Question about Bob Mackie Onyx FireWire Sound Card
Got no conection betveen the firewire carc and the pc. Tryed several different cables and mixers, stil no conection...??
Got no conection betveen the firewire card and the pc. PLEASE HELP
Posted on Aug 01, 2010
    Guru:
  • 1,738 Answers
It is the unit.
Posted on Nov 15, 2009
Mackie 402VLZ4 4 how to connect to pc
It depends on what I/O is available on your PC. If it has an analog input (typically a stereo 3.5.mm connector), you can connect that to the mixer's Tape Out connections (cable needs 2 RCA plugs on one end, 1 3.5mm stereo plug on the other).
If the PC only has USB or Firewire connections, you need a computer interface. Something like an M-Audio M-Track or PreSonus AudioBox USB. Connect from the mixer Tape Out to the line inputs on the interface. Connect USB (or Firewire) from the interface to the PC.
Jun 30, 2014 | Mackie 402VLZ4 4-Channel Ultra-Compact...
My iphone 3gs will not charge or conect to itunes
REplace your data cable.If not working that also.... check you port of iphone.And try different USB port.
Thanks.
Feb 18, 2013 | Apple iPhone 3G
What exactly do I need to connect a Mackie 402-VLZ3 to a Macbook Pro ? Where can I buy the cables? Thanks!
The internal audio systems in the PC's are inadequate for high quality work. You should get an external audio system that attaches via firewire or USB to your MAC. Then use balanced cables from the mixer to this audio interface. There are MANY different audio interfaces... Search the music equipment suppliers in the "recording" section of their catalog...
Feb 10, 2011 | Mackie 1202vlz3 12 Channel Mixer
The Onyx Firewire card installed in the 1620 mixer is sending a low left channel signal back to the mixer. It use to work fine but not anymore. I have this same problem on my Mac tower G4 and powermac...
Hi there and welcome to FixYa,
Try a different Firewire cable, there maybe noise issues on the cable making it difficult for the signal to pass through. If it still fails, try unplug-replugging the firewire card. Re-install the driver.
Also, for a quicker solution to that, try cleaning the contacts with WD40 or an electric contact cleaner. Replug the cable in and out... make sure as well to check that your left channel is indeed passing signal to the Mackie processor.
Hope this helps
Dec 25, 2010 | Bob Mackie Onyx FireWire Sound Card
Everything seems to be fine, but
If you have tried it on several computers, then it seems there is something wrong with the HD or its cable. Are you able to use another USB cable with it to see if that fixes it? I'm assuming the power light is on, and you can hear the drive spinning?
I bought an external drive about 2 years back. It worked beautifully but close to a year after purchase stopped working. Being a technician, I removed the drive from the case and connected it inside my PC where it still works fine. The USB circuitry in the case had failed, not the drive, which was good for me.
Apr 11, 2010 | Seagate Maxtor 750GB One Touch 4 Plus...
What i need to conect my mixer on my pc
You need two cables to connect your L/R line output from your mixer at the two inputs of FCA202 (the numbered 1,2) and one firewire cable to connect from FCA202 to your pc's firewire port.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Feb 04, 2010 | Behringer F-CONTROL AUDIO FCA202 External...
Can i copy mini dv tape items to pc through usb conectivity to computer
Generally not. You will need a firewire cable to connect through DV. The connections are different shapes than USB. You will also need a firewire connection on your pc.
Hope this helps.
Jun 06, 2009 | Canon DV-MV830i Mini DV Digital Camcorder
Which cable do I need to conect my camcorder to pc
if you need a visual on it, there is a video on www.HandBookLive.com under Electronics. The example is Belkin IEEE 1394 cable (Firewire and I-Link compatable) and it connects digital camera to a laptop.
May 28, 2008 | Sony Handycam CCD-TRV78E Camcorder
JVC GR-D275 not seen as connected to computer
Many Camcorder users have faced problems while connecting their camcorder to their PC. One of the most common problems is ?no activity? after connecting the camcorder to the PC. The found new hardware wizard does not run and fails to detect the camcorder. This can mean two things. Either the DV port on the Camcorder is not working or the FireWire cable is faulty. Try using a different FireWire cable. If the camera is still not detected by the PC, try connecting it to a different PC. If the Camcorder is still not detected, then your camcorders DV port is most likely at fault. Confirming that the FireWire Port on you PC is working fine You can check the status of the FireWire port from under Device Manager. To access the Device Manager, Right Click on My Computer and then click on Properties. Select the Hardware tab and click on Device Manager. If you cannot see the FireWire port in the list, then it is not inserted properly into the motherboard. If you see a Yellow exclamation mark, then you need to install the drivers, which are usually bundled with a Floppy or CD with the FireWire card.
Dec 21, 2005 | JVC GR-D275 Mini DV Digital Camcorder
Bob Mackie Onyx FireWire Sound Card Logo
188 people viewed this question
Top Bob Mackie Computers & Internet Experts
David Payne
David Payne
Are you a Bob Mackie Computer and Internet Expert? Answer questions, earn points and help others
