Question about Meade DS-2114 ATS (325 x 114mm) Telescope
Autostar wont turn on
Purchased a DS2114-at-tc, assembled it and placed new batteries in - flipped the switch on with the Auto star attached-nothing. Returned it to Sams to get a replacement - same problem. Please help!
I had the same problem and I wiggled the wires that attach to the battery box and found that it had a bad connection.
Posted on Dec 20, 2009
  • 3,186 Answers
Unless Sam's has a batch of all bad telescopes???? Check that you put the batteries in correctly. You may have one or all reversed?
and or try a separate 12 volt power source if they included a cable. If not return the scope again!
Posted on Nov 16, 2009
ETX-80 hand controller say's "Self Check Failed"
You may need to reload the firmware by following these instructions for Safe Load:
From the Autostar 2.0 README file: "SAFE LOADER MODE IN YOUR Autostar:
If the firmware in your Autostar crashes and you cannot access the "DOWNLOAD" menu item on your handbox, you can use the "SAFE LOADER" feature of your new Autostar software (version release 1.1G and above). To get into the safe loader, follow these simple steps: 1. Make sure the Autostar and ETX are turned off.
2. Press and hold the "ENTER" key and the Scroll Down Key located to the right of the help key on the Autostar handbox.
3. While depressing both keys, turn on your Autostar power switch. This will require you using both hands.
You should see "FLASH LOAD READY" on your display. This indicates that you can proceed to Update new software to your Autostar."
This is for the 497 controller. There is NO safe load for the 494 controller.
Nov 01, 2010 | Meade ETX-80AT-TC Telescope
Lz200gps doesn't boot and I can't communicate via com1
Before you panic, try a new hand controller cable. You can buy these from Meade or for a better one from www.scopestuff.com
"Autostar II: if you need to use Safe Mode to recover from a disaster,
turn on the telescope, and key 999 before it says "Initializing"
The Autostar will say "Flash Load Ready"... now go start the ASU.
Read this page all the way through--
http://www.weasner.com/etx/autostar/guide-asu3x.html
Jun 02, 2010 | Meade LX200GPS Telescope
Nothing seems to work on my LX90
You may need to purchase a new hand unit.
go to meade.com for purchase.
May 15, 2010 | Meade 8" LX90 LNT Schmidt Cassegrain...
Meade/auto star problem
You never said what model. The CD ROM only contains free planetarium software which you can also down load on Meade's web site here:
www.meade.com look under the Customer Service link.
Motor Faults are usually caused by low power and or a broken part.
If you have CALIBRATE MOTORS feature in the hand controller do this first. If it still does not work, RESET the hand controller, reenter date, time, and SITE, and calibrate motors again.
If this does not work something is broken inside the scope.
Apr 18, 2010 | Meade 80mm Refractor Telescope
How do i use my meade DS2114 ATS-TC
Here is the manual:
http://www.meade.com/manuals/TelescopeManuals/Reflectors/DS2000%20manual.pdf
Read it TWICE! Then Calibrate Motors using the same power source you will use outside at night.
Then Train the drives, then enter time, date, daylight savings time =NO right now.
Do a two star automatic alignment.
Jan 03, 2010 | Meade DS-2114 ATS (325 x 114mm) Telescope
Etx-ls update to 1.2g failed, how to i restore or try the update again the autostar iii handbox does nothing
Easy.
If the firmware in your Autostar crashes and you cannot access the "DOWNLOAD" menu item on your handbox, you can use the "SAFE LOADER" feature of your new Autostar software. To get into the safe loader, follow these simple steps: 1. Make sure the Autostar and ETX are turned off.
Oct 08, 2009 | Meade Optics
Best out of 3 Telescopes
Hi Glenn
I would recommend the DS2000 should be DS2114 AT. The AT
refers to the use of the autostar hand box. This is a helpful tool for the beginner. Once you learn how to align the scope the computer will guide you around, helping you become familiar with the orientation of objects in the sky.
Nov 29, 2008 | Meade Polaris 114EQ-D (36 x 114mm)...
Autostar
Double check the cable from the Autostar to the telescope. Sometimes the ends go bad. They can be replaced with regular telephone cables.
Aug 29, 2008 | Meade ETX-125EC (500 x 127mm) Telescope
Meade DS-2114 ATS (325 x 114mm) Telescope Logo
108 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
