Question about Nordic Track NordicTrack Treadmill, A2550
I need the bolts to attach the console to the frame
    New Friend:
  • 64 Answers
You can order from the manufacture iconfitness.com You will need your model number. It will give you a schematic of your mill and you can order the exact pcs you need.
Posted on Nov 18, 2009
Excessive wear on frame where lower control arm attaches
If your sure its stout It should be ok my? is what caused it has to be some thing louse or bent.
Apr 19, 2013 | 1999 Dodge Caravan
How do i put the nail pusher spring back in the hitachi framing nail gun
Remove all bolts holding the rails to the body of the gun (make note of the position of the parts as you take then off ). Slide out the pusher assmbly. If the spring is good (wound tightly and has the bolt hole), hold the pusher assmbly in hand and attach spring to body of gun leaving bolt loose. Slide the pusher back into the rails and attach rails to body of gun up against the bolt (snug down bolt and check spring action). Re-attach rails to gun. Some after market rails do not have the slot cut into front allowing easy install of spring (cut slot with dremel). Good luck
Sep 12, 2011 | Hitachi NR83A2S Framing Nailer, Full Head,...
Directions: Attach main frame to rear deck. Assemble by aligning the rear axle against the C shaped support at the end of the main frame, then rotate rear deck assembly so that the attachment bolt...
That's a carriage bolt, right? Maybe the square shoulder isn't seated in the hole. If the bolt is so short a washer uses up the available threads you would need a longer bolt anyway. That's all that connects the rear to the front. Maybe a visit to the hardware store?
For some reason the Parts List makes no differentiation between that bolt and the other 4 that hold the Rear Standing Deck to the Frame. Clearly the other 4 bolts would not to be as long or they would be protruding dangerously. Perhaps one bolt is swapped.
May 17, 2011 | Schwinn 12" Roadster Tricycle
Where do i find the ground wire
What are you trying to ground? If electronics, Any bolt attached to the frame of the car can be used as a ground. You can attach a closed loop metal contact to the wire and attach the bolt for a ground. Extra info, bolts that hold down your seats, firewall bolts and seat belt bolts are some common grounds.
Best Wishes and Good Luck!!
Apr 10, 2011 | Chevrolet 2500 Cars & Trucks
What's the easiest way to replace a front/top cracked motor mount bracket on a 1999 chevy malibu
u will need a floor jack, block of wood, assorted tools, and a torque wrench Turn off the engine and disconnect the negative battery cable. Gain full access to the engine mount. Support the engine oil pan using a jack and a block of wood. Remove the bolt that holds the engine mount to the frame. Lift the engine and mount off of the frame using the jack. Once raised, remove the bolt that holds the mount to the engine. Remove the engine mount.
Attach the new engine mount to the engine with the original bolt. Lower the engine. Attach the engine mount to the frame. Tighten all mounting bolts to the manufacturer's specifications. Reconnect any components that may have been removed. Test drive the vehicle to verify the repair.
Mar 19, 2011 | Chevrolet Vehicle Parts & Accessories
Remove and replace Front Sway bar
Hello ggagne.
Here is the procedure.
  1. Raise and suitably support the vehicle.
  2. Remove the left tire and wheel assembly.
  3. Remove the pinch bolt from the lower intermediate steering shaft
  4. Loosen all insulator clamp attaching bolts.
  5. Place a jack stand under the center of the rear frame cross member.
  6. Remove the rear frame-to-body bolts.
  7. Lower the rear of the frame just enough to gain access to the stabilizer shaft.
  8. Remove the insulator clamp bolts and the clamps from the frame.
  9. Remove the insulators from the stabilizer bar.
  10. Remove the stabilizer bar links from the control arms.
  11. Pull the stabilizer shaft rearward.
Installation
  1. Insert the stabilizer shaft to the left side of the vehicle. Important: DO NOT tighten the stabilizer link nut at this time. The weight of the vehicle must be supported by the control arms such that you can obtain the vehicle design trim heights before tightening the link nut.
