Question about Candy 24 in. CD622 Free-standing Dishwasher
Can i use my candy aquaviva cd 622 dishwasher if i only have a cold water supply to connect to it - even though it has pipes to connect both hot and cold water supplies?
  • 835 Answers
I strongly advice against it, because the pumps are gonna assume thier is water their and is gonna try to pump the water in, and u will burn them up if their is no water their.. how ever you could get a splitter and run water to both hoses. even though their is no hot water you could run it. just need water going to both lines. your dishes how ever wont get as clean as they would if you had the hot water.
please rate this
Posted on Nov 15, 2009
Water is not being taken in on our candy Aquaviva CD 623 dishwasher
First check and see if there is plenty of water coming into the machine by examining the fill hose inself.
You likely will have to disconnect that hose, not at the machine end, the sink end.
Then, find a way to test the wires to the fill valve, should likely be 110 volts when the machine starts, allowing the fill valve to open.
A volt-ohm meter will tell you, set it to over 110 volts on the A.C. setting.
If no power to the fill valve, you may be facing a new timer.
Be blessed.
Jan 24, 2013 | Candy 24 in. CD623 Free-standing...
I need the operating instructions for a candy aquaviva cd623 dishwasher. Can anyone help with a pdf version I can download?
I am sorry to hear that you have problems with a candy dishwasher. I have had two or three pieces they just died of old age.
But seriously on line there is this manualsonline.com
You will most certainly find your candy manual there for downloading free.
Goodluck
kolbrun
Mar 24, 2012 | Candy 24 in. CD623 Free-standing...
Is it a cold water or hot water fill
It's your choice.There's only a single supply hose and with most dishwashers that means cold fill only, but as this is a compact basic worktop model the manual supplied suggests that users connect to a hot water supply.
In real-life situations though, the water drawn from the hot supply often isn't instantly hot so all you do is drain cold or tepid water from the supply pipe and let it get replaced with wasted hot water which then cools in the pipe! If the machine features condenser drying like many dishwashers, then cold water is essential for it to work. A final consideration is that unless your hot water is supplied at mains pressure (such as in a combi-boiler or megaflo system) then the water pressure from a hot water storage tank will not often be high enough and you'll have to use the cold supply.
Jul 13, 2011 | Bush DW5F 22 in. Dishwasher
Candy aquaviva plumbing
NO if it has two inlets then both are used buy a connector to connect both hoses together any diy shop will supply
Dec 20, 2009 | Washing Machines
Water Connections
In the US dishwashers are usually connected to the hot water supply. Although the ASKO 1850 I believe has an in line heater. Using hot water supply will reduce electrical useage.
Interestingly we use to have ASKO washer and it suggested only using cold water hook up as it heated its own water. I guess this was a feature if one's laundry area does not have hot supply, but it made no sense in CA to heat water with electricity.
Nov 11, 2009 | Asko 24 in. 1805 Built-in Dishwasher
Kenmore dishwasher. The upper rack is not getting clean. Even very light residue remains. And, detergent is left in door at end of cycle. The bottom is filling up, so I don't think it's the intake valve....
I find it odd that the dishwasher is filling with cold water if the water is hot at the sink. It sounds like the dishwasher is connected to the cold water line rather than the hot. Check under your sink; if you've got standard plumbing, the dishwasher supply line should be connected to the left water pipe.
Regardless, the water temperature doesn't fully explain the symptoms, especially the detergent left in the door (assuming you're using fresh detergent and it's not caking in the door prior to washing).
I would check the blades again. Even thought they may appear clean, there may be debris in them that get forced into the openings during operation, but fall away from the openings when the water flow stops. Remove the blades, run water into them, then invert them to drain while rocking back and forth. If there's crud in them, you may need to do this several times.
Sep 14, 2009 | Dishwashers
AEH Favorit 50730 dishwasher seems to work fine other than the water never gets hot. Is it easy to replace the heating element or whatever that could be faulty?
If this dishwasher is a residential dishwasher the water that is supplied to the unit is from the hot water side of the sink supply. The dishwasher does not heat the water it uses water from the water heater that is connected to the house. It sounds as if the dishwasher is hooked up to the cold water supply instead of the hot water supply. The heating element you see in the dishwasher is for drying purposes and not for heating water. I would check the hot water supply for your dishwasher to see if that could be the problem. Also remember unless you have a recirculating pump on the hot water there will be an amount of water in the pipe from the water heater and the dishwasher that has sat and cooled down over a period of time therefore when you turn on the dishwasher you will not get hot water immediately due to the distance the dishwasher is from the water heater. You will notice when you turn on the hot water to thew sink you do not get hot water right away you let it run for a minute before it gets hot since the dishwasher is connected to the same valve as your hot water to the sink it acts the same way.
Good luck on your repairs hope this helped.
Dave
Sep 02, 2009 | AEG 24 in. Favorit 50730W Free-standing...
Can i connect a dishwasher to the hot water pipe??
In my opinion you always connect to the hot water unless there's some compelling reason not to like your dishwasher's manual says to connect to cold. Your dishwasher will heat up whatever water you have connected it to, but since you have a tank of preheated water already sitting in your water heater you should use that.
The "resin in the water softener" example, I think, makes no sense since your dishwasher will heat up the water to something like 160 degrees Fahrenheit no matter if the input is cold or hot...
Jul 15, 2008 | Dishwashers
Candy 24 in. CD622 Free-standing Dishwasher Logo
Top Candy Dishwashers Experts
 Evgeniy_Getz
Evgeniy_Getz
Dado
Tom Chichester
Are you a Candy Dishwasher Expert? Answer questions, earn points and help others
