Rebuilding PC I have transferred all parts of my PC from the manufacturer's slimline case to a standard case with a new quieter CPU fan.  It powers up for a few seconds and then shuts down.  Why might this be?  Can you help?
  • 4 more comments
  • charlie1000 Jan 09, 2008
    The PC is (was!) a Phillips Freevents, Intel P4, motherboard is gigaybyte 649-M3. (Have looked for motherboard schematic but no joy).
    Those two cables are connected as shown. The model number is LS-1500-UK
    any thoughts?
    I think so, there seems to be only one place it can go (that is the wire labeled "Power SW", right?). There is no label on the motherbaord but there appears to be only one connection on there which fits it.
    I have just done a bench test both with the old system (with old case etc) and the new system (with new case, new CPU fan and power supply). The old system came on for less than half a second, the new system for about 3-4 seconds.
    Any more ideas? Any help is appreciated
    Ok, i tried what you said with the old case, old power supply and new CPU fan.
    With just motherbaord and RAM, the CPU fan started and continued fine.
    When I connected the power to the CPU (the square connector with four pins, near to the CPU) it powered up for about 3-4 seconds then beeped and shut down.
    What does this mean? Is the new CPU fan not strong enough for the processor?
    Will do, I reckon that's the most likely problem myself aswell, thanks for your help
    Scholar:
  • 135 Answers
Are you sure you connected all the power cables from the power supply that need to be connected to the motherboard? Please tell me what motherboard and processor you're using so I can further assist you.
Posted on Jan 09, 2008
  • 2 more comments
  • Yonatan Horan Jan 09, 2008
    Your motherboard may require you to connect a cable that looks like this, in addition to the cable that looks like this. What's the PC's model number and who is it manufactured by?
    Are you sure you connected the cables from your case (ie. the ones that connect your power button to your motherboard) properly? If you didn't it could cause this.
    You moved the motherboard, etc. back to the old case and it wouldn't load? The problem is probably that you didn't connect something properly. In order to diagnose it you can try starting from scratch, that is, just have your motherboard connect to your power supply (without the processor, RAM or anything else) and to the case. Try turning it on. Then, if it turns on, try adding components one by one, until you find the one that's causing the trouble.
    The problem is most likely that you installed the CPU fan incorrectly. Try changing it around and looking at the directions that came with it. It may need to be tighter on the processor, or looser - I can't tell as I can't really take a look at it. :) Try removing the fan and putting it back on, making sure the thermal paste is aligned with where it's supposed to be on the CPU and mess around a bit. Eventually you'll get it right.
I have a hp slimline 3100. the cpu fan runs fast everytime i open a program or play a cd. it speeds up the slows down. sometimes it runs really fast, then the computer shuts down. whats going on?
This is an indication of overheating within the PC. Open the PC case and clean all the air vents. Take the heatsink and fan off the CPU and give it them a good clean. Put the heatsink and fan back on to the CPU and start up the PC. check that the fan on the heatsink is running smoothly.
Also, make sure the vents on the power supply are clear and the fan on the power supply runs well.
If you go into the BIOS setup, you may be able to monitor the fan and the CPU temperature.
Mar 18, 2011 | Computers & Internet
A fan is making a horrible noise
hello
if its the CPU fan is making loud screech noises, its time to replace it
if the power supply fan is making the noise, its time to replace power supply , 5188-2859 is HP part number $25-$40
CPU fan = 5188-3722 HP part number , costs about $40-50
please rate my service with 4 thumbs up
Dec 09, 2010 | HP Pavilion Elite m9510f PC Desktop
I have an Hp pavilion slimline s3100n pc and after a while, it just shuts off with no warning whatsoever. When I try to turn it back on, it just shuts right back off. It's like I have to wait for it to...
Verify your fans are for the CPU and case are moving. You can remove the Pc cover and turn on the Pc. Watch the cooling fan on top of your CPU heat sink, it should begin spinning when you turn on your PC. If it doesn't then with the PC unplugged, make sure the connector for the fan is seated properly. From behind the PC you should be able to feel the Power Supply cooling fan moving air. Either of these could cause your PC to over heat and shut down.
Aug 18, 2010 | HP Hewlett Packard Pavilion Slimline...
Very noisy fan
You can try using caned air. turn off and unplug the computer then used the caned air on the fan to blow out any dust. plug it back in and power it on and see if the fan is any quieter. If not then it could be that the fan is going bad and may need to be replaced. Most computers will have a coupl of fans, case fans, CPU heatsink fans, videocard fans, power supply fans, so you will probably need to open the case up to get to all of them and make sure they are clean.
Apr 12, 2010 | Acer Aspire E500 PC Desktop
I have an IBM ThinkCentre PC, that the CPU fans often spins on high, even when CPU is idling. I have used Dust Off spray to try to clean fan, but obviously have not gotten all the dust out. Is it possible...
Yes, you can take off the fan. They are usually screwed into the heat sink or are clipped to the mainboard on top of the sink. Just be careful if you do this as it's easy to accidentally pop off the cpu and bend some pins. You may want to invest in a quieter fan for both the cpu and case if you already have it out.
Mar 10, 2010 | Computers & Internet
My HP Slimline Desktop s3120n turns on and as soon as goes on it turns itself off.
it seems your computer needs cleaning and servicing, my advice is to open your pc and use dust cleaner,you can buy a can from any computer outlet, spray all the dust out also all fans,the heat sink on the CPU,make sure also the fan that is connected via the CPU,I believe dust has accumulated between the fan and the CPU,by this the cpu cannot read the from the hard drive all because of so many dust that has accumulate between the cpu, it hard to read the data from hard drive and CPU.
hope this work for you.
Jan 20, 2010 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
My cpu overheats
clean the cpu cooler slots and replace the thermal compound on the cpu ....make sure you clean off the old thermal compound .....only a thin layer of new thermal C will do all most see through ... hope this helps my friend
Oct 25, 2009 | Gateway 504GR PC Desktop
Won't Start
This happened to my to my HP Media center Edition PC. I'd have to unplug the power from the outlet, let it stop flashing and the power up again. It would run for a short time and then shut off with the annoying amber / blue flashing light.
I found it was a heat problem on mine - specifically, the CPU cooler. After shutting down and opening the PC, check to see 1) if the CPU fan is running smoothly and 2) if there is a lot of dust and dirt on the CPU cooling fan and heat sink (and rest of the case for that matter).
Gently clean / vacuum the insides of the case AND power supply as best you can. Carefully vac the fan blades and heat sink to clear the dirt and dust that prevents the heat from being blown away by the fans.
When complete, you might even want to take the PC outside and reverse the vacuum so that air can be blown into tight places in the case. A can og compressed air can do the job instead, too.
Reassemble and start up as normal. Good luck!
Sep 18, 2009 | HP Hewlett Packard Pavilion Slimline...
Cpu
The noise is coming from fan friction and vibration. Running compressed air through fan components can help reduce noise pollution from dust buildup. Brush-less CPU/GPU fans are significantly quieter than the brush-motor powered fans that come with some factory electronics. Furthermore, some computer cases are designed with noise reduction in mind; Antec designed cases are know for being one of the quietest because they use patented bushings to secure the computer hardware. Moreover, make sure internal wiring is free and clear of all fan blades.
Mar 11, 2009 | Intel D101GGC Motherboard
Rebuilding PC (2)
maybe the issue is your video card, try to clean your graphic card with an earaser.. rub the edge, an try to check your memory, clean it also..
Jan 10, 2008 | Computers & Internet
Computers & Internet Logo
114 people viewed this question
Alun Cox
David Payne
David Payne