  2. Loosely install the stabilizer shaft link at the control arm.
  3. Install the insulators on to the stabilizer bar.
  4. Connect the insulator clamps to the frame.
    • Tighten the stabilizer shaft bracket bolts to 48 Nm (35 ft. lbs.) .
  5. Raise the frame into position while you guide the steering shaft onto the gear.
  6. Install the new frame-to-body attaching bolts.
  7. Remove the jack stand.
  8. Install the pinch bolt and tighten.
  9. Install the left tire and wheel assembly.
  10. Lower the vehicle.
  11. Support the weight of the vehicle by the control arms.
  12. Tighten the stabilizer link nut.
    • Tighten the stabilizer shaft link nut to 23 Nm (17 ft. lbs.)
There you are, I hope your job goes well.
Thank you for using FixYa.
KL
Nov 13, 2010 | 2002 Buick Century
How do i install a new dash for 83 mazda rx7
Instrument Panel and Pad REMOVAL & INSTALLATION
  1. Disconnect the negative battery cable.
  2. If so equipped, unfasten the inside hood release handle.
  3. Remove the steering wheel and the lower steering column cover.
  4. Remove the glove box, switch panel and console. Fig. 1: Loosen the retaining nut to unfasten the inside hood release handle 85810013.jpg
    Fig. 2: If necessary, remove the dash mounted speaker covers to access hidden instrument panel bolts 85810003.jpg
    Fig. 3: Due to space limitations, some bolts are best removed with an open end or box wrench 85810004.jpg
    Fig. 4: Other bolts are easily removed with a socket 85810005.jpg
  5. Remove the meter (gauge) hood, heater control panel mounting screws and separate the heater controls from the instrument panel frame. Remove the combination meter.
  6. Remove the air duct(s) and the steering shaft mounting bracket bolts. Allow the column to lower.
  7. Disconnect and label the meter wiring. Unfasten the mounting bolts and remove the crash pad and instrument panel. Fig. 5: Some of the instrument panel attaching bolts are hidden behind removable trim covers or plugs. Carefully pry off the cover . . . 85810006.jpg
    Fig. 6: . . . then remove the bolts with a socket 85810007.jpg
    Fig. 7: The glove box must be removed to unfasten some of the instrument panel retaining bolts 85810008.jpg
    Fig. 8: Other retaining bolts are accessible with the meter hood and combination meter removed 85810009.jpg
    To install:
  8. Position and fasten the crash pad and instrument panel, being careful to route the wiring correctly. Attach the meter wiring to its appropriate connections.
  9. Raise the steering column to its normal operating position and install the steering shaft mounting bracket bolts. Connect the air ducts.
  10. Install the combination meter. Install the heater controls into the instrument panel frame with the mounting screws. Attach the meter hood.
  11. Install the console, switch panel and glove box.
  12. Install the steering wheel column cover and steering wheel.
  13. If applicable, attach the inside hood release handle.
  14. Connect the negative battery cable.
Nov 05, 2010 | 1983 Mazda RX-7
Replacing sway bar. cannot get new sway bar to propper position. how do i get it to fit propperly?
Your old sway bar made of tubular steel. New sway bar made from solid steel. You have a frame under engine the sway bar attaches too. This frame also supports your engine and trans mounts. Follow frame and there are 4 bolts securing same. Mechanic I watched supported engine underneath. Loosen back bolts though not removed. (please note sway bar has arrow that bar can only go in one direction) This maybe your problem. Attach bar to frame and fitting's. Best if you raise front end and remove both tires. Good luck
Feb 15, 2010 | 1999 Pontiac Grand Prix
My Coleman Powermate 5500 is lose inside its frame
Rubber feet normally attach via a bolt or screw through the center of the foot. Look for a bolt or screw were the feet use to be. The rubber may have torn free, so you may need to glue or replace the feet.
May 31, 2009 | Coleman Powermate Powermate 5000W...
Removing engine
Yes it does. The R&P is attached to the subframe of the car. When you undo the rear sub frame bolts be sure to have a jack under both sides of the sub frame to support. The R&P is bolted to the sub frame and so is the engine.
Sep 29, 2008 | 1999 Mercury Sable
Nordic Track NordicTrack Treadmill, A2550 Logo
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
