Question about Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television
Vga cable connects TV to HP laptop...then what?
I tried connecting my Aquos HDTV to my HP laptop with a vga cable...Do I have to configure something specially...or what should I do next to make things work?..Nothing seems to happen re: TV as monitor.
Thanks
  • 405 Answers
You have to enable VGA port on the laptop. Press Fn + F5.
Posted on Nov 15, 2009
How do you hookup a computer to the tv
connect to VGA port with VGA cable. if no VGA port, buy a VGA to HDMI converter cable
Aug 12, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Can I hook up my Toshiba laptop to my Sharp Aqous TV, if so what connections do I need, ?S-video? I have an SGA connection on my laptop but not on the TV?
If this is the exact model Sharp Aquos television you have then you would have to have a laptop that has hdmi or dvi. You can try S Video on a laptop but the laptop's resolution would have to be so low that most laptops cannot accommodate this. You're right; this television does not have a VGA (RGB cable) input.
Nov 02, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I am trying to connect Sharp Aquos with laptop using a VGA cable. I know how to change the display on my PC, but my TV will not recognize the input. I have tried to use the input button on my remote, but...
USE HD CABLE which is available in the market by which you can attach your laptop to your television and all the instruction are written in the instruction book. how ever if you notice the socket in your television thesse are more similar and built for HD cable
Oct 30, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a Sharp LCD TV and a Toshiba Satelite laptop. I have never had any problems connecting my laptop to the tv using a vga cable. It isn't working anymore however. I checked the cables and...
I would check the video setting on your laptop. The resolution or refresh rate might have been changed and the LCD TV might not be able to process the signal. Try changing the laptop's resolution to the lowest setting(right-click on desktop and pick properties) and see if the TV produces a picture. Also verify the video output on the laptop is working by hooking it up to a computer monitor if available.
Jan 09, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
HDTV won't diplay/detect input from my Acer Laptop
A u sure u have extended windows desktop or put it in to clone mode. maybe u haven't selected proper source on TV. just try with something besides TV maybe cable is too long or not working.
Aug 29, 2009 | Acer Computers & Internet
Trying to connect my laptop to Hdtv with vga wire?
Ok, 14-pin is for really OLD VGA. Your cable will simply NOT work. Find a S-VGA cable (15-pin) and you are on your way to fame. By the way, make some room trashing that old cable.
Apr 18, 2009 | HP Pavilion dv9700t Notebook PC
VGA and Audio cables connected to PC but no audio through TV
if your tv has vga input there should be a "line in" input very near it. VGA can only get its audio source through a "line in" connecting to the coaxial audio inputs will apply the music stream to a different video input on your tv. your tv has video 1, video 2, vga, and so on, but the vga cannot show video and then audio from the video/audio coaxial inputs. you will need something like a dual male tipped 3.5mm audio connector.
Good luck and pls rate this post
Mar 16, 2009 | HP Pavilion dv2000t Notebook
Connect Laptop to TV
It depends on what kind of TV you have. If you have a flat-panel LCD or plasma TV, it may have a VGA connection already installed. If that is the case, all you need is a standard VGA cable to connect from your notebook to your TV.
If you have a TV without a VGA connection you will need a scan converter to convert your signal from VGA to RCA or composite video signal. These can be purchased online or from electronics stores like Radio Shack. You plug your VGA connection from the computer to the scan converter, then RCA or composite video cables from the converter to the TV.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 16, 2009 | HP Compaq 8510p Notebook
How do I connect my HP Pavillion dv9700 laptop with my Sony TV KV 32HV600? TV has DVI-HDTV-In and s-video with 4 holes. My laptop has s-video with 7 holes, another port with three rows of five holes, and...
You need s-video cable or VGA cable (if VGA ports are available on your laptop and TV) to connect your laptop to the tv.Connect the one end of your cable to your laptop port and another end to the tv port.and then set your tv to s-video mode.
Thanks
Mar 03, 2009 | Computers & Internet
Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television Logo
639 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
