Question about Rainbow E series Canister Wet/Dry Vacuum
Has lost suction power - Rainbow E series Canister Wet/Dry Vacuum
    Problem Solver:
  • 14 Answers
The "fan blades" will get clogged with a fine layer of "micro dirt" with each use. Scrubbing it gently with an old toothbrush and some 409/windex/fantastic will greatly improve the efficiency of the unit.
If it was a sudden loss of vaccum, check to make sure there is a good seal between the vac and the water canister. There is supposed to be a foam seal there on some (possibly all?) models. If that seal is missing, you will have almost zero vacuum.
Hope it's one of these fixes!
Posted on Nov 15, 2009
It has lost suction
Have you got suction just before the motor? How about air coming out the exhaust?
Mar 14, 2015 | Vacuums
I have a model DC3 rainbow thar has lost suction. what can i do to fix it
Check suction at intake without any hose connected. If that is good, then connect hose and check suction again. If that is poor, then you have a clog. If still good, then check power nozzle by getting into the belt area.
RainVac
www.rainvac.com
800-523-0510
Apr 01, 2013 | Rainbow E series Canister Wet/Dry Vacuum
EF 1750 has lost suction power. There is a noticable decrease in suction power even at the power unit inlet.
Disconnect the actual pipe where it meets the vac. Then test the intake for suction. If you have poor suction still, check the intake itself from inside the vac body for blockage, then check the gasket on the pail for mis-alignement.
If you have suction at the actual intake, your issue will be in the house piping. Look for any damaged inlet doors which are ajar, also look at any inlets you may have recently removed for painting or renovation work. Each inlet has an o ring seal which must be properly aligned. If not aligned you will hear a hiss at the inlet when the door is closed.
Last check where any exposed pipe or pipe joint could have been jarred loose or damaged, basement , garage, etc. Post back to advise what you find
Nov 06, 2009 | Easy Flo EF1750 Central System Vacuum
Dyson dc14 has lost suction
Down on the lower right hand side of the vacuum, when you're behind it, there is a little 'J' shaped piece with a purple clip on it. Tilt the vacuum up and unclip this. Usually, people who have these amazing vacuums will accidently **** up things like lollipop sticks/pens/paperclips/etc. that don't bend... and will stay in this piece. This should solve your problem.
Sep 05, 2009 | Dyson DC14 All floors Bagless Upright...
My old dyson lost suction. Bought a new one,
For your new machine that does not power on - call the Dyson helpline - your power switch may need to be replaced. They'll set you up with a repair dealer who will fix it for you.
Jul 15, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
My VAX Vacuum has lost ALL suction power. I've
vax power pet 1 filter keeps getting clogged up so dirt not going into cylinder
Jul 05, 2009 | VAX Appliances Vax X5 Bagless Upright...
It has lost most of its suction power...what to do?
clean all the filters if this doesn't help then check for blockages at head, hose and entrance to collection chamber
May 30, 2009 | Vacuums
Kirby Low Suction
Have you checked the fan? It is what creates the suction. If ok, then you may have a motor problem, sometimes they run but not up to speed, then suction is lowered when that happens.
Mar 08, 2008 | Vacuums
How to for Belt replacement and solution to suction loss
You say it lost its suction, then you also say this is plenty of suction power, seems you cant figure out the prob. Try cleaning the fan on the suction blower. The blades can get chocked with dust which will give you a reduced suction.
Jan 05, 2008 | Vacuums
Rainbow E series Canister Wet/Dry Vacuum Logo
175 people viewed this question
Top Rainbow Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
