Question about Dryers
Fan is not turning (fridge and freezer not cooling) can you help me
  • matlock_mich May 11, 2010
    Sounds like you need a hard start ask your local parts house for one.If its not cooling then the compressor is not pumping.the freezer will get cold without the Fan.
  • 3,463 Answers
If the fan is not working, you need to check to see if the fan is getting an electric feed to it, if not, then prob is elsewhere.
If it is, then fan is probably faulty, and would need replacing.
Please rate my comments.
Thanks.
Posted on Nov 16, 2009
Fridge not cooling
Your description is quite complete but is rather baffling. Pls bear with me while we process by elimination. A few basic/working ideas:
  • most designs call for a single compressor to cool the freezer;
  • the cold air in the freezer is drawn towards the fridge to cool that area;
  • this is performed by a fan drawing air in the freezer through the evaporator;
  • most would have a vent or air pathway to guide the freezer air;
  • all would have thermostatic control to set the desired temperature;
  • some designs have two thermostatic control , 1 for the freezer, 1 for the fridge.
As applied to your concern:
  • compressor is working since freezer is OK;
  • fan is working as you posted but is the air drawn from the freezer, better still, is the air forced/vented into the fridge?
  • could you please check that the air is strongly blown into the fridge area;
  • a little experiment, open the fridge door, look for and press on the door switch, the light should go out, after a lengthy seconds, the fan should trigger on, not only would it be audible, you would notice the frozen air swirling inside the fridge area. If you hold on long enough to the dorr switch, the compressor should kick in (if it is not already running) since the thermostat of the fridge area (if one is present) would sense that the fan is turning but the fridge area is not cooling.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 02, 2008 | Refrigerators
MY Frigidaire Refrigerator is 2 years old, the Refrigerator is not cold, but the freezer is working fine, what is common fix?
Most will tell you the freon is bad. but i have found in most cases the freezer works but fridge doesnt.. I have found the solution to be a bad cooling fan on the fridge it self. if the fan is not cooling the fridge will not cool. You could pull the fridge out and see if you can see the fan turn it on hi and when the fridge kicks in see if the fan or fans are working.. dust can cause them to slow or stop.
Jan 06, 2015 | Frigidaire Refrigerators
Whirpool wgi fridge freezer, fridge not cooling?
Most frideges get all their cooling from the freezer. There will be a fan and duct in the back of the freezer that pushes cold air down into the fridge. If the duct is blocked with ice or the fan motor has quit. Your freezer will work fine but the fridge will barely cool at all. Check that the fan runs when the compressor is running, ( turn both temp knobs to the highest cooling and leave door open until comp. comes on). If the fan runs your duct is plugged. If not you need a new " Freezer Fan Motor". Most are simple to replace and cost around $100.00.
Jan 01, 2012 | Whirlpool Refrigerators
My frige is not cold, just cool, turn the T stat to coldest & no good. The freezer seems fine & I looked in the back & the fan is running. It doesn't seem to be blowing cold air or...
Two thoughts. If the fan is running... and you can here it in the freezer when it is on. Then the fan is fine and it is the mixer control. IF the fan is not working, then fix the fan.
The mixer control is in the top of the fridge where the air comes out on the wall between the fridge and freezer.
I think maytag calls this a cold control / damper.
Basically it controls the air flow rate between the fridge and freezer. When it is opens it allows air from the freezer into the fridge and cools it off.
Hope this helps.
Jun 17, 2010 | Maytag MSD2756G Side by Side Refrigerator
Fan is not working and fridge is not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
ARHGADF
Jun 03, 2009 | Amana ARB2557CSR / ARB2557CSL Bottom...
Fridge not cooling
evidently the fan that runs in the freezer and blows air into the main fridge has a circuit issue or the fan is frozen, but if the bulb does not work then its a circuit issue. likely on the same circuit as fan.
Mar 20, 2008 | Refrigerators
Dryers Logo
42 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
