
Jul 03, 2009 | Whirlpool Refrigerators
Freezer side of 690 does not work (not even cool); refrigerator side works just fine.
Check the fan in the freezer department. It has to run when the door i closed. Sometimes the door switch is bad. This causes the freezer coils to ice up so the cold air does not go through the coil to cool the freezer. Unplug the power cord for 1 hour or two hours. Then plug the cord in and see if the freezer gets cold.
May 15, 2009 | Sub-Zero 690 Side by Side Refrigerator
Fridge/Freezer combo - Freezer working fine but fridge is not
There is a duct between the freezer and refrigerator. Sometimes this duct blocks off with ice and won't allow airflow. Open your refrigerator door and check for air flow if there is none the duct needs to be defrosted. turn off freezer/ refrigerator and defrost.
Feb 24, 2009 | Hotpoint Freezers
Top Freezer section working Bottom Refrigerator not getting cold
I have a side by side jenn-air refrigerator, the freezer compartment working fine and making ice like it should, however the refrigerator compartmant is not cooling, no cold air is felt, I need advise.
Sep 28, 2008 | LG LRTC19314ST Top Freezer Refrigerator
hello, my refrigerator got the following problem; it works fine at the freezer but there is no cold in the frig, when i unplug it from the wall connection and after few time connect it again, it start working, after few hours, the refrigerator stop, the freezer is fine and very cool,but the frig is not cool and the refrigerator do not start working again, even after the freezer gets warm.Please i hope you can help me with this problem.
Sep 03, 2008 | Refrigerators
Refrigerators Logo
385 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
