Question about Sony PlayStation 2 (PS2) Console
The gray layer power thing
Its makes the power work i opened my ps2 to look inside and it went off it doesnt look broken it just went off of the motor please help
  • vavamkii May 18, 2008
    i re-aligned the lens. (i have done this several times in the past before the console broke) i managed to fix my then current problem. while assembling it back casing and all, i severed what appears to be a gray ribbon connecting the outer shell of the console with its more delicate inside machinery. help me
    Genius:
  • 1,003 Answers
Go to www.richsplaystationparts.com look for your model to see where this part goes
Posted on Jan 13, 2008
DRYER GETS HOT BUT DOESNT TURN
hello, check inside of the door to see if the long pin has snaped if ok then the capacitor next to the motor may be faulty good luck
regards
shaun
Oct 25, 2010 | Dryers
Driving force pro ps2 not 900 degree rotation
I'm not sure what you mean with the 900 rotationg thing can you clarify?
May 25, 2008 | Logitech DRIVING FORCE FEEDBACK STEERING...
My ps2 is broken
The eye that reads the Disc has went out in it . Google PS2 Repair ...
Sep 20, 2009 | Sony PlayStation 2 (PS2) Console
My ps2 will not spin the disk
sounds like the motor is bad on it, your best bet would be to replace the drive cause you don't know what other kind of damage may have happened to the drive.The lasers I know you can get seperately but not the motor.
Sep 03, 2009 | Sony PlayStation 2 Slimline Console
Whirlpool quiet partner II top rack sprayer doesnt work
The top rack spray arm doesn't work because of low water pressure from the wash motor or it's clogged with debris.
If the top spray arm looks clear of debris, remove the lower spray arm and lower feed tube to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary (part # 8268383). If the motor gear is broken, replace the sump and motor assembly (part # 8535150). Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
Apr 03, 2009 | Dishwashers
Tailgate window doesnt work
It could be several things. Make sure the tailgate is latched all the way. The motor could be bad. remove the tailgate cover inside the truck. use a test light and have someone press the up and down button while checking for power at the motor wiring. If you have power going to motor on both sides ,the motor is bad. If you do not have power check for broken wiring or bad switches.
Feb 01, 2009 | 1993 Ford Bronco
PS2
There may be many problem that have occurred to make this happen, here is a list of the three most common:
  1. You MAY have a disc jammed into the PS2, making it impossible to open (and/or) close. This could have happened by someone accidentally putting one disc right on top of a disc that is in the PS2, and not taking the other game, movie, etc., out. How to fix? Best Buy, Circuit City. Another way this could have happened is: an earthquake, flood, SOMETHING, may have happened that made a disc fall out of the tray (while INSIDE of the PS2) and jam it up, to fix this, you have to do the same as the first option.
  2. The motor is broken, this is pretty self explanatory, the motor that makes the disc drive open and close is broken, solution? Same as before.
  3. Your PS2 has reached it's prime, and gone over the hill, sorry buddy. :(
I hope you found this helpful, sincerely- animation508 (youtube username)
Sep 23, 2008 | Sony PlayStation 2 (PS2) Console
Unread disks
1.just take the disk out for a min and give a good wipe and without spittin, blow inside the umd tray
The laser going bad is a pretty common issue with the drives, spindle motor could be all gunked up with dirt as well and cause that issue also.
or it could just be the laser. can also try and clean the laser lens.
Feb 07, 2008 | Sony PlayStation 2 (PS2) Console
When inserting a game disc it displays "disc error" or "no disc data" unless playing 3yrs games only ????
try going inside and dusting your ps2 that should help my ps2 was malfunctioning i thought i bought a small one and went inside my big one i found thatsdusting the thing will make it read disks better and faster and the thing wont go disk error
Dec 26, 2007 | Sony PlayStation 2 (PS2) Console
PS2 will not play DVD
Make sure the disk is compatible and not damaged.Try playing another disk and see what happens if you still do not get anything you may want to consider a xbox or 360 with remote control for dvds. Also check to see if ps2 has a remote for playing dvd disc. never worry!!
Jul 05, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
21 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
