Question about Dell Inspiron 1525 Laptop
'battery not charging' at 8%. Please assist - Dell Inspiron 1525 Laptop
  • 569 Answers
This is a common problem. The issue is almost certainly a faulty power board, a small PCB that accepts the power input and also holds two USB sockets – located on the top left side of the PC near the screen.
If your machine is in warranty the solution is a Dell repair/replacement.
If out of warranty then you will need to replace the component, or have someone do it for you.
The procedure involves buying a new power board, (Part number 48.4W006.021, available from Dell or more cheaply on Ebay at about £35), and replacing the old component. This is a task you should only undertake if you are comfortable with disassembling you laptop right down to removal of the system board. Instructions can be found in the Dell Service Manual at
http://support.euro.dell.com/support/edocs/systems/ins1526/en/SM/index.htm
This is not difficult if you are competent at this type of repair, but I would not recommend it for someone that has not taken a laptop apart before.'battery not charging' at 8%. Please assist - c9938e3.jpg
Posted on Dec 14, 2009
    Problem Solver:
  • 19 Answers
Remove battery, clean the battery slot, put it back in, restart notebook, try charging again. if this doesn't helps then make sure proper power supply is coming or update the bios.
Posted on Nov 15, 2009
I have a Pride 4 wheel Go Go Elite Traveller Scooter. It generally works fine, but I will frequently get an 8 beep error code and it won't go after a stop. I merely turn the key off and then
BEEP CODE CONDITION SOLUTION
2 Battery voltage is too low to operate Charge the batteries fully until charger and
the scooter. any meters indicate completion.
3 Battery voltage is too high to operate Contact your authorized Pride Provider for
the scooter. assistance.
5 Solenoid brake trip. The manual freewheel Remove the key, then push the manual
lever may be in the freewheel position. freewheel lever to the drive position and
restart the scooter.
6 Throttle trip. The throttle control lever Release the throttle control lever completely,
may have been depressed while inserting then reinsert the key.
the key.
7 Throttle trip. Throttle potentiometer Contact your authorized Pride Provider for
fault or speed potentiometer fault. assistance.
8 The motor is disconnected. Contact your authorized Pride Provider for
assistance.
9 Possible controller trip. You may be Shut down your scooter for a minimum of
attempting to install the battery pack while several minutes to allow the controller to
the key is inserted or the motor controller cool. Or, try reinserting the key into the key
may be in overheat protective mode. switch.
What you may be doing is mis-counting the beeps and it may be 9 beeps or its 8 and you have a bad connection between the motor and the switch? Good luck!
Jan 19, 2015 | Pride Health & Beauty
Charging battery on Tablet which is totally dead
Depends on how long it sat for with no charge. LION batteries dont recharge from totally being dead if they are left discharged for long periods of time.
Jul 29, 2013 | Polaroid 7-in. Internet Tablet - Other
Hello, well my acer laptop model AO751h doesnt seem to be charging. I check the battery icon and it says "plugged in, charging" but it doesnt seem to be charging cause im sure the battery icon...
is this an older laptop, if so you might just need to replace the battery. or try a different charger before buying a battery. If you need anymore assistance im here
May 20, 2011 | Acer Aspire One AO751h-1211 (LU.S820Y.108)...
I talked via my Plantronics Explorer 340 all morning and when we went to a park walk, I get it off my ear and put it in my pocket (still working and connected) in order to put my little son on my...
This would usually happens only, if your BATTERY present is the BT headset is completely dry or worn out..
Try charging your headset for another 8 hours and try again, If its not charging you have to take it to plantronics service center to change the battery,
But mostly after charging for 8 hours, it would work.
Please revert me, if you need more assistance, i would be very glad to assist you more.
If you were satisfied with the solution please rate this sollution.
Thanks For using FixYa!
Vinod Kumar J
Dec 03, 2010 | Cell Phones
My iphone is not at all getting on..when i try to put charge it looks like charging but it doestnt do so..i was trying this for almost eight hoursss..please help.
Sounds like the internal battery is no longer working. A rechargeable battery only has so many cycles(time it can charge).
best to take it to an apple store and have them install a new battery. Also there are many of smaller local stores that are battery outlets that change all apple product batteries. Only thing is if you iphone is under warranty you have to take it to a apple store to be changed.
If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the solution. thanks and have a great day.
Aug 20, 2010 | Apple iPod touch
My garmin C330 was working fine now it wont charge or power up
You may need to have the battery replaced.
Contact Garmin Customer Support for assistance.
North America - Consumer Products
Monday - Thursday: 8 AM - 6 PM, Friday 8 AM - 5 PM Central Time (closed holidays)
US: 913-397-8200
US Toll Free: 1-800-800-1020
Canada: 1-866-429-9296
Feb 07, 2010 | GPS
LOw battery message on my C550 Garmin gps. I charge through my computer but it wont take a charge through the car. Charge will only last 3-4 days wjcorban@gmail.com
There may be a problem with your car charger. You may be able to find one on eBay.
Otherwise, you may want to contact Garmin Customer Support for assistance.
US: 913-397-8200
Feb 07, 2010 | Garmin StreetPilot c550 GPS Receiver
Won't hold charge
Dear Iblaze1136, Fri 2-20-2009 8:22pm EST (USA)
Batteries must be charged completely when they are new or they will never hold a charge right!
I'm assuming you never fully charged them when new and so they will never hold much of a charge!
The Solution is to replace the battery or batteries and charge properly (overnight or at least 8hrs).
I recommend Radio Shack for this!
jack
b306d28.jpg Let me know if I can be of further assistance!
Feb 19, 2009 | Nextar X3-03 Car GPS Receiver
Nokia 6680 charging problem
this is a common problem with mobile phones if the battery voltage drops to low the phone canot control the initial cherge remove the battery and charge out of the phone if you can or by a new battery which will have a small charge in and should allow you to cherge the phone normaly
Dec 14, 2008 | Nokia 6680 Handheld
Dell Inspiron 1525 Laptop Logo
47 people viewed this question
Alun Cox
