Question about Husqvarna Garden
H 50 REdiculous to get started
I get my husqvarna fixed at a shop and it runs for maybe 2 days, then it won't start and when it does it has no power.
  • dontbother10
    dontbother10 May 11, 2010
    Take it back!!! Take your fuel can with you!!! They may confiscate it!!! If authorized repair facility and they can't/won't fix it report them to Husqvarna!!! Was the shop a chainsaw seller/mechanic or a 4 cycle small engine shop? I use Stihl mechanics for all my saws... Never have a problem! Did you replace the fuel mix you had at home? How old is it?
  • 211 Answers
SOURCE: husqvarna 400 e series- I mixed the fuel 40-1 instead of 50-1
Hi
If you have good compression and spark at the spark plug try priming the engine(put some fuel mixture in the spark plug hole),set the carb adjustment(highh speed H=3/4 turn and lowspeed L=1 1/4 turn,turn the scews clockwise until the end and then set them.Try to start the engine.If it runs only the gas you puted inside the cilinder and then stops you have a fuel delivery problem to find and fix.First disassembly ,check and clean the carb.Then the fuel filter and the hoses.Let me know. best regards savumihai71
Posted on Feb 11, 2009
  • 4088 Answers
SOURCE: husqvarna 235e will not stay running
Take the saw back for warranty service. We have a Husky #435 that had starting problems when new last year--warranty service replaced the ignition module the first trip, then a little later, they replaced the carburetor--it has worked very well since. I suspect that Husqvarna has had problems with our ethanol blended fuels. Hope this helps!
Posted on Jul 14, 2010
  • 2239 Answers
SOURCE: 3 month old Husqvarna 235.
These machines have had issues with main bearing cages breaking up, this it turn scores the piston and snags the ring in, if there is a good spark and the plug is getting wet i woud whip the muffler off and take a look at the piston through the exhaust port.
Posted on Jun 14, 2011
Testimonial: "Took to dealer. in five minutes they showed me the piston through the exhaust port. PISTON SCORED. Blamed thing hasn't been used 20/30 hours. Thanks."
HansPP
  • 2510 Answers
SOURCE: My 435 Husqvarna chain saw
The carburettor is getting too hot and fuel is being blocked from feeding into the engine. Make sure that the carburettor is clean and has adequate cooling while the engine is running. If you still have problems withs starting, blow the carburettor cool or use a damp cloth to cool it if starting is a problem.
Posted on Jul 13, 2011
  • 2239 Answers
SOURCE: Husqvarna Model 51 won't start.
If you have a good spark, and there is fuel at the plug, the only things to stop it fireing up are a sheared flywheel key knocking the timeing out, or the engine has low compression due to wear or damaged piston and ring.
Posted on Sep 07, 2011
2012 Gilera Runner SP 50 loses power when warm
Hi, Moatez and the usual suspects are:
1. Severely drained or faulty battery.
2. Faulty regulator/rectifier or high output coil.
3. Faulty power valve, solenoid or installation.
4. Clogged air filter or exhaust.
5. Cracked or incorrect float level.
6. Float needle is not seating.
7. Faulty reed valve.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
ET4 50cc losing power when hot full throttle scooter forums com
Power Loss Help
Gilera Runner RST 50 SP Service Station Manual
Gilera RUNNER SP 50 2006 Parts
https://www.eumoppenomc.se/WebRoot/Ballou/Shops/moped/4E2E/640B/3A3C/9A86/C6E0/0A0C/05E9/B1B7/Manual_GILERA_Runner_SP_50.pdf
Jan 28, 2018 | 2011 Gilera Runner SP 50
Husqvarna 223L won't start
I would first take the spark plug out and see if the tip is wet, it could very well be flooded.
second of all I'd try putting fuel directly into the carb (if this helps you'll most likely need a carb kit or maybe even a new carb)
May 30, 2013 | Husqvarna 223L
1989 Ford 150 4cly truck will run fine then starts cuting off and dies out . . no one can fix it. in shop now. shop owner pay labor can not fix. in shop 50 days
Hi, Check fuel pump that it is running properly. Sounds like an electrical problem with the pump. Good luck.
Oct 29, 2012 | 1996 Dodge Ram
My husqvarna 128ld won't start
Do you have compression, good spark and is fuel getting into the cylinder.?
Oct 21, 2012 | Husqvarna 128LD 28cc 2-Stroke Gas-Powered...
Husqvarna weed eater starts , but blows alot of smoke & then stalls out
Rod, Carb. may need adjusted, try loosening gas cap and start to see if cap vent plugged, there is a in tank fuel filter that you could fish out and remove to see if it is plugged. If still not running remove muffler and clean spark arrester screen, if screen plugged the trimmer will do this.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Craftsman Trimmer starts then dies
How to Clean Spark Arrestor Screen on Small 2 Cycle Engine Quick Fix
How to Clean Two Cycle Two Stroke Engine Carburetor
Sep 06, 2012 | Husqvarna 128 LD Weedeater
I have a Hasqvarna 150BT blower that started to make a knocking noise at full power and has lost some power. Seems to start ok. Loss of power / rpm and knock are only ploblem?
I had the same issue with a Husqvarna 150 BT blower. Brand new ran through 2 tanks of gas and need to buy more gas , mixed 50 to 1 ratio 87 octane on new gas which was the same as what i was running and it started pinging and running like **** then stalled and would not start. took the plug out and it was fouled. cleaned the plug got it running again but still not good. This model comes with a NGK CMS7H plug which i replaced with a champion RZ7C and new gas 93 octane and lawnboy oil mixed 50 to 1 ration and now its running like a champ. I've had bad experiences with NGK spark plugs in the past and thought this may resolve the issue and it did. Hope this is helpful to anyone out there having the same issues. Also used some fuel stabilizer in the fuel mix, I hear this helps with the ethanol problem in the fall/winter gas.
May 13, 2010 | Husqvarna Backpack Blower 25cc, 140 Mph,...
Can't start husq. 261
Most all of these saws use a 50 to 1 ratio. However, i like to use a two cycle oil that has a TCW3 rating to it. This helps to fight again moisture and condensation when the saw isn't being used.
Jul 14, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
VS-50803 50" Mitsubishi No picture problem
Sounds like your picture tube has went out,, or maybe something simple,, to fix,, i would at least let a tv shop check it out ,, worth a chance ,, nothin 2 loose,, good luck
Oct 05, 2008 | Mitsubishi VS-50803 50" Rear Projection...
Garden Logo
51 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
