Question about Minolta Office Equipment & Supplies
Minolta copier 2050
Error c0072 - sub upper toner motor
  • Minolta Master
  • 6,674 Answers
OK CAREFULLY take out the toner bottle, then open close the front door, then power off the machine, wait 10 sec, then power the machine up with the toner bottle out, only add the bottle when it ask for toner
Posted on Aug 01, 2009
C0072 copy error
The error code C0072 deals with the toner hopper. I would remove the toner bottle and close the front door and wait till the copier comes to ready and make a copy, if it works install the toner and see what happens. The problem may be in the toner bottle holder.... There is a "HP" sensor that may be dirty or broken. Good Luck
Nov 05, 2013 | Minolta EP4000/5000 CS/PRO Copier
Minolta ep 5000 error c0072
A C0072 error code deals with the toner bottle. Remove the toner bottle and close the front door and let the machine warm up. Make one copy and install the toner bottle again. The toner holder may have not been in the correct position. If it continues, you may need to call a service person. Good Luck
Dec 07, 2012 | Minolta Office Equipment & Supplies
I have a pitney bowes copier model C350 giving me an error code C0072. What is this?
Sub Hopper Toner motor mechanism malfunction.Remove rear cover,pull out toner cartridge,Remove sub hopper unit fixed under main hopper toner assembly and change the sub hopper motor or the agitator levers gears.
Aug 11, 2012 | Office Equipment & Supplies
Code C0072
You did not give the model number? So, I'm going to guess, did you just add a new toner? If so remove the new toner bottle and close the door / cover and see if the copier comes to ready? If so, make a copy and when the copy is done install the toner bottle. The error code C0072 deals with the toner hopper motor. If the code will not clear, then you may have a broken gear in the hopper drive unit. Good Luck
Mar 28, 2011 | Konica Minolta Office Equipment & Supplies
I have received code C0072? what can I do to
The toner bottle is in wrong, take out the toner bottle and close the front door. wait until the motor stops running or until the copier asks for toner. open the door, the bottle should go in with the hole up.
Jan 27, 2010 | Minolta EP4000/5000 CS/PRO Copier
Minolta 6100 displays message C0072
Are you certain it is a Minolta 6100? The only 6100 I am aware of is a Magicolor 6100 color printer. My service manual for that model lists no service code C0072.
C0072 is a common Minolta copier code which pertains to the toner add system. I had a service call the other day for C0072 and it was the toner cartridge not fully "locked" in to it's receptacle, so you can start there. Opening and closing the front door on most Minolta's will reset this code.
Good Luck
Oct 21, 2009 | Minolta Office Equipment & Supplies
Minolta c0072 code, hopper or toner?
C0072: Sub Hopper Toner Replenishing Motor M9’s
Failure to Turn
Sep 03, 2009 | Minolta EP4000/5000 CS/PRO Copier
Copier Minolts ep4050 error code C0072 +
C0072 is aerror code for the sub hopper unit. It is having a hard time adding toner or that the toner motor is ON for to long. It is having a hard time kepping up with the ATDC. The M2 is a counter, it can be reset in service mode, but major parts have to be replaced to clear it..
Mar 25, 2009 | Minolta EP4000/5000 CS/PRO Copier
Copier Minolta model D1520
Remove the toner bottle and let the copier warm up to Ready, then re install the toner bottle and see what happens
Feb 07, 2008 | Office Equipment & Supplies
120 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
