Question about HP DesignJet 450c InkJet Printer
HP design jet 450C inkjet Media Error`
Hi
Iam facing problem with Hp Deskjet 450c, it is showing media error even after properly aligning the paper properly in the plotter.
Any sugguetions pls
Thanks in advance
N. S.Rao
Mail: sudhakararaonlr@yahoo.com
  • CADASH Jun 12, 2008
    I TRIED THICKER AND THINNER PAPER BUT NOTHING WORKS THE MEDIA LIGHT KEEP COMING ON.WHERE IS THE PAPER SENSOR AND HOW DO I REMOVE IT TO CLEAN IT.
  • Anonymous Dec 09, 2008
    Media light is flashing. Have cleaned and lubed, have referred to the manual and run the sensor tests. I am stuck - is there any way around this?
The pen cassette slide bar (aluminum) is dirty. Wipe it clean. Lube it. I used a light coating of 3 in 1 oil. Push cassette to the left. Close cover. Turn machine off and on.
Posted on Jul 11, 2008
Clean the Paper sensor which is down button use to feed the paper & the paper edge sensor on the carriage unit
Posted on Jan 15, 2008
DESIGNJET 450C SMEARS (BLEEDS) INK
Most likely the media (paper) is touching the print heads. This can occur because 1) the media holding mechanism is not holding the media correctly, and the media buckles, or 2) the carriage to media distance is too small. (Check the adjustment in chapter 5 of the manual).
I found a copy of the procesure online:
HP DesignJet 430 Service Manual Adjusting The Carriage To Media Distance
Dec 21, 2017 | HP DesignJet 450c InkJet Printer
My hp design jet 450c shows all three cartriges,data and media indicators on.... and the cartrige carrier box get stop in the middile with a quick **** while i power on the printer.when i push the cancel...
This is a problem with the Printer.The processor program may corrupted.Please call to service center and tell the problem so that they will reload the system.
Aug 08, 2009 | HP DesignJet 450c InkJet Printer
HP Design Jet 450 C won't print
***it could be a communication issue: port setting, cable, ecc.
It could be a driver problem too. You need a compatible version with your Windoes version.
Please read here
www.plotterdriver.it
CAD & Prints
Mar 06, 2009 | HP DesignJet 450c InkJet Printer
Error lights
Lights are explained in the owners manual. Google HP 450 owners manual if you don't have yours. Various lights can be everything from change the ink to close the cover to Oh Oh, you're in trouble!
Sep 03, 2008 | HP DesignJet 450c InkJet Printer
Problem with plotter
Are the lights flashing? If they are flashing it is a system error, if they are on steady it is a recoverable error. When you push cancel is the media light the only one or is align media or ready on as well?
Aug 11, 2008 | HP DesignJet 450c InkJet Printer
450 c
Make sure your paper is aligned with the left edge of the rectanglular holes on the right side of the printer paper feed slot
those slots are monitored to check for proper paper alignement and if it is not --it spits out the paper
Jul 25, 2008 | HP DesignJet 450c InkJet Printer
PRINTER DO NOT ACCEPT PAPER ON HP DESIGNJET 450C
I don't know if you are running in sheet or roll media, but we have this problem with roll media if it is not aligned properly. Usually if I release the media lever and pull 10-12" of paper through and align it with itself and with the dotted line to the right of the plotter, then it will accept it. Sometimes takes several tries. Sheet problems may be caused by dirty sensors. Good luck.
Jun 12, 2008 | HP DesignJet 450c InkJet Printer
Designjet 450C
In my 8 years of servicing plotters I haven't seen published specs as far as the paper thickness goes.But from experience and seeing my customers produce problems free plots, you don't want to plot on anything past 30 lb media. 99% of plots are done in the 18-24lbs range. Media Types: Paper (plain, vellum, coated, glossy) Film (vellum, coated, glossy, clear, matte), Translucent Bond for Black output only
Hope this helps
Mar 02, 2008 | HP DesignJet 450c InkJet Printer
HP DesignJet 450c InkJet Printer Logo
923 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
