Question about Gigabyte GA-7DPXDW-P Motherboard
GA-7DPXDW-P motherboard will not boot or beep
    Guru:
  • 1,738 Answers
Make sure that power cord from the power supply is seated in good. If that don't make it boot or beep sounds like your board got toast by some surges.
Posted on Nov 15, 2009
I need to replace some of the 6.3V 3300ufd caps on the GIGABYTE GA 7DPXDW P DUAL MP SOCKEt motherboard or I need to replace the motherboard. What wattage soldering iron is needed, or where can I buy an...
Normal operating temperature for electronics is 400 deg. Use of silver solder is common. However, MB fixes are rare these days..but given the nature of your board I understand your desire to fix it. Dual boards are not cheap - especially when Tyan had the mrkt tied up. There is a good source for older high end equipment I have used....www.compuvest.com. good luck!
Jun 13, 2011 | AMD GigaByte GA-7DPXDW-P Dual Athlon MP...
GigaByte GA-8EGXR-P motherboard beeps when turned on - no video or BIOS - system does not boot
hi try to clean memory ram....clean it using eraser.....most of motherboard beep if memory not detected....or try other memory ram
May 10, 2011 | Gigabyte GA-8EGXDR-EL Motherboard
GA-K8VM800M MOTHERBOARD The problem with the board is that, initially it got the message that disk boot failure, after checking bios settings, still it got same message. I have changed the IDE cables...
Try making your hard drive as the first boot in the bios and just connect your hard drive only on the motherboard ( remove cd/dvd drive, etc..). Make sure your hard drive is detected in the bios. Then restart your computer again.
Oct 11, 2010 | Gigabyte GA-K8VM800M Motherboard
Hello, I recentily buy a GIGABYTE GA-EP45T-UD3LR motherboard, it workd great, but don't have the "beep" sound when boot, I test via software the internal speaker and it works, is this correct ?, I hear...
1 beep is the BIOS signaling all is well after testing components inside and attached to the pc. On newer motherboards it's heard only when you have something attached to the USB connectors . Do a simple test: boot with an connected USB device, like a running printer or an memory stick - you will hear the short beep as you were used to.
Apr 13, 2010 | Gigabyte GA-EP45-DS3L M-b- P45+ICH10, DDR2...
GA-MA785GM-US2H
You can find the manual here at Gigabyte. The appendix lists this information about beep codes:
Hope this helps you figure out what to do next. Thanks for using Fixya!
Feb 20, 2010 | Gigabyte GA-MA785GM-US2H Motherboard
GA-81RM Max RAM?
From the manufacturer's web-site:
http://www.gigabyte.com.tw/Products/Motherboard/Products_Spec.aspx?ProductID=1332
you can view the complete specifications, including the maximum RAM.
Nov 06, 2009 | Gigabyte GA-7DPXDW-P Motherboard
Gigabyte GA-945P-S3 short beep codes on cold boot. Tried reseating RAM, didn't help. system runs fine after beeping stops
Using the manual for the Gigabyte GA-945P-S3 MB. Go to page 71 & you'll see bios beep codes for your board: AWARD BIOS Beep Codes 1 short: System boots successfully 2 short: CMOS setting error 1 long 1 short: DRAM or M/B error 1 long 2 short: Monitor or display card error 1 long 3 short: Keyboard error 1 long 9 short: BIOS ROM error Continuous long beeps: DRAM error Continuous short beeps: Power error As you can see there isn't a code for three short beeps. When you boot your system try to pause your boot up screen. See if the bios is reporting the correct total of memory in your system. Bios codes from the link below. http://www.computerhope.com/beep.htm#05 3 beeps for the AMI bios code reports Base 64K RAM failure. You can test your memory. Go to memtest.org Scroll down the site to just under the three screen shots. Download Memtest86+ V2.11 You have a choice in making a bootable floppy disk or a bootable CD-ROM disk. Once completed you boot your system to the testing program. Memtest will check your system memory. This should help. Thanks for using FixYa! Mike
Jun 04, 2009 | Gigabyte GA-945P-S3 Motherboard
Trying to load raid drivers
I would suggest you slipstream your install to include the drivers.
have a look at this guide
http://www.maximumpc.com/article/How-To--Slipstream-your-XP-installation
Thanks,
Ekse
Feb 15, 2009 | Gigabyte GA-7DPXDW-P Motherboard
Gigabyte GA-7DPXDW-P Motherboard Logo
116 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
