Question about Hitachi Televison & Video
Hitachi projection tv showing double
We have a 46 inch i believe hitachi projection tv and it recently started showing two of everything, towards the top half of the tv and its shadows are in bright pink and green. Any idea how to fix this?
    Scholar:
  • 101 Answers
This sounds like a convergence problem. Not sure but, the IC's are STK 392-110 or the last three digits could be 150, 570, ect... These IC's look black and about 3 in x 2in and have 12 to 15 pins. They will be mounted to a heat sink (a piece metal) They will be screwed on or a metal tab clip holding it on. Look on the IC for the numbers, then you can order the right one for your set . Hope this is helpful.
Posted on Dec 01, 2009
Hitachi 46f500 46 in problem double picture end two collor
This is symptom of convergence output chips failure in rear projection tv, replacement of convergence output chips will fix the problem.
Chips/ IC replacement requires soldering work in circuit board, if you are not familiar with electronics stuff fixing an soldering work, call local tv repairman to help you.
Thanks.
Oct 26, 2010 | Hitachi 46F500 46" Rear Projection...
What are the best video settings for a Hitachi (46GX01B), 46 inch, rear Projection TV (from 2001) in regard to: contrast,brightness, color, tint, sharpness, etc. The setting level goes from 1% to 100%....
The best setting are the ones you prefer the most.In general most sets are optimized for 50% on color and tint and usually 70% or more for bright and contrast.
Nov 08, 2009 | Hitachi 46GX01B 46" Rear Projection...
Colors have seperated on tv, and curve
You have a convergence problem.
Maybe need change the IC of convergence, or the power supply of these parts.
Bye.
Apr 04, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Hitachi 50 inch projection tv
Convergence ICs replace them bot 2 big black ics STK392-560s not sure what your STK numbers are but use same number to order parts call Electronix Parts 1-800-223-3205 PS if they are using 110s use 180s if 020s use 040s better ics.
Dec 19, 2008 | Hitachi 46F500 46" Rear Projection...
Tv looks green and bowed, also has double image
your tv is having a convergence problem, nothing you can do aloneyou wll need to call a tech, there must be 2 bad ic and some resistor burnt
Jul 30, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Philips 46-inch Rear Projection with bowed image?? slight distortion
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jul 02, 2008 | Philips 46PP9302 46" Rear Projection...
My Hitachi 43" HDTV shows double vision with shadows on people and words> I have tried to adjust everything with the remote but that does not work. Maybe there is a remote feature to fix this that I dont...
Is it a rear projection tv? if it is, then the problem is the convergence board. convergence ic need to be replaced. and this can be done by an experienced technician or if you are good in soldering, you can do it yourself.
Jun 06, 2008 | Hitachi 46F510 46" Projection HDTV
46 inch rear projection tv
The convergence modules are bad. They are made by SDK. ShopJImmy has them. Buy the kit because it has resistors and fuses that you may need to replace too. TV Parts Universal TV Stands DLP Chips ShopJimmy
May 23, 2017 | Hitachi 55FX48B 55" Rear Projection...
Hitachi 53UWX10B Projection TV colors not lining up...
This is a convergence issue..both chips need replacement.
Dec 14, 2007 | Hitachi 53UWX10B 53" Rear Projection...
Televison & Video Logo
83 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
