Question about Tascam CD-A500 CD Player
CD player does not recognise some CDs. When placed in the drawer the deck displays "no disc" if another CD player is used the disc works fine
I found out that CD's not of the required thickness, see CD specs by Philips and Sony, will show the NO DISC message. Thickness supposed to be 0.05 " Other players are not that senssitive.
Posted on Feb 09, 2012
I have two of these Tascam CD-A500 players, and one more than the other has this problem of not reading some CDs that will play fine in other players. I'm starting to loose faith in this Tascam product. Anyway, seems the consensus is to open it up and check for dirty laser optics. If that doesn't fix the problem, then send it in for repair or scrap it and buy a different brand. I've not had this problem with any other brand CD player, but very suspicious that the same problem happens on BOTH of my Tascam CD-A500 units.
Posted on Apr 30, 2010
Cd mixer deck repeatedly ejecting cd
It may be a mechanical or optical detection of the disc being inserted.
The unit need to be seen by a Technician to determine what is wrong with the unit. Lens cleaning is not the first action I would take to resolve this.
Dec 05, 2012 | Audio Players & Recorders
Cd player wont accept cds
There is nothing you can do to repair this, you must remove the deck and send it out for repair at a factory approved repair station.
Aug 07, 2012 | 2007 Hyundai Getz 1.4
The drawers on the left side that hold 5 cds will not open.Only the drawer in deck B operates at all.All local electronic repair shops don't repair cd players/recorders.
I have the same problem and have just lived with the B deck for over a year. Just now with nothing to lose, I decided to open it up. I don't have a clue about the inner workings, but was on a mission to at least rescue the 3 discs that were held prisoner. I'm happy to say that not only did I rescue my discs, but I'm listening to a disc in tray 2 right now. All the trays now work. I don't know if my disc was jammed in the player or what the problem was, but it seems the act of removing the disc from the deck made all the difference. If you want to try this, take the 6 black screws out (top 2 on rear panel, 2 on left and 2 on right panel) lift the panel straight up to remove it. you'll see the white framework that houses the trays and the play deck near the rear. In retrospect I should have opened up the play deck first since that may have been the source of the problem. I suggest you try that. There are two tiny screws on each side of the framework. Not sure if you need to remove the two screws with the washer heads. I think they just hold the disc clamp head in place. Again, I'm trying to save you unnecessary work, but remove them if it still doesn't come off. Once you get the top of the deck off, you should be able to access your disc. Take it out, then plug in the player to see if the deck starts to operate. I was very surprised. The belts started spinning and I was hearing the startup sounds I hadn't heard in over a year. Hope this helps
Feb 18, 2010 | Sony RCD-W500C 5-Disc CD Recorder
3 Disk Rotary not working
Are you using a disk that the machine can recognise? Some disc players do not recognise certain formats, so it might be worth checking the discs or formats you are using.
Aug 07, 2009 | Philco (R) Capital CD Player
Player doesn't recognize most CDs - 'no disc' message appears.
Your player lens needs to be cleaned by a lens cleaner...
Feb 24, 2009 | Teac CD-P1260 CD Player
RCA RS2620 - CD works well ocassionally and then not at all
Simple solution - a CD lens cleaner did the job. $11
Feb 19, 2009 | RCA RS2620 Single Cassette Deck
Discs stuck inside CD Player. Screen says ''Reading.''
Try resetting the CD (Cambridge soundworks) by unplugging, then repluging. Then hold down the eject button while you turn on the power.
Nov 15, 2008 | Cambridge Soundworks 740I CD Player
Won't play CDs
in the manual it says that error 12 could be scrached disc or dirty disc the action it says to take is to clean or replace the disc(s). the last thing error 12 could mean is mechanical error, actions for that is to turn your key to the off position and wait for the power to turn off and when it does turn it back on and see if it works, if none of these work then i suggest that your player needs replacing. hope this works for you
Oct 02, 2006 | Pioneer DEH-1400 CD Player
NAD C521 discs not spinning
The CD player has a sensor that is supposed to detect when a disc is inserted and spin it up etc. yours might be the problem, either it has some loose connections (that you haven't noticed) or it simply misbehaves. Another thing could be the motor itself that somehow 'misses' the spin up signal and needs a 'manual' boost. The best solution in your case is probably to bring it to some lab.
Sep 14, 2005 | NAD C521 CD Player
Tascam CD-A500 CD Player Logo
377 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
